Author Topic: Which should I buy: Pamco ignition or dwell meter?  (Read 10960 times)
Offline Holden
« on: July 01, 2011, 08:22:54 AM »
I've never done anything with points.  I'm wondering if I should buy a dwell meter or put that money toward a Pamco ignition.  The Pamco installation seems pretty straightforward (cb750ignition.com), but setting up the points still seems a little mysterious to me.
What do you think?
Offline Spiider
  • '73 CB750k
Re: Which should I buy: Pamco ignition or dwell meter?
« Reply #1 on: July 01, 2011, 08:33:56 AM »
Hijack: Where did you find to buy a dwell meter? I can't find one locally here in Ontario.
Is there a decent one online that we can get?
KingCustomCycles.com
« Reply #2 on: July 01, 2011, 08:49:15 AM »
You will still need to time the ignition to the engine, electronic or not.  I also don't see the need for a dwell meter on an 750 points ignition?
Offline zzpete
  • You better get an
  • 1969 CB750, 1971 CB750
« Reply #3 on: July 01, 2011, 09:00:46 AM »
I just saw a dwell meter at Sears. I think they have Sears in Canada.
http://www.sears.com/shc/s/search_10153_12605?keyword=dwell+meter
I read the Pamco thread, it looks like a good product. I am going to try out the HONDAMAN ignition on my 836.
http://forums.sohc4.net/index.php?topic=67543.0
"One of the things that make motorcycling so great because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
Offline DJ_AX
« Reply #4 on: July 01, 2011, 09:05:32 AM »
While the points may seem mysterious if you've never adjusted them before, once you start tweaking you'll find it's not really that complex. I'd say ... give it a shot.
I plan on picking up the HondaMan Transistorized Ignition eventually but right now my points are workin' just fine.  :)
Offline Holden
« Reply #5 on: July 01, 2011, 09:13:16 AM »
http://www.amazon.com/Actron-CP7605-Tachometer-Voltmeter-Analyzer/dp/B00062YUUS
Offline Accolay
« Reply #6 on: July 01, 2011, 09:23:48 AM »
+1 on doing your points first. It's not that hard, and although I hear the Pamco ignition is very nice, IMHO, I'd say learn how to do the points first just because. Zen and the Art of Motorcycle Maintenance and all that... disclosure- I'm using the Hondaman transistorized ignition system and I like it.
1977 CB550F
Offline BeSeeingYou
« Reply #7 on: July 01, 2011, 09:35:22 AM »
A points ignition system has never let me down in 32 years.  I have had failures with electronic systems on various motors over that same time period.  Sure it's old fashioned and not as efficient.  Hondman's is a bit different and retains the original system in case of electronic failure.
Offline Holden
« Reply #8 on: July 01, 2011, 10:00:17 AM »
I set the ignition timing yesterday for the first time.  It was easy, although I couldn't get the base plate (cylinder 1 and 4) adjustment over quite enough.
Offline lrutt
« Reply #9 on: July 01, 2011, 10:21:05 AM »
Yup, points will always get you home. unless you're going to race at 8k RPM's or ride 10k miles per year, stay with points. Electronics are just not worth it otherwise. Proper points will start almost immediately, run great right to redline, and hold an adjustment for many thousands of miles. Just follow the instructions WRT lubing the felt pads etc.
« Reply #10 on: July 01, 2011, 01:29:02 PM »
You don't need a dwell meter.  (Or the P ign.)
Just a feeler gauge and a 12v lamp with alligator clips and wires attached to it.  (...and a small addition to your knowledge base.)
There, I just saved you quite a bit of money and anguish.   ;D ;D
Offline Holden
« Reply #11 on: July 01, 2011, 01:39:05 PM »
I like that.  If anything, this bike has been a learning experience.  It's my first w/o FI and definitely my first w/o electronic ignition.  I do have a carburated lawn mower, but it's never needed any attention.
Offline immortal
    • 1976 CB750F "Pegasus bike"
« Reply #12 on: July 01, 2011, 01:49:41 PM »
I got the transistorized ignition from "Hondaman" that people speak about on here. I am just getting ready to install it. If there were to be a failure of any kind you still have your points as a back up system.
Sometimes...the hard thing and the right thing are the same thing!
1976 CB750F "Pegasus Bike"
http://forums.sohc4.net/index.php?topic=80492.0
bollingball
« Reply #13 on: July 01, 2011, 01:54:07 PM »
Points and a HondaMan Ign.
The only reason I see for a dwell meter is to get the second set of points just like the first set .But not necessary if you are good with a wire (round) not flat feeler gauge.
                                          Ken
« Reply #14 on: July 01, 2011, 01:59:36 PM »
a multi meter would be handy to have though for checking charging etc,some cheap automotive ones have tach/dwell functions.
Offline Spiider
  • '73 CB750k
« Reply #15 on: July 01, 2011, 02:19:59 PM »
Thanks everyone for the dwell meter suggestions.
I have the Hondaman ign, but you still need to set up your points properly with it.
I have adjusted them with a feeler gauge, and I have a test light I can use for setting basic timing but I think you really need the timing light and dwell meter to get it perfect.
Sorry to hijack...and now back to your regularly scheduled programming.
Offline Holden
« Reply #16 on: July 01, 2011, 09:44:14 PM »
One thing I noticed while setting the timing is that the points on the left (for cylinders 1 and 4 IIRC) would noticeably let out a blue spark every once and a while.  Could anyone tell me the significance of this?
Offline xsmooth69x
« Reply #17 on: July 01, 2011, 10:35:27 PM »
mine does that too the left points thing sometimes does the blue spark
1975 CB550 (FINISHED?!?!?)
Offline Skunk Stripe
« Reply #18 on: July 01, 2011, 11:22:45 PM »
Always nice to see the axe anything but points crowd out. I would only use points if I had to again, they just are not as good in my experience. After all, if points were that great, why are they not being used today? Times change and again, people DO have failures with points too, do not let people kid you on that.
As for a dwell, sears makes a good one that also has a tach function which is useful for tuning your idle mix. If you do stick with points, a dwell meter is the most accurate you can get. Setting dwell is more precise than setting just gap.
A meter is about $50.
Offline xsmooth69x
« Reply #19 on: July 02, 2011, 01:04:14 AM »
fuel injection anyone?
Offline Deltarider
« Reply #20 on: July 02, 2011, 01:43:42 AM »
You overlook the possibility that the cost of (mass!)manufacturing electronic components is actually lower than breakerpoints.
... a tach function which is useful for tuning your idle mix.
Definitely NOT in my experience.
I'd advise anyone to invest in an automotive DMM over a carb synchronizer that you can easily make yourself if you understand basic fysics.
Google Voltcraft AT400 for example. It offers practically everything. You can even check your capacitors, measure temperatures and if you want to do the latter by infrared an extension is available as an option. Overhere www.conrad.nl sells them. Check the specs. Click 'meertalig' under 'Gebuiksaanwijzingen' and you have the instruction manual in various languages including English.
« Last Edit: July 02, 2011, 01:56:40 AM by Deltarider »
CB500K2-ED Excel black
« Reply #21 on: July 02, 2011, 01:48:12 AM »
any tinkerer should have at least a basic digital multi meter,,they take a hell of a lot of guess work/trial and error out of your fiddlings.
Offline Deltarider
« Reply #22 on: July 02, 2011, 01:53:08 AM »
Right, and if you don't have one, consider yourself lucky, because now you can buy the automotive type rightaway that'll offer you everything.
« Last Edit: July 02, 2011, 01:57:49 AM by Deltarider »
« Reply #23 on: July 02, 2011, 02:51:34 AM »
this automotive one was cheap,like $70,with a socket set in a case that has every imaginable wierd screw driver/tamperproof/torx drive bit in the world that youve never even seen!the meter has a temp probe,duty cycle,rpm,dwell and all that other stuff you never use,i blew the fuse and made a dodgy modification and now have an external blade type on it,,the fuse was soldered inside behind the circuit board and a real mother to get to,i wasnt going there again.
« Reply #24 on: July 02, 2011, 03:17:29 AM »
I learned points on my long gone CZ250.   For this Honda, I replaced points right away with PAMCO -  too much to tinker with to worry about points.
It needed new coils anyway,  went with the whole package.
