Author Topic: CB750 Instrument internals-have you been inside?  (Read 2065 times)
« on: March 28, 2010, 07:17:42 PM »
I'm wondering do K2 style instruments still have the internals that would allow for idiot lights to be mounted inside?
K1 instruments (what I want) are going for a lot on eBay as they are unique. But K2+ are readily available, I even have a couple, and K1 faces are available from Yamiya.
So if one could put the lights in the K2 instrument chassis, swap out the faces, voila K1 instruments. I have a brand new NOS k1 tachometer, just need a speedo.
Does anyone know?
Offline Old Scrambler
Re: CB750 Instrument internals-have you been inside?
« Reply #1 on: March 28, 2010, 07:57:16 PM »
You will need to attach a base-plate to attach the light sockets. I think you could transfer the idiot lights from a low-cost clock like a CB100 or such. Delicate work but I think its do-able.  Before you go any further.......I just remembered........There's a set of K1 clocks at a friend's salvage yard..........I told him to get them off of the roller and put them away a few years ago. I'll check tomorrow!
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #2 on: March 29, 2010, 06:45:41 AM »
Hi Dennis: I think we talked about a set back in December? I passed at the time hoping for a better deal. With the NOS tach for free (pennies from heaven) I was just shopping for a speedo. Just last night I won an ebay auction, I didn't expect to. I set a bid and went to bed. Won it at only slightly more than I wanted to pay, so if its in good shape I'll be good to go.
If your friend has a set they should bring good money. But the market is fickle.
« Reply #3 on: March 29, 2010, 11:46:36 AM »
Dennis I'm interested in a set if no one else needs them , my tach just went south. it is reading about double. cable winding up maybe?
Offline 77cafe750
« Reply #4 on: March 29, 2010, 11:54:48 AM »
i have been in side the gauges and mounted my shift light internally so doing the idiot lights is definatly doable
live like an outlaw and love like an angel
crash
blacked out gauges rock
http://forums.sohc4.net/index.php?topic=67710.0
« Reply #5 on: March 29, 2010, 12:05:38 PM »
Cable is easy to check.
Probably inside the head, the spinning bits have lost their lube. I've never actually been in one, but that's the general idea.
« Reply #6 on: March 29, 2010, 12:07:49 PM »
That's interesting to know. I will be sending my newly obtained K1 speedo to a shop to have it recalibrated to my smaller wheel.
But I think I will experiment with my K2 gauges and see if I can put lights in them.
« Reply #7 on: March 29, 2010, 06:47:10 PM »
Good for you on the ebay win!
Don R..........suggestion.......remove the cable and spray some graphite or teflon into the tack with a straw....not too much!  Also check the cable to be sure it its not broken or frayed.  Then lube it with the same spray.  If you remove the tach from the bike, be sure NOT to store it on its face. The new (or old) lube could leak onto the face and stain it.
I looked at the salvage yard set of clocks today.  They are rough but the tach would only need a new face.  The speedo would need a new crimp-ring as wll as the chrome 'cup'   The seller wants $60 for the set with the mount.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
« Reply #8 on: March 29, 2010, 06:49:44 PM »
More pics
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
