Author Topic: Modifying speedo drive for dual disks on 550 / 750  (Read 14696 times)
Offline Tintop
« on: May 05, 2010, 08:00:54 PM »
Thought I would post this early picture (edges need finishing) of my modified speedo drive for a 550.  The key is that you need a front hub with the flats machined on two sides.  I have a 550K (using), and early 750F (for next project) both with the flats.  Also have a 78 550 without.
This is what the final setup looks like.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Re: Modifying speedo drive for dual disks on 550 / 750
« Reply #1 on: May 14, 2010, 07:21:25 PM »
Interesting.........
Glad you could use my pics from a few years back.  ;D
Here's how it turned out.  ::)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #2 on: May 14, 2010, 08:48:20 PM »
I was just going to say................ ;)
I still have the print out of that photo out on my bench, somewhere ;D
.......your just sitting there aren't you ;)
Offline Roach Carver
« Reply #3 on: May 16, 2010, 08:10:20 PM »
 :D
Offline Tintop
« Reply #4 on: May 17, 2010, 05:11:09 PM »
I also see that the bike was a BOTM.  Hope mine comes out that nice.
77 CB550 Cafe build
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #5 on: June 26, 2010, 09:48:41 PM »
Thanks for posting these pictures. Just in time too.
There isn't anything forcing (holding) the speedo drive against the wheel?
« Reply #6 on: June 27, 2010, 12:26:39 AM »
The original steel plate is holding it against the disc..
 Hey Jimmy, are you going to be up at OKeefe Ranch on July 10 & 11 ?
Offline Ricky_Racer
« Reply #7 on: June 27, 2010, 09:03:37 AM »
bwaller... Would you mind telling us what front fender you used on this build? CB650?  And how was the width with the mid-70's CB750 forks, and what did you have to do to get a secure fitting?  I'm working on a late Tracy and need a finned front fender similar to this one. Thanks in advance!  RR
« Last Edit: June 27, 2010, 09:06:17 AM by Ricky_Racer »
« Reply #8 on: July 04, 2010, 06:24:05 PM »
Sorry I haven't checked in here for a while.
That fender is from a VF500F. It's rivoted to an aluminum bracket which bolted to lugs cast into the original fork legs and acted as a fork brace.
I machined the 550 forklegs (longer, later model legs)round and made a clamp for each leg that the fender fastens to and again get the benefit of a built in fork brace. This fender is originally for a 16" wheel, but I laced up an 18" for this one, and it fits well. I did try it on a 19" front & it looked goofy....too small.
Offline Ricky_Racer
« Reply #9 on: July 04, 2010, 08:42:01 PM »
Thanks for the reply! Yeah the VT500F had a small front wheel. I think I'm going to gamble on picking up a CB650 front and hope it is the right width. Have a good one. RR
Offline cwchan
« Reply #10 on: September 10, 2010, 12:19:37 PM »
So does anyone have suggestions to modify to fit for the hubs without the flats?  i was thinking of grinding notches into the Inner diameter of the disc rotor...
Offline Ricky_Racer
« Reply #11 on: September 10, 2010, 12:48:13 PM »
That'll work if you have access to a mill. Machining flats into the backside of the rotor is a second way to do the job. RR
Offline Tintop
« Reply #12 on: September 10, 2010, 02:29:26 PM »
My 78 550 hub doesn't have flats.  I was thinking of taking the lip off the drive plate in a lathe, and then installing dowels in the hub which would mesh with holes in the plate.
77 CB550 Cafe build
Offline Tintop
« Reply #13 on: September 10, 2010, 02:33:34 PM »
Are you sure that would work RR?  My rotor (550) is a slip fit over the hub centre.  There is no clearence for the edge of the drive plate between the rotor and hub.
tintop
77 CB550 Cafe build
Offline fantino
« Reply #14 on: September 16, 2010, 02:51:27 PM »
A member on the forums (Rangelov) has had a number of adapter plates machined out of aluminum for this very purpose. I'm awaiting mind, but they seem to be pretty damn slick. They're in the FS forum:
http://forums.sohc4.net/index.php?topic=76835
Offline Tintop
« Reply #15 on: September 16, 2010, 04:51:35 PM »
I saw the post, nice piece.  But if you have the drive plate, and some basic hand tools its free.
Another way to make it is to turn the lip off in a lathe, and then bend down two edges to fit the hub flats.
77 CB550 Cafe build
Offline Ricky_Racer
« Reply #16 on: September 16, 2010, 05:59:53 PM »
tintop
Sorry I missed your posting, TT. I don't know about the CB550, but I've seen reliefs cut into the rear of the CB750 rotors. Of course the chrome trim ring is unnecessary then. I'm using old sandcast drive plates that work like the cut 'n bent ones, so I haven't had to do either yet.  RR
Offline Tintop
« Reply #17 on: September 16, 2010, 06:21:49 PM »
tintop
Those are the ones that Honda sold individually later, for dual disk upgades.  Tried to find one for my project, but ended up having to make one. :(
77 CB550 Cafe build
Offline nippon
    • Classic Cycle City
« Reply #18 on: September 17, 2010, 02:18:34 AM »
We made some of the modyfied speedo drives for double disc setups.
nippon
Offline Tintop
« Reply #19 on: September 17, 2010, 03:59:08 AM »
nippon
nice looking piece nippon.  That's along the idea of what I had planned on doing if I had one machined.  Only difference being I had thought of using dowels instead of screws.  The speedo drive holds it in place once assembled on the axle.
tintop
77 CB550 Cafe build
Offline Sealteam1
« Reply #20 on: February 16, 2020, 06:45:01 PM »
nippon
Do you still have any of these?
Offline Ricky_Racer
« Reply #21 on: February 16, 2020, 06:51:06 PM »
Sealteam, I can save you a ton of work. Take a look at my Ebay listing. It's a very rare part, but exactly what you need!
https://www.ebay.com/itm/173924740446?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
RR
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #22 on: February 16, 2020, 07:09:08 PM »
That’s a great price on that Ted! I sold a stack of repops at 75 bones each!
Offline Ricky_Racer
« Reply #23 on: February 16, 2020, 07:11:53 PM »
Yeah, Mario. These are originals I've had for about twenty years. Too bad that Honda no longer offers them.
RR
