Author Topic: What did you do to your bike today ?  (Read 3725704 times)
0 Members and 35 Guests are viewing this topic.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #32800 on: February 12, 2024, 08:36:22 PM »
Built a sissy bar for the CB today.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
« Reply #32801 on: February 12, 2024, 10:14:24 PM »
scraped and cleaned literally a quarter inch of crud off a center stand.   Fantastically disgusting job.
Online BenelliSEI
« Reply #32802 on: February 14, 2024, 08:50:17 AM »
It’s amazing what gets stuck in there, almost as bad as under the sprocket cover!
« Reply #32803 on: February 14, 2024, 09:04:35 AM »
Chain lube is a magnet for dirt.
« Reply #32804 on: February 14, 2024, 09:13:41 AM »
Well I got started on my latest K6.
Started the Electrolysis cleaning of the tank that came on it, replaced sometime in the past after the 1st owner damaged the original tank. It was partially filled with old rusty gas from @ 2004.(I emptied it a few weeks ago and rinsed it with acetone and let it air out). I started it last night. This morning I decided it was time for a new electrode.
A couple more days and I'll rinse it out and do a day or 2 full of Evaporust. Then I'll rinse it well with 4 rinses of diesel fuel, then coat the insides with 2 stroke oil to preserve it.
Then it'll be off to my PDR guy along with a friend's tank to remove the dents from them.
Offline Magpie
« Reply #32805 on: February 14, 2024, 10:04:36 AM »
The last few days work, today remove the front end and start the cleaning process to prep for paint of the K6 frame and bits.
Online BenelliSEI
« Reply #32806 on: February 14, 2024, 12:29:16 PM »
Cliff……Another “exploding bike”. Looks like a full restoration to me. You should have started a project file! I’m so glad this doesn’t just happen to me. Your shop looks very comfortable.
« Last Edit: February 14, 2024, 04:45:24 PM by BenelliSEI »
« Reply #32807 on: February 14, 2024, 02:23:19 PM »
I've never attempted electrolysis in a tank before;it looks like a very good process.
I imagine the type and shape of the electrode has to be just right,so it doesn't short-out?
« Reply #32808 on: February 14, 2024, 02:40:02 PM »
Yes you don't want the electrode touching the tank. That's why the spray can top cut around the hinge and latch, double nutted and fender washers bolting the threaded rod to the cap and the tape to secure it solid.
The results speak for themselves.
« Reply #32809 on: February 14, 2024, 02:42:54 PM »
Stu…Another “exploding bike”. Looks like a full restoration to me. You should have started a project file! I’m so glad this doesn’t just happen to me. Your shop looks very comfortable.
I did John. But you probably meant it to Cliff to start a project thread?
I actually when saw this earlier I thought "why is John taking it apart again??" I saw the yellow lift....then I looked at the name....
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #32810 on: February 14, 2024, 02:42:55 PM »
That's impressive. What does a rig for that consist of?
Offline M 750K6
« Reply #32811 on: February 14, 2024, 02:45:21 PM »
Wow! 👍
Online BenelliSEI
« Reply #32812 on: February 14, 2024, 04:47:16 PM »
Stu….. That’s funny. I fixed the original. Cliff told me he was only doing a “light cleanup”! Next thing the engine is out and frame is stripped. It’s a disease.
« Reply #32813 on: February 14, 2024, 06:06:34 PM »
Well I guess you can start a support group...
Offline Floshenbarnical
  • Money pit enjoyer
« Reply #32814 on: February 15, 2024, 06:41:00 AM »
Tell me about it. I was just going to pull the motor to fix a leak. Now the entire bike is in labeled boxes and *everything* is getting the anal-retentive Floshenbarnical treatment
Oh well
'77 CB750 SS
« Reply #32815 on: February 15, 2024, 06:51:21 AM »
It's one of those things, knowing you were the last person there at the scene, can you leave it the way you found it?
We know the answer.
« Reply #32816 on: February 15, 2024, 08:56:55 AM »
This morning I decided to dump the washing soda/water mix from the tank, got a fair amount of rust chips out with the hose rinsing it out. Looks pretty good already but put another batch in and hooked it up again for another day or two.
Gave you the before again....
« Last Edit: February 15, 2024, 08:59:58 AM by newday777 »
« Reply #32817 on: February 15, 2024, 09:11:32 AM »
Stu,how long will it take to get it nice and clean of rust if you used Evaporust and kept it about 110-120 degrees for 18 hrs. ?
« Reply #32818 on: February 15, 2024, 09:38:07 AM »
Are you asking without electrolysis before Evaporust?
How much rust is a factor too.
I've only kept it at 70° never that high.....
« Reply #32819 on: February 15, 2024, 12:23:31 PM »
I heated up some Evaporust to around 120 degrees(#1 on my stove control)and put some small rusty parts into the pot and they were rust-free in 2.5 hours;pitted,but rust-free.  ;)
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #32820 on: February 15, 2024, 02:06:25 PM »
Did you maintain the temp somehow or just drop the parts in and let them cool?
« Reply #32821 on: February 15, 2024, 05:22:03 PM »
I maintained the heat at #1-1.5 on the burner control for a couple few hours;quick work  :)
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #32822 on: February 15, 2024, 07:39:52 PM »
Does it splash or let off a lot of odor? I'm assuming at that temperature it's not going to be near boiling point yet?.
« Reply #32823 on: February 15, 2024, 09:02:36 PM »
It stays calm but you can see some activity/movement in the heated Evaporust.
The low heat I use is pre-simmer(climbs up to about 150-160 degrees max:no more)and super-charges the stuff to get very active;I put a pot cover over it to keep the heat in and keep it from evaporating too much :D
I imagine you would place a fuel tank filled with it in a very hot room,etc.? Or an industrial oven at the lowest setting.
  • Money pit enjoyer
« Reply #32824 on: February 19, 2024, 06:33:18 AM »
We know the answer.
Well, quite. Do it once and do it right. I don't want to have to do this again. Getting that motor out was really annoying
'77 CB750 SS
