Author Topic: What did you do to your bike today ?  (Read 3562329 times)
Offline Tomshep
« Reply #28325 on: February 22, 2020, 12:56:30 PM »
Carbs stripped. Two serviced.
Offline Tomshep
« Reply #28326 on: February 23, 2020, 11:40:44 AM »
All carbs serviced and on the bike. Throttle cables to fit, oil to be topped up then I shall run out of excuses. Time to fire it up.
« Reply #28327 on: February 23, 2020, 12:40:38 PM »
 Rode it like I stole it, came home and polished the engine, wheels and a lot of the chrome. 55*F out today, 6" of snow forecast next week. I also put the lowers on the windjammer in case it's cold next time out.
Online BenelliSEI
« Reply #28328 on: February 23, 2020, 03:10:32 PM »
Sat on line and ordered 5 renewal stickers for my three cb750’s, the Benelli SEI, and my KLR650. $42 each for the privilege! What a Provincial rip off....... the insurance companies will be send my renewals next!
Offline Tintop
« Reply #28329 on: February 23, 2020, 04:19:31 PM »
Will at least the bike plates aren't either falling apart (my truck), or you can't read at night (new ones).  What I don't understand is why some idiot told the police. ::) >:( >:(
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline 750K5
  • agentsmith5
« Reply #28330 on: February 23, 2020, 04:26:04 PM »
Painted Cases!
Offline Jarrett_Honda
« Reply #28331 on: February 23, 2020, 05:26:26 PM »
I rode my bike the first time with saddlebags. Felt different, but that was to be expected.
Sent from my SM-N950U using Tapatalk
Offline spotty
« Reply #28332 on: February 23, 2020, 05:57:42 PM »
just wait until you fill them with beer, thats when you'll notice something a bit wrong....happily you'll have beer to console yourself over the loss of your previous razor sharp handling
i blame Terry
« Reply #28333 on: February 23, 2020, 06:08:09 PM »
...and don't forget to drill some small drain holes in the bottom for when you fill them with ice.  Then you can throw in a couple left over steaks too.   ...and your friends (and others) will always be able to find you by following the drip trail.
Offline spotty
« Reply #28334 on: February 23, 2020, 06:12:55 PM »
and whatever you pack into them , the thing you need will always be at the bottom
i blame Terry
Offline web
« Reply #28335 on: February 24, 2020, 11:19:49 AM »
Picked the chain cover off the winter beater (PC26) just to have a look at a small water hose running behind it.
Oooohkay.  :-X
Now imagine the chain length is well within spec and it rides just fine...
And no, I don't wash that bike. It sees a muddy road every day too. It's the definition of beater.
« Reply #28336 on: February 24, 2020, 11:42:59 AM »
Requires dentistry
Offline Tomshep
« Reply #28337 on: February 25, 2020, 01:51:42 AM »
Fitted throttle cables. Just the central pair of plenum chamber rubbers to seat fully onto the inlets and top the oil up. Plan to fire it up this evening.
« Reply #28338 on: February 25, 2020, 10:03:28 PM »
got the last of three cb500 running pretty saleable?had some kind of mucus in the tank n carbs,starts on the button now,reused all the carb o rings got a leak,the new owner can deal with that #$%*.
Maybe this bloke would be interested?
http://forums.sohc4.net/index.php/topic,180989.0.html
« Reply #28339 on: March 04, 2020, 02:13:43 AM »
Just received the good 1973 XLH1000 crank and flywheel assembly so I can rebuild my black Sporty that I bought from my hospital bed last year. The assembly (with S&S rods) looks perfect, but just watched youtube vids of guys having to use a hydraulic press to remove the crank from the left side crankcase.
I don't own a hydraulic press, but I've always wanted one. Oh wait, there's around a zillion on Ebay. I do now............. ;D
Offline fxef79
« Reply #28340 on: March 11, 2020, 09:45:59 PM »
Swapped advancers from the TEC 333 that was on it (this ain't right for a CB750 - no idea what the PO was thinking) with a 300 I acquired.  Static timed using a probe light.
Reinstalled 3 spark plugs.
Learned my new 18mm socket CANNOT be removed after you've tightened down the plug on #2.  Ground down the socket.  Put plug in.  Took plug out.  Ground the socket some more.  Put plug in.  Took plug out.  REALLY GROUND DOWN THE SOCKET.
Reinstalled 1 spark plug.
Remounted 1 carb I had pulled to measure the rubber boot holding it to the manifolds (this has dual VM34s on CycleX manifolds).
Attempted to start.  Got a little cough, and then the battery died.
Observed I forgot to replace the leads on the battery maintainer sometime last week, and my periodic attempts to check timing and various electricals over the last week have drained the battery too low to get it started.
Dug out the 10A battery charger and put it on.
Fiddled with some stuff while it charged.
Attempted to start... cranking, no starting.  Waited a bit longer to gather more battery charge.  Attempted to start... cranking, no starting.
Observed I had the kill switch flipped.
Fiddle with some stuff while it charged.
Started... with only cylinders 3 and 4 firing.  Well, that can't be coils.  OK... bright idea - maybe I have a carb problem (1 carb feeds #1 and #2, the other carb feeds #3 and #4).  Quick test?  Swap the carbs.
Rerouted fuel lines and cables to swap carbs.
Started on all 4 cylinders! (huh?)
Best I can figure I had a stuck float on one carb... bumping them around swapping them must have freed it up.
Too late for the neighbors to mess with completing dynamic timing tonight...
Clean up tools.
Offline fxef79
« Reply #28341 on: March 11, 2020, 09:51:08 PM »
My first bike was a black '74 XLCH 1000.  Kick-only, and right side shift like your 73.  My uncle has it now - man I miss that bike!
« Reply #28342 on: March 11, 2020, 11:32:48 PM »
Yes, it could be related to the coils. ;) The coil that feeds the #4 plug also feeds #1, and the coil for #3 also goes to #2. It doesn't sound to me like it's hitting on all four?
Offline fxef79
« Reply #28343 on: March 12, 2020, 04:41:44 AM »
If there were a bad coil, I’d have no spark on either cylinders 1,4 or on cylinders 2,3.
What I had was cylinders 1,2 that were cold and only 3,4 were running.
For there to be a spark problem on 1 & 2 at the same time that was caused by a bad coil, it would mean BOTH coils are bad, and thus how could there be spark to 3 & 4, right?
That was my reasoning.
Sure, I suppose I could have bad caps or wires on 1,2, but that’s not a “coil” problem, per se.
Offline fxef79
« Reply #28344 on: March 12, 2020, 04:47:12 AM »
And the video doesn’t do it justice. After I listened to the video I realized it sounds completely different than what it did in person. Exhaust pressure/pulses were nice and even on both sides, all 4 header pipes heated up equally... pretty sure it was on all 4. It was definitely and distinctly different than before when it most definitely was only firing on the right 2.
Offline 750K5
  • agentsmith5
« Reply #28345 on: March 12, 2020, 05:53:11 AM »
I started polishing engine covers. Mind numbing work!
« Reply #28346 on: March 13, 2020, 02:20:03 AM »
You were a lucky boy mate, my first bike was the Honda C50 my sister loaned me to teach myself to ride on, in 1968 or 69. I love big bikes, so my first "real" bike was a 1975 CB750F0 that I bought new (old stock, nobody wanted them) in 1978. I bought my first Sporty, a 1985 Iron Head XLH1000 in 1987 and loved it, but was almost wiped out by an old bag who did a turn in front of me and put me in thee gutter, so I bought a big V8 musclecar, then another one, and didn't buy another bike until 1989, a Kawasaki Z750L1, which I thought was a character-less sewing machine until I traded it on a 1979 Ducati 900SS, which I discovered was the biggest, over-hyped POS that ever rolled off a factory floor. Great handling, grreat brakes, when it started........
I bought my 1994 XLH1200 5 speed Evo sporty in 2015 with 4000 miles on the Odo, it's still only got 5500 on it now, and it's a magnificent beast, but I've always wanted another iron head, so when I was laying in a hospital bed an hour after coming out of a general anaesthetic and I saw this bike going cheap, I texted the guy a message and sent him a deposit, sight unseen (apart from the poor pics he'd posted on FB) and my son drove me over to his place when I was discharged a couple of days later to seal the deal.
He even followed us over to my place in his truck and dropped it off. I'm looking forwards to replacing the crank and whatever else it needs, and putting some more miles up. I bought a new Sudco Mikuni carb conversion and spent a small fortune on the optional Borrani rimmed wheels (18 inch rear) for it, plus shipping from the US of A, so it'll be back on the road and running as good as it looks very soon. ;D
Terry's XLH1000 15 Oct 2019 by Terry Prendergast, on Flickr
« Reply #28347 on: March 13, 2020, 06:52:49 AM »
Rode my bike around. I did run into an issue of my bike cutting out at stop lights. I suspect that it's the battery that's dying everb though I just put the battery in last Fall.
The battery had 12.68v when I checked after making it home.
Offline fxef79
« Reply #28348 on: March 13, 2020, 07:34:08 AM »
Nice!  I'm gonna have to scrounge around to find some old pics of the '74.
My grandfather had a brown '76 XLH that I'd ride from time to time... it always threw me off switching between right and left shift.  To this day (and it's been 20 years since I rode the '74) I still catch myself having to think to switch feet.  Doesn't do much good trying to toe-up the brake.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #28349 on: March 23, 2020, 01:02:38 AM »
Wow!
    1,636,456 views and still going...who would have thought?  :o
