Author Topic: What is the opposite of diamond cut fins?  (Read 890 times)
Offline q2418130103p
« on: October 10, 2010, 05:22:54 PM »
You guys have seen diamond cut fins right?  What is it called when the fins are simply flat and polished as opposed to diamond cut?
Check out my CB550 project thread:
http://forums.sohc4.net/index.php?topic=83097
Re: What is the opposite of diamond cut fins?
« Reply #1 on: October 10, 2010, 05:32:00 PM »
Some guys call it "de-finned".
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
« Reply #2 on: October 10, 2010, 09:43:26 PM »
Stock and polished?
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
« Reply #4 on: October 10, 2010, 10:38:57 PM »
 There is Block-sanded & polished fins..
 Milled fins...
 Hexed fin...
 If you are gonna do it, shave the valvecover while you are at it...
