Author Topic: Dorothy III - CB750  (Read 408407 times)
Re: CB750 made in March, 1970
« Reply #75 on: October 31, 2011, 06:32:16 AM »
New to me wheels and tires. They came off of the rolling CB750 I got on ebay. Much better than my original and finally 18 wheel in back.
Kept sprockets but they need to be replaced and the chain too.
Kicked started it for rhe first time, way cool!
« Reply #76 on: November 01, 2011, 01:18:20 AM »
Air filter is on.
« Reply #77 on: November 02, 2011, 03:11:26 AM »
Just documenting, the snake nest of harness looks awful.
Re: Dorothy III - CB750
« Reply #78 on: November 14, 2011, 08:33:05 AM »
Cleaned the front disc with scotch pad and xylol. New pads and no more squeel. Took it for a ride and later on replaced the chain with Tsubaki O ring and also new sprockets.
Finished at 11PM, test ride later, better in daylight.
« Reply #79 on: November 15, 2011, 06:20:32 AM »
The new chain makes amazing difference. Much better response, the old one acted as torque shock absorber to some extent. Had to adjust shocks, the chain would ground the left one. Also the front sprocket cover needed touch of a file, the sprocket was eating it.
Overall money well spent and the bike is safe now - except for the nut behind the handlebar, of course.
« Reply #80 on: November 20, 2011, 02:34:29 AM »
The throttle cable broke while I was getting ready to go to work. Changed vehicle for jeep.
On the weekend fixed the throttle by shortening the bowden and crimping on copper lump for the sleeve. Test ride in the back yard - I had some wine - and it works well. This is aftermarket but I plan to build my own.
Installed replacement valve in the #3 choke.
The center stand needs exhaust off to get the axle in.  Messed with exhaust, broke#4 clamp and decided to live with kick stand only. The center stand now supports the 73 frame in the storage - good use.
« Reply #81 on: November 21, 2011, 04:08:34 AM »
Found this schema of 4 to 1 throttle cable, time will come when I will need it.
« Reply #82 on: November 29, 2011, 03:48:20 AM »
Da Filtar!
« Reply #83 on: December 22, 2011, 08:41:07 AM »
Synchronized carburetors - finally!
Also new clutch cable. Now it is smooth and easy, what a difference.
« Reply #84 on: January 02, 2012, 05:36:52 AM »
That's a nice K0 you've got there mate, and a freebie to boot! Well done! Cheers, Terry. ;D
« Reply #85 on: January 02, 2012, 06:04:09 AM »
Thanks, Terry.
Offline Simpson
  • I ain't no
  • Aged to perfection
« Reply #86 on: January 02, 2012, 06:29:41 AM »
Hello fellow Virginian! Free is my favorite four letter word.
Glad to read you are having luck getting this running.
Also nice to see some folks sorts near by enjoying a SOHC.
1970 CB750 K0
1975 CL/CB 360 Mix
« Reply #87 on: January 02, 2012, 03:44:58 PM »
Hey there Simpson. Check the map, there are quite few of us in NoVa.  If Godzilla ever comes to the DC Metro, there will be a lot of partcipants.
« Reply #88 on: February 07, 2012, 01:59:35 AM »
I am working on dual disc brakes nowadays.  Here is a spare rotor I drilled for weight loss - I wish I could do the same to my body  :)
« Reply #89 on: February 07, 2012, 02:02:53 AM »
This is the speedo boss I made for the dual disc conversion.
Chunk of aluminum, the piece how it comes from the lathe and the final boss.
The grooves should be milled but due to the limitations in my machine park I had to do it the old way - using a file and elbow grease.  Surprisingly enough the best file to do this was the fine side of an old hoof rasp.
« Last Edit: February 07, 2012, 02:10:29 AM by 70CB750 »
Offline lucky
« Reply #90 on: February 07, 2012, 08:17:05 AM »
The motorcycle was free from a friend, based on his story, he got it himself for free in 2009 and got it running after who knows how many years.
This year, the space got more important than another bike - he has few others - and he gave it to me.
This is what  it looked like when I brought it home - without foot rests from the front of the frame, I removed those right away.
The bike is younger than me, not sure if it's a good or bad thing ;D
I like that seat it came with.
About that age thing......You can live with a Dorthy younger than you -right?
« Reply #91 on: February 07, 2012, 08:30:42 AM »
Definitelly! ;D
The seat - you can have it for the postage as soon as I get a different one. But some PO removed the frame bracket and the seat pan is basically gone beyond repair.
« Reply #92 on: March 28, 2012, 09:24:17 AM »
Didn't record the struggle with rear tube, spent entire week patching and punching the poor tube using rubber cement and off road mounting irons.
Finally got to Warrenton and bought 3 tire spoons and a new tube - problem solved.
This is Aluminum foot peg, I am going to replace all four with these, gotta buy more O-Rings to finish this one.
« Reply #93 on: March 29, 2012, 12:46:00 AM »
Did you forget to post a pic mate? ;D
Dorothy III - CB750
« Reply #94 on: March 29, 2012, 06:00:37 AM »
Yes I did, oops. I need to get more O rings too.
Offline tango911
« Reply #95 on: March 29, 2012, 08:23:16 AM »
cool thread
CURRENT STABLE:
1969 Honda Dream 305 (black)
1974 Mach III kawi 500 smoker
K2 (project)
K2 Original fixer up
K0 original fixer up
2006 CRF250R
« Reply #96 on: April 03, 2012, 01:26:31 PM »
I ride more than I wrench these days, the spring is in my beloved Virginia with all the subtlety of a freight train.  Getting vineyard ready for the season and million of other things including 30 chickens.
The dual brake setup is ready to go in - but it has to wait. The fork I have to replace  has inspection sticker on it and I need to pass riding test at DMV. Easier to wait with the brakes than argue dmv official.
Found NAPA filter 1390 - looks like it is gonna work on CB750 engine. Gotta make a nipple for it M20x1.5
Offline lucky
« Reply #97 on: April 03, 2012, 07:29:58 PM »
It takes 30 chickens to make a profit or at least break even.
« Reply #98 on: April 04, 2012, 06:04:18 AM »
It takes many vines to make wine cheaper than from the store - and who cares?  Ditto for chickens.
« Reply #99 on: April 13, 2012, 03:57:53 AM »
Documenting changes.
