Author Topic: Homemade pin spanner for bearing retainers  (Read 9376 times)
Offline johnrdupree
« on: February 11, 2011, 10:22:12 AM »
I'm in the process of replacing the wheel bearings in my 550 and, of course, need to get the retainers out.  After searching around here for hints and tips, I went with the metal bar design:
http://forums.sohc4.net/index.php?topic=40052.0
A length of 3/4" wide steel and a couple of 4mm nut/bolt combos and it was ready.  It worked great for the front, but the back was having none of it.  Try as I might I couldn't get the rear to turn.  And, yes, I know it's a reverse thread and I drilled out the stakes.  That wasn't the problem, it was just on really tight. With a lot of force the bar would flex and the screws would pop out of the retainer.
While pondering my options I remembered an article I had read in a Classic Motorcycles magazine (I think that's the title) where a guy made a pin spanner for a shock absorber from an open end wrench.  Find a wrench of the appropriate size, drill two holes the correct distance apart through the side of the wrench, insert some kind of pin and you're ready.  I started looking around and grabbed the biggest open end wrench I had, a 1-5/8".  Some measuring, some drilling, some tightening yielded this:
The bolts are still 4mm and they have 7mm heads, which fit perfectly in the holes on the rear retainer.  And you know what?  It still wouldn't budge.  I ended up whacking the other end of the wrench with a hammer to loosen the retainer, but after a about a 1/2 turn I could spin it out with my fingers.  I know not everyone has a 1-5/8" open end wrench laying around (I'm not sure why I do), but maybe this will give you some ideas.
~john
1975 Honda CB550K1
1991 Honda ST1100
1989 Suzuki GS500E
1954 NSU Lambretta 125 (long term project)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: Homemade pin spanner for bearing retainers
« Reply #1 on: February 11, 2011, 11:16:17 AM »
Great idea.
This might have solved your leverage problem.
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
« Reply #2 on: February 11, 2011, 01:37:45 PM »
or use an adjustable for varying sizes.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
lewiszman
« Reply #3 on: November 06, 2013, 02:19:55 PM »
Awesome idea.
I used a angle grinder key. It fit two of the holes, side-by-side, which was okay since the retainer isn't torque on extremely tightly.
« Reply #4 on: November 06, 2013, 05:41:44 PM »
Clever!
« Reply #5 on: November 06, 2013, 08:45:29 PM »
Very clever and you can use the wrench as a plain wrench.
Offline lucky
« Reply #6 on: November 07, 2013, 04:20:01 PM »
Or just use the tool that came with your 4 inch grinder for changing discs.
« Last Edit: November 07, 2013, 04:22:48 PM by lucky »
Offline robvangulik
  • Honda Fourever
« Reply #7 on: November 08, 2013, 02:07:29 PM »
Read reply #3 on this same thread....
« Reply #8 on: November 08, 2013, 06:58:22 PM »
the rear has a left hand thread dont forget,clockwise will undo it,the front one is a normal thread,heres my home mades.
« Last Edit: November 08, 2013, 07:00:47 PM by dave500 »
