Poll
Is it a Stocker or Cafe Style this month?
Tintop
73 (53.3%)
sohc836
15 (10.9%)
markb
40 (29.2%)
egar
9 (6.6%)
Total Members Voted: 131
Voting closed: February 28, 2011, 08:10:35 PM
Author Topic: Vote for Bike Of The Month - March 2011  (Read 18413 times)
Offline Raef
Re: Vote for Bike Of The Month - March 2011
« Reply #25 on: February 23, 2011, 05:46:53 AM »
on 550's its on the inside of the frame, you can just see the edge of it.
the bracket on the out side appears to be for the oil lines.
Mark
Offline Really?
« Reply #26 on: February 23, 2011, 06:10:23 AM »
Ahhhh now I see it!
Thought about getting the polished front and back ones from carpy.  Only place I have seen them.  I am not a machinist.     ahhhh dreams....
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline kap384@telus.net
« Reply #27 on: February 23, 2011, 09:15:39 AM »
So torn, dammit!
Great work everyone!!!!
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
Offline Tintop
« Reply #28 on: February 23, 2011, 07:01:08 PM »
Ahhhh now I see it!
You can see the left one in the engine adapter pic (and edge of right).  They are alloy, with a small pocket milled in the inner face.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline gnarlycharlie4u
  • Far from being an
« Reply #29 on: February 24, 2011, 10:16:42 AM »
That was a tough choice. I really love those stockers but Tintop stole the vote this time <3
Offline sohc836
« Reply #30 on: February 24, 2011, 09:43:06 PM »
So my bike started off as a mildly modified bike, and i stripped it down and started to rebuild, here is a video it was very dark during filming however it does sound nice.
So I machined my own headlight, and tried to make it resemble a old carbide style headlamp, it started life as a piece of aluminum 6"diameter round stock. I also machined and welded up my own tach housing and LED backlit it (even made my own tach needle), I also machined my own rear drum brace from aluminum stock and fuel petcock mount from brass stock. Also a new brass and aluminum fuel valve was ordered up and installed.
the rear frame hoop is made from solid stock and was cold bent by hand (with a big pipe) and the seat support was re-welded to the frame. The passenger peg frame section was removed and rear-sets were added. I rewired the whole bike with a modified hot rod harness. and used the proper bullet style shrink fit connectors. I also moved the ignition under the seat with a fabricated polished aluminum bracket. LED signals were installed along with a LED relay flasher. The stop/tail light is a stainless 32 ford hotrod tail light mounted to a side mount license plate mount I fabricated from aluminum. I replaced the regulator and rectifier with a single solid state one from a DOHC and used a Odessy PC310 dry cell battery and of course relocated all the electronics under the seat.
It took a lot of emails to decide to get a Benjie seat and tank, but I didn't have the tooling to make a aluminum tank and also didn't have the knowledge to build a carbon one. however I did away with the seat mount and made my own. also strapped down the rear of the seat with a leather strap and brass fasteners.
The copper oil lines were hand bent and took almost a whole roll of tubing to get the bends right, and of course they were polished along with all the brass fittings were polished as well. The oil tank was replaced with a CNC'ed machined unit that was then mounted to the frame by welding a piece of flat bar under the seat.
I removed the starter and associated wiring as the bike starts fist kick anyway, and starters are for wusses. Bars were replaced with Renthal low rise bars and new grips, the bar was machined to run the wiring through them and all the controls were refurbished and polished.
I fabricated new shock mounts and moved the top mount farther back and lower down to raise the back end and change the geometry. The brake lines were replaced with stainless braided jobs, and the brake switch was polished as well.
The whole motor was disassembled checked over and pained then rebuilt, as it was already bored out to 836cc with some other upgrades ie pistons, springs, cam. Then the motor was treated to a set of Keihin CR 29 carbs and an open exhaust. Also, a joker machine filler cap was added to the tank.
and here are some more pictures.
ton up?
Offline sohc836
« Reply #31 on: February 24, 2011, 09:51:07 PM »
This will be tough for me.  Tintop has a very nice ride, sohc836 has some interesting things going on there (see his build thread), and both of those stockers are nice nice nice!  I would not have the ball's to do those year stockers.  If I can find something worthwhile to start with around here, I would have the balls to build something like Tintop and sohc836.  Perty much run out of things to do on momma's bike. Basically just new paint, reshape and recover the seat.
I would have to say that I believe that building those stockers would be way more difficult than building a cafe, I would find it very difficult to find the patience to source every single perfect part. for myself its easy to just imagine things and build them and if I don't like it then I can just change it, you cant do that when building a stocker, so you guys have my full respect for going that route. FYI my other dream honda is a K0 in candy gold.
ton up?
  • Far from being an
« Reply #32 on: February 24, 2011, 09:53:49 PM »
sohc836 that is a beautiful build no doubt.
dual discs and modified forks and you would have had my vote.
I feel like the bike is just... ALMOST done without them because of how badass everything else turned out.
I totally agree with you about the stockers though it's patience and discipline vs ingenuity in this BOTM thread it seems.
Offline sohc836
« Reply #33 on: February 24, 2011, 09:58:49 PM »
the forks have been updated with springs and valves, I just dont know what exactly was done as it was done by the PO and I was quite happy with the feel of them. I decided against dual disks as I wanted to keep one side of the spoked wheel open for visual effect. I had actually made a different headlamp mount that used aluminum tubing over the upper forks but it never came out quite how I wanted it to, it made it look meaner but just did not look right.
ton up?
Offline Raef
« Reply #34 on: February 25, 2011, 04:32:00 AM »
sohc836
Thanks for sharing the pics and vid, it is a very nice bike, I'd love to have a set of those wheels, the bike is built very much in the spirt of a old school cafe racer.
All I can say about the headlight bucket is wow, thats a lot of cuttin with a nice result.
Mark
  • Far from being an
« Reply #35 on: February 25, 2011, 06:49:17 AM »
I can totally understand not doing the dual discs because those wheels are purdy. By modified forks I meant a cartridge emulator or air caps or something (or fork swap? :D)
gsxr forks would look mighty beautiful on that thing.
Good on ya for not putting a big hunk of aluminum over upper forks. I don't think it would have turned out very clean looking.
Offline Really?
« Reply #36 on: February 25, 2011, 11:38:41 AM »
Looks like I will have to ask my daughter to decide again.  I can't make a decision.
Online FunJimmy
  • Who you calling
  • Vancouver
« Reply #37 on: February 27, 2011, 09:35:07 AM »
Vote cast!
Good luck everyone.
Offline egar
« Reply #38 on: February 27, 2011, 03:00:31 PM »
I am still shocked by the nomination. I discovered this site in 2005 or thereabouts when I bought a neglected 550 (the black one as my avatar) and was hooked. I did another 550 while looking for a 750 and finally got lucky. An attorney at our main office kept teasing me about one that he was considering selling. I didn't know what year it was and he kept saying that he might fix it up and get her running again. When he finally got serious about selling it, he offered it to me for $500. When I found out it was a 1970, I made the 2.5 hour drive to St. Augustine beach and snapped it up. He had owned the bike since 1974 and, being an attorney, was meticulous about paperwork. He even had the original title and owner's manual.
The bike was far and away in the worst condition of the bikes I had encountered. It was as if the 550s were practice runs for a honest to goodness restoration. Tearing into the engine was frightening. Spending thousands on parts and not knowing whether I had reassembled everything correctly was unnerving. When I finally heard the bike run two weeks ago, I was ecstatic. To be nominated along with guys who really know what they're doing is overwhelming. If it weren't for this site, I never would have fallen into this hobby (passion, sickness, it's all semantics).  I still need to get the fenders plated and save for some solide HM300 pipes and I'll be mostly finished. I have a feeling that this bike is a keeper.
sohc4
'04 ST1300, '70 cb750KO
Offline MoMo
  • Ride like you're invisible
« Reply #39 on: February 27, 2011, 03:24:42 PM »
definitely a  keeper ;D...Larry
Offline CB500Four
« Reply #40 on: February 28, 2011, 02:51:41 PM »
I have touched the nipple :o.
It was a tough decision.
If i would reveal my vote no one would be surprised  ;).
Good luck at all.
Regards, Heinz
Offline Old Scrambler
« Reply #41 on: February 28, 2011, 06:19:11 PM »
My vote is counted..............Good Luck to all!
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Really?
« Reply #42 on: February 28, 2011, 07:38:31 PM »
Talk about waiting until the last minute!
Offline Really?
« Reply #43 on: February 28, 2011, 09:39:15 PM »
We have a WINNER!  Congrats d00d!
« Reply #44 on: March 01, 2011, 12:08:15 AM »
Well done Tintop, great build...
Offline MoMo
« Reply #45 on: March 01, 2011, 01:03:31 AM »
Congrats to Tintop, excellent work....Larry
Online FunJimmy
  • Who you calling
  • Vancouver
« Reply #46 on: March 01, 2011, 07:17:17 AM »
Congrats Tintop for a well deserved win.
Offline markb
  • When I finish my current project I might be a
« Reply #47 on: March 01, 2011, 07:20:09 AM »
Congratulation Tintop!  If my bike wasn't nominated I would have voted for yours.  But egar's and sohc836's were excellent too.  Tough competition this month.  I was honored to be grouped with all of you.
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline Raef
« Reply #48 on: March 01, 2011, 07:26:46 AM »
Yes indeed, nice group of bikes, congrats to "speed worrior" and the rest of this months showing
Offline Tintop
« Reply #49 on: March 01, 2011, 07:50:32 AM »
Thankyou to all who voted.  It was an honour to be nominated (thanks Roach & tweakin), but to have your work vote BOTM by your peers, is truly special.  My thankyou also to this forum, for the inspiration, advice, and knowledge so generously to be found here.
Thanks markb.  Your's & egar's stockers are an inspiration in the art of restoration.  When the right one comes along, I can't think of 2 finer examples to use as my role models for 'getting it right'.  sohc836's metal work, especially the head light, is really great.  But then I have a billet bias anyway. ;) :)
Thankyou Retro Rocket, photolar, TipperT, FunJimmy, & raef for the congrats.
tintop / Brian
77 CB550 Cafe build
