Author Topic: Air Filter & Stack Filter Kit for 550's & 750's / The end, see post #898, pg 36  (Read 246384 times)
Offline Kong
Re: Air Filter & Stacks Combination for 550's & 750's
« Reply #350 on: February 17, 2011, 02:53:46 PM »
I could get behind that rainbow set, if it only had a green on in there somewhere.  I like green.
2002 FXSTD/I  Softail Deuce
2001 Acura (Honda) CL Type-S
1986 Honda Rebel, 450
1978 Honda CB550K
1977 Honda CB550K
Offline Tintop
« Reply #351 on: February 17, 2011, 03:15:04 PM »
Replacement filters would be available thru ITG if required?
These are being made by ITG, exclusively for myself.  So I will be handling replacement 'parts'.  That said, the filter with proper care should / could last indefinitely.
Good question! Can I just buy the filter?
If by 'filter' you mean the foam & back plate parts (no stack holes), this is something I will be doing, but not until after the 1st orders are shipped.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Silverback
« Reply #352 on: February 17, 2011, 03:27:03 PM »
Don't even need the backing plate, just the filter. I can do all the rest.
Chris
"It's hard to define soul. You get it in art. You get it in music, and occasionally you get it in machinery."
78 CB750F racer
78 CB750F stock
75 CB750K Baby Blue Sold (She was a great bike!)
71 CB750K (rusty rod)
77 cb550F Sold :(  Bought it Back :)
Basket case 73 CB750, 77 CB750F (Building now)
01 Aprilia Falco
76 kz400
96 BMW K1100LT
Offline shinneh
« Reply #353 on: February 17, 2011, 07:28:46 PM »
Awesome photo shop job there man. I definitely will go for a yellow set....after getting some data. I'm sure I haven't missed any posting about the test trial going on. So, I still await said trial's results. Anxiously. Anxiously waiting.
Anxiously.
Our greatest glory is not in never falling, but in getting up every time we do.
-Confucius
Offline Tintop
« Reply #354 on: February 19, 2011, 02:49:26 PM »
Didn't get to use this setup in CA, but did put it on the bike today.  Did a quick test start so I can do a video tomorrow. ;D
Frankenstuff engraved back plate, and the 1st set of blue stacks.
77 CB550 Cafe build
Offline odiewan
« Reply #355 on: February 19, 2011, 03:36:35 PM »
Tintop, I'd like to have a set of red ones for my 750, if possible.
thanks
CB750K3
2009 Aprilia RS125
2001 Aprilia RSV Mille R
2002 Suzuki SV650S
1979 Vespa P125X
Offline Tintop
« Reply #356 on: February 19, 2011, 04:09:26 PM »
thanks
noted odiewan.
77 CB550 Cafe build
Offline SOHC Digger
  • I'm not an
« Reply #357 on: February 19, 2011, 04:18:00 PM »
Tintop, I'd like a yellow set for my 78 CB750F.  Please pm me with whatever deposit is necessary.
Offline wannabridin
  • Patience made me a
  • -Garrett
« Reply #358 on: February 19, 2011, 04:44:56 PM »
a little tight there eh?  looks awesome!!!
hurry up and take my money already!!!   :D :D
Offline Tintop
« Reply #359 on: February 19, 2011, 05:34:06 PM »
Yeah, noticed the shape when I posted it.  Think its just the camera angle, but going to check it out tomorrow.  Plan on shooting some video, just hope the sound is good. ;) :)
77 CB550 Cafe build
Offline Grnrngr
« Reply #360 on: February 19, 2011, 07:30:53 PM »
MMmmmmm   yeah!!  some blue boots on the head side would really set it off..
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
Offline wannabridin
  • -Garrett
« Reply #361 on: February 19, 2011, 09:37:57 PM »
Something I just thought of, the "sharp" edges for the boot holes, they don't dig into boots at all do they?  Seems like with excessive movement they could dig into the rubber a bit much?
Or am I just being stupid?
Offline Tintop
« Reply #362 on: February 20, 2011, 04:44:18 AM »
Are you referring to the stack holes in the back plate?  The sealing ring(s) on the stack are very snug, there is virtually no movement, and a tight seal.  In addition, engine vibration is being absorbed by the stack body.
77 CB550 Cafe build
Offline Silverback
« Reply #363 on: February 21, 2011, 06:50:56 AM »
Is this possible? I am not saying that I can do your set-up better. I just don't need it for stock Honda carbs! Thanks!
Chris
78 CB750F racer
78 CB750F stock
01 Aprilia Falco
76 kz400
96 BMW K1100LT
Offline Tintop
« Reply #364 on: February 21, 2011, 07:19:51 AM »
The long and short is yes.  However not until after initial orders are filled, and I see what I have left.  That said, I receive them with an un-drilled back plate, so any order like your requesting would include the blank plate.  And no, I don't have any idea of what the price would be. ;) :)
77 CB550 Cafe build
« Reply #365 on: February 21, 2011, 07:11:03 PM »
Yeah, what Brian said, plus, the rubber boots are much thicker at the sealing ring end than OEM Honda items, so that's definitely not a concern, not that I've ever seen an OEM airbox do any damage to the sealing rings on the OEM boots either.
I had a problem last ride I did on my K1 with Brian's "Anti Pod" installed, I missed a gear (3rd to 4th) at high RPM, which resulted in a slight loss of power, but more worryingly, a loud rattle in the top end. Oh no........
Last night I hunted for the source of the top end rattle, and was relieved to find that it was a loose lock-nut on my #3 inlet valve. Woohoo! I re-adjusted the clearances, and happily, no more rattles! While I was at it, I decided to install bigger main jets as it has been running quite lean with 120's and the "Anti-Pod".
I've got a set of 132.5's somewhere, but couldn't find them. Poop. Hmmnnn, but I did have a 1.5mm drill bit and a heap of old 105 jets, so I thought, why not? I set four of them up in my lathe and drilled them all out, then installed them. (spilling just enough gas on my engine to make the silver paint run, fcuk it!)
Anyway, I fired it up, and, well, FARK! It absolutely screams up to the redline and sounds wicked! I'm a tad worried that 150 mains may be too rich under load though, so I think I'll get a 1.4mm drill bit (or better still, a proper set of jet drills) and experiment a bit with some more old jets. The driveway was blocked with cars, and it was getting late, so I only rode it around the back yard, but when I attempted an impromptu burnout on the concrete path, I swear the front wheel started to come up!
The downside was that my wife saw me doing it and scolded me mercilessly, (I tried to tell her that my hand slipped off the clutch lever, but she wasn't buying it) and Felix, my woosy little black cat, jumped the fence and hid under my neighbors house, and wouldn't come out for over 2 hours! Man, was I in the doghouse! Oh well, it was probably worth it........  ;D
Offline Syscrush
  • Sold. :(
« Reply #366 on: February 21, 2011, 07:31:21 PM »
Decide for yourself how to weigh this in your equation, but I'm pretty sure you're my hero. :)
« Reply #367 on: February 21, 2011, 07:59:53 PM »
Terry, how is it working at the smaller throttle openings?  This seems to be the tough area's of tuning when you get rid of the stock airbox and is the whole point of my interest in the anti-pod.
« Reply #368 on: February 21, 2011, 08:54:09 PM »
Thanks Guys, well of course I haven't ridden it any distance since I upped the mains so it's hard to say how it'll go with sustained throttle openings at any particular RPM, but it was nice and steady with the 120's down low, but awful over say, 4000 RPM? Not surprising though, considering how lean it was then. Hopefully I'll get it out again this weekend with a couple of different sized sets of main jets so I can compare the differences. Cheers, Terry. ;D
Offline Tintop
« Reply #369 on: February 24, 2011, 03:55:31 AM »
A quick update on the delivery front.  The filter metal work is done, and it is expected that they will begin making the foam elements later next week.  Seems my order is held up slightly, while they completed one for the Renault F1 team. :)
77 CB550 Cafe build
Offline wannabridin
  • -Garrett
« Reply #370 on: February 24, 2011, 09:20:41 AM »
A race team???  Unacceptable!!!
Offline odiewan
« Reply #371 on: February 24, 2011, 09:44:51 AM »
Aw man!!!! This is an injustice. Who do those F1 guys think they are? ;)
CB750K3
2009 Aprilia RS125
2002 Suzuki SV650S
1979 Vespa P125X
Offline hesselfuzz
« Reply #372 on: February 24, 2011, 08:27:36 PM »
And now they even get 2 extra weeks because they canceled the season opener in Bahrain.
Moderation is a fatal thing, the only success is in excess.  -Oscar Wilde
73 CB750k
78 CB750ss
70 CB750k
06 Buell Ulysses
Offline Syscrush
  • Sold. :(
« Reply #373 on: February 24, 2011, 08:36:26 PM »
Yeah, they're gonna use that time to test air filters. ;)
Offline Tintop
« Reply #374 on: February 25, 2011, 12:35:35 PM »
 :D :D :D :D :D :D
Not worried about the quality though (from ITG email) "The guys that will be building the filters are currently working through a large Renault F1 order..."
« Last Edit: February 25, 2011, 01:49:37 PM by Tintop »
77 CB550 Cafe build
