Author Topic: Air Filter & Stack Filter Kit for 550's & 750's / The end, see post #898, pg 36  (Read 280426 times)
Online Tintop
Re: Air Filter & Stack Filter Kit for 550's & 750's / The end, see post #899
« Reply #925 on: October 12, 2013, 02:19:50 PM »
See 'reply # 899' for drilling instructions.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline spdygnzlz
« Reply #926 on: October 16, 2013, 09:37:27 AM »
Got an email back from Andy@ITG.  He said the filter is available from their distributors but that it is unlikely to be on their current price list or catalog since it's just now become available.  I called the folks at Coast Fabrication in Huntington Beach, CA and they're looking into pricing for me.  Will post once I find out.
Offline KrautKoffin
« Reply #927 on: October 16, 2013, 11:56:54 AM »
I contact Raffi @ EurosportAcc in Anaheim, CA. I've dealt a lot with this company and should be able to catch a deal. I linked him to this thread so we'll see how it goes.
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
Offline spdygnzlz
« Reply #928 on: October 18, 2013, 03:20:06 PM »
I love trying to figure things out after I order parts.  Anyway, I have a 650 head with 750 carbs mounted in a 550 frame.  I think the 750 stacks are too long now that I have them mocked up.  Would the 550 stacks mount to the 750 carbs and is the 550 element smaller than the 750?  I'm going to reread this entire thread but seeing as I'm going on 5 hours of sleep every night this week, my attention span is about 5 minutes so figured I'd just ask.
Online Tintop
« Reply #929 on: October 18, 2013, 06:19:33 PM »
no - 750 throat is bigger / yes - 550 filter is 10mm shorter (45 vs 55)
77 CB550 Cafe build
Offline Gangsterfist
« Reply #930 on: October 21, 2013, 10:18:53 AM »
so now I'm in contact with Gary Donahew I gave him the part number JCJNBR/45 for the 550 set up and he's going to contact me.This is fun!!!
 but it's going to be worth it.
Offline KrautKoffin
« Reply #931 on: October 27, 2013, 02:16:47 PM »
Here's my gripe: a $225 air filter. Holy crap ITG, that's ridiculous.
/rant.
I'll be ordering one as soon as I trip on a stack of $20 bills or get my tax refund.
74 cb550
Offline dlhoulton
« Reply #932 on: October 28, 2013, 03:16:56 AM »
That's what I was hinting about several post ago when I found out info on them and posted it. Your getting the original "AntiPod" filter for there new reduced price, minus the custom stacks and clamps. You also are getting a blank base/mounting plate that you have to drill. Better do it right the first time, cause it will be very expensive trying to get a replacement.
Offline KrautKoffin
« Reply #933 on: October 28, 2013, 09:52:05 AM »
Agreed.
74 cb550
Offline JDub35
Correct me if I'm wrong, but I've been going through the thread and am I to understand that this Anti-pod is not happening now?
Online Tintop
Correct, however you can still get the individual pieces that make it up.  See post 899 / pg 36 for information
77 CB550 Cafe build
Offline Fiffen
First post ! :)
Anyone here made these with sucess lately ? Any luck getting all the parts ?
Offline Anton
Just picked up my filter at the post office! I went through Gary at Coast Fabrication in CA. I also received the stacks a little while ago too. Now I just have to find someone to drill the holes.  Pretty excited about this set up
Online Tintop
You can drill the holes with a hole saw from Home Depot, or similar.  Don't need a expensive one as you only need to do 4 holes.  Let me know which engine / carbs.  Spacing is the same for all, but location is different vetically for the 550.
77 CB550 Cafe build
Offline Anton
I've got a 550 TT
Offline Anton
How much room for play to I have with these stacks? My concern with using a hole saw is that they tend to "walk" a bit when starting the hole. If I use a 1 9/16, which is slightly smaller than the 41mm required, then it might work out.
What do you think Tintop?
Online Tintop
You need to use a hole saw that has a centre guide drill, then it won't walk.  It my shake a bit, but not enough to make the hole too big.  didn't have a chance to find my notes today, will do it in the morning.  Usually one side is nicer than the other, make that the inside and put your layout marks there.  Use a thin felt tip as it will easily be removed.
Find the horizontal centre line, and the centre point.  Make a new line 5mm above, and parallel (on the 550 it needs to sit slightly lower for frame rail clearence).  I'll check this tomorrow but memory says....spacing is 70mm between 1 & 2 / 80mm between 2 & 3 / 70mm between 3 & 4.  From the centre of the new line mark 40mm to each side, make a mark, and from there 70mm each way and another mark(s).  These are your centre drill points for the holes.
77 CB550 Cafe build
Offline Anton
Do you think a 1 5/8" hole saw will be ok? This is slightly larger than 41mm
Online Tintop
If you have calipers measure the dia. of the seal gap.  I'll check tomorrow.
77 CB550 Cafe build
Offline Anton
So I checked the diameter of the seal gap and its 44mm, which is for the 750 as it says in your post 898.. I havent checked to see if the boots fit the carbs yet but I have a feeling there not going to. Would this feeling be right?
Offline Anton
Sorry, I meant stacks
Offline Rocketman
Classic Motorcycle Solutions
« Reply #946 on: April 21, 2014, 08:30:41 AM »
Anyone have a good email or phone for Classic Motorcycle Solutions?  Can't pull up their webpage and emails come back as undeliverable.  Thanks.
Online Tintop
Assume your looking for the stacks, this should work - paul gabor: mybluebike2004@yahoo.com
77 CB550 Cafe build
Offline spdygnzlz
I have a set of the stacks for the 750 in case you need them.
Offline billingstitan
Late to the party but are you still making these?
Calling upon my years of experience, I froze at the controls.  ~Stirling Moss
2014 Ducati Monster 796
1977 CB550K http://forums.sohc4.net/index.php?topic=138289.0
1977 CB550K
1972 CL175
2000 Kaw Nomad 1500
1992 KDX 200
2001 Honda 80R
Past Bikes:
1973 Kaw 900Z1
1970 Yamaha 350RD
2003 Yamaha VStar 1100
2001 Suzuki GS850
