Author Topic: Mirror Blurrrrrr  (Read 4143 times)
Offline Rosinante
  • All Generalizations are False
Mirror Blurrrrrr
« on: June 25, 2010, 04:36:29 PM »
This is for the 750 guys, as each bike no doubt has its own vibration signature.  I wonder how much vibration do you get in your mirrors.  Let's say a group of cars are behind you on the freeway at freeway speeds.  The choices are:
1)  I can tell how pretty the lady drivers are.
2)  I can sort of tell what make/model the cars are.
3)  I can count the cars.
4)  I cannot count the cars, but can tell that some have their lights on and some do not.
4)  Cars?  What cars?
1978 CB750K
Offline MasterChief750
  • Detonation
Re: Mirror Blurrrrrr
« Reply #1 on: June 25, 2010, 04:41:36 PM »
im deff #4
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
Offline hondaface75
« Reply #2 on: June 25, 2010, 05:51:41 PM »
At freeways speeds I can see what the models are (if they are close enough mind you). I have the DCC barend mirrors. Short stems, about 2 inchest, and mirror at about 2 inches as well. On clubman bars. They dont really fuzz up on me at all, just at that speed its hard to tell in such a small mirror.
Offline Popwood
« Reply #3 on: June 25, 2010, 06:57:19 PM »
That's a good question and something I've been wondering about for awhile. I'd say I can generally make out the kind of car I'm seeing (all being relative to the distance behind) but what I wonder is why one mirror looks more fuzzy than the other? Can one side of the bike be less tuned than the other causing more vibration and blur in the rear views than the other side? And if so, what are the harmonic vibrations that cause it and how does one correct it? Carb sync, valve lash adjust? Just what's traveling up the handlebars to the mirror?
Current Rides:
1975 cb550K
1975 cb750K
1967 Bridgestone 350GTR
Past Rides:
1988 400 Hawk
195? Schwinn Whizzer
« Reply #4 on: June 25, 2010, 07:11:28 PM »
All engines have resonant frequencies, to counter this use bar end weights,they will definitely help and if you really need to see clearly at the vehicle behind {is it the cops?} then pull in the clutch for a second and have a look, i have been doing this on most of my bikes for years.... ;)   I should add that the roughness of the road surface and the stiffness of the suspension will also effect the vibes through the bars...
« Reply #5 on: June 25, 2010, 07:19:32 PM »
Good question. I found it depends on the mirrors. Bar end mirrors though small are very very clear even at speed. On the other hand the stock mirrors are #4 or worse at speed...I am with Mick in that bar end weights may help but keep in mind that it may be mirror specific as well.
Andy
Online Don R
« Reply #6 on: June 25, 2010, 07:23:13 PM »
A PO put some custom rectangular short mirrors on mine, I get a nice view of my arms and on the side some blurry cars. gotta order some stockers.
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #7 on: June 25, 2010, 07:25:50 PM »
I have a bar end mirror and the vibration is at a #3
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #8 on: June 25, 2010, 07:26:25 PM »
i'm the 2nd number 4   :D :D  but that's because i don't have a mirror on my bike currently.  i know i know, i need one!  just looking for the right one!  (it's on my 01 spirit 750, and it's a hard tail w/ 12" apes, so it's a difficult decision!)  but i do plan on some old school looking under the handle bar or nice foldable bar end mirrors w/ weighted bar ends to make them more useful!
Offline Nikkisixx
« Reply #9 on: June 25, 2010, 07:29:58 PM »
Barend mirrors make a difference for sure.  I can tell what the make of that car is is and sometimes know enough to slow down and see if that lady cop is good looking  ;)
I chalk part of that up to the fact that my barends are fisheyed.  It is like camera shake diminishing when the zoom is all the way out (wide angle).
« Reply #10 on: June 25, 2010, 07:55:04 PM »
I am going to make an assumption here, the bar end mirrors are doing the same thing as the bar end weights, putting the weight at the end of the bars helps dampen the vibrations. So for those wanting normal mirrors i suggest again bar end weights.... ;)
  • Like a well oiled
    • Undead Asphalt
« Reply #11 on: June 25, 2010, 08:05:40 PM »
eh... makes sense.
Offline Johnie
« Reply #12 on: June 25, 2010, 08:58:19 PM »
The bikes I bought with aftermarket mirrors were pretty blurry. Then I bought OEM Honda mirrors and no blur.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline GammaFlat
« Reply #13 on: June 25, 2010, 09:43:30 PM »
There are also mirror "isolators".  My Kawasaki KLR650 came with them.  It's a 1 inch (or so) piece that screws into your mirror mount.  It is then shaped kind of like a small cup with rubber in it.  The rubber contains the piece of metal that has female threads that your mirror mounts to.  My brothers both have KLRs with no isolators and I "claim" to be able to tell a difference.  ;)  We all have bar end weights.
K6
85 Goldwing
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
« Reply #14 on: June 26, 2010, 12:42:12 AM »
With the 750 I would say #2 I see the makes of the cars and such, it's not too bad.
With the 350 I can't see jack... Infact the glass vibrated out one of the original mirrors and shattered on the road & and I had to replace it.  :o
« Last Edit: June 26, 2010, 12:44:07 AM by cb350twin »
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
Offline Popwood
« Reply #15 on: June 26, 2010, 05:34:08 AM »
First I've heard of bar end weights. Do they just fit in the end of the hollow bars? Remove the grips and put them in? Do they vary in weight? Are the commonly available at a bike shop?
Current Rides:
1975 cb550K
1975 cb750K
Past Rides:
1988 400 Hawk
  • Like a well oiled
    • Undead Asphalt
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #17 on: June 26, 2010, 05:54:19 AM »
..OEM Honda mirrors and no blur.
Must be the case. After reading this thread and thinking, no blur comes to mind when I ride, it must be the OEM mirrors vs. others. ???
Offline crazypj
  • I'm brill, me
« Reply #18 on: June 26, 2010, 06:08:15 AM »
 Those things were stock on Suzuki's in 1970's, probably still availble.
 They have modified them and fit closer to mirror head on new Suzuki Gladius.
 I still have about 6~7 NOS.
 Have to change clutch side mount on Yamaha's because of left hand thread
Offline SohRon
« Reply #19 on: June 26, 2010, 06:46:05 AM »
These are the "vibration isolators" as described above; they have them at JC Whitney, currently on sale for $1.95 apiece. I've never used them, but they look interesting
Anyone tried them?
Offline crazypj
  • I'm brill, me
« Reply #20 on: June 26, 2010, 08:37:27 AM »
I've never broken one so they are pretty robust (genuine Suzuki)
The only problem I've found is the mirrors move back slightly at speed because of wind resistance.
Shows they isolate mirror though  ;D
PJ
Offline Rosinante
« Reply #21 on: June 23, 2024, 02:00:10 PM »
Zombie thread, that I started, but now I have something to report.  I recently dropped the coin for a pair of NOS factory mirrors.  They ARE worth the money.  I can see everything behind me now, with no blurrrrrr.  Very happy.
1978 CB750K
Offline M 750K6
« Reply #22 on: June 23, 2024, 02:30:19 PM »
Stock mirrors, 750K6, I'm a 3.
« Reply #23 on: June 23, 2024, 03:09:32 PM »
...you can tell what model the cars are?
I could in 1972, today not so much.
I'm not talking about those in the mirrors...just all of 'em...
I still have the factory mirrors on mine, they are pretty good when I re-glue the mirrors to the frames: about every 10 years or so the rubber insert that holds the mirrors shrinks (some more) and then they start shaking and vibrating, so I have to glue them down.
Again.
Offline Rosinante
« Reply #24 on: June 23, 2024, 04:32:05 PM »
I hear that.  Today's automotive styling, or should I say lack thereof, is pathetic.  But there is still variety in pretty girls and therefore the world still makes sense.
1978 CB750K
