Author Topic: 1973 CB750 Leaky Puck  (Read 6583 times)
Offline chewbacca5000
  • I polish covers!
« on: December 31, 2011, 05:48:38 PM »
I could use a little help with my 1973 CB750.  The engine is out of the bike valve cover is off and I am at TDC 4.  Now I need an easy quick way to remove the cam towers to replace a rubber puck to keep oil form dripping down between 3 and 4.  The oil drips down and runs along the fin making it look like a head oil leak.
Thanks and Happy New Years!
Offline mrrch
Re: 1973 CB750 Leaky Puck
« Reply #1 on: January 01, 2012, 06:11:14 AM »
No quick and easy way, cam needs to come out. Hardest part of the job (removing engine) is done already.
my build
  • I polish covers!
« Reply #2 on: January 01, 2012, 06:57:31 AM »
I got the cam out, and sure enough the 2 center pucks in the center had oil in them. I am still not confident that the there is no head gasket oil leak. Compression on the side of the oil leak is good around 125 PSi.  No loose head bolts.
Looking at the head it looks like there is a little gap between the head and the gasket.  This might just be the placement of the gasket.  Any ideas here?
« Reply #3 on: January 01, 2012, 11:06:59 AM »
Are you planning on replacing the head gasket ? Your almost there anyways,new head gasket and change all the pucks would be a good idea where your at.
  • I polish covers!
« Reply #4 on: January 01, 2012, 01:00:37 PM »
Ekpent,
I think that is the route I am going to go.  I just took the head off and everything looks pretty good. A nice even layer of carbon on the pistons and the head no heavy caking or deposits.  Exhaust valve 3 is badly rusted so that will need attention. Bores 1.4 look nice and glassy.
If I take the block off does that force me into having to replace the rings.  Thanks!
Offline mrrch
« Reply #5 on: January 01, 2012, 01:06:38 PM »
Probably a good idea to seal the 4 studs for the cam towers, oil can leak past those threads. I had found them loose on the 2 heads I have worked on. I used some Threebond on the threads.
my build
  • I polish covers!
« Reply #6 on: January 01, 2012, 01:18:34 PM »
You mean the 4 10mm Phillips head bolts that attach the head to the block?  What about 3 bond under the rubber pucks?  Will this helps with leaks?
« Reply #7 on: January 01, 2012, 02:36:44 PM »
If it were me and I was not going to do anything with the pistons or rings I would leave the barrel alone. May be asking for more trouble breaking rings etc.Do the bores look good.?. Others though will suggest you change out the base cylinder gasket also.
  • I polish covers!
« Reply #8 on: January 01, 2012, 02:47:18 PM »
Bores look good and all rings are free, but will measure the bores to be sure.  That said I can probably get away with new gaskets and a valve job.
Offline K5owner
« Reply #9 on: January 01, 2012, 02:54:08 PM »
Yea, I'm one the others...   I'd change the base gasket while you're this far.
-Ray
Remembering the past...   Livn' the dream
1975 Honda CB750 K5, Restored Aug/2011
1971 Honda CB175 K5, next project
1977 Honda CT70, swap meet scooter
2004 Honda NRX1800 (Rune), Cruiser
1977 Honda GL1000, daily driver
« Reply #10 on: January 01, 2012, 03:25:53 PM »
just more opinions but...I've yet to actually see an undisturbed cb base gasket leaking...but of course, pulling the head could certainly be considered a disturbance...
Offline mrrch
« Reply #11 on: January 01, 2012, 03:42:35 PM »
There should be 4 6mm studs left on top of the head once the cam towers have been removed.
my build
Offline Powersnatch
« Reply #12 on: February 24, 2015, 09:07:16 PM »
I just wanted to chime in on this thread. I had the same leak, got into it and found my old pucks hard and  shrunken. New pucks were soft and a perfect fit, not concerned with gasket sealing them in at all. Will know tomorrow if they fixed the leak.
Offline SKTP
« Reply #13 on: February 24, 2015, 09:21:44 PM »
I did not seal my pucks and I now have "special" oil pants to ride...pulling the motor and sealing those pucks...
I plan on following this thread
http://forums.sohc4.net/index.php?topic=107040.0
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Wobbly
« Reply #14 on: February 25, 2015, 02:30:08 AM »
My experience exactly. I wouldn't touch it.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #15 on: February 25, 2015, 07:19:45 AM »
THAT THREAD IS ALL OP NEEDS! I'm going to be following it too! I started with puck leaks, then a head gasket leak. Going to be replacing my head gasket and my pucks when the weather warms up a bit.
--Evan
1975 CB750K "Rhonda"
« Reply #16 on: February 25, 2015, 08:39:30 AM »
+1
..and, if you have Hondamans book, it'll list the necessary puck thickness range.
I had to purchase 10 pucks to eventually get 6 that were thick enough (based on my puck cutout depth) for adequate compression.  I still sealed them.   I'm still leak free...
« Reply #17 on: February 25, 2015, 09:39:24 AM »
When head is off, there are things to do and money to spend....
Check the valves, seats and verify guides (stem - guide play) by wiggle the valves when a few mm out. CB750 steel guides seems hard to damage/wear out. Minimum lap all valves and replace all valve guide seals.
- Check if the cam tower studs leak oil. It should be easy to check with finger from the ign plug side. Also check if the threads for these are OK. Maybe need of helicoil that has to be glued, stud mounted with thread sealer with teflon.
A small radius on the head close to the stud indicate coming thread failure. The 2 inner seems to get thread failure easier than the outer.
The other threads for the cam bolts might need to get helicoils too?
My head have all these holes got timeserts.
New rubber pucks that are not too thin, seal them with a non hardening sealer.
The 4 small o-rings for oil channels to cam towers need to be replaced too. Many of them are too thin, no rubber over the head surface meeting the towers. It must be some extra for rubber to seal
-All threads for valve cover OK? More thread repairs...
« Last Edit: February 25, 2015, 09:49:18 AM by PeWe »
