Always nice to see the axe anything but points crowd out. I would only use points if I had to again, they just are not as good in my experience. After all, if points were that great, why are they not being used today? Times change and again, people DO have failures with points too, do not let people kid you on that.
As for a dwell, sears makes a good one that also has a tach function which is useful for tuning your idle mix. If you do stick with points, a dwell meter is the most accurate you can get. Setting dwell is more precise than setting just gap.
A meter is about $50.
