Author Topic: brandEn's K4  (Read 339118 times)
Offline brandEn
Re: La Flama Blanca aka The K4 - painting the tank... AGAIN.
« Reply #425 on: June 29, 2013, 11:23:15 PM »
Branden,
That Tarozzi  fork brace your fitting does that fit your  K lower legs OK ?  I was looking at their website ages ago and thought they only done  braces for F legs.  If they fit my K legs  I'll grab one , saves dikking around trying to machine it.
cheers Johno
They fit over the 77-78 K legs. I installed 78 forks just so I could install a fork brace. The 77-78 K fork lowers are a bit taller and don't use fork gaiters.
Offline brandEn
« Reply #426 on: June 29, 2013, 11:24:22 PM »
Oops just realized that was about the other post lol
Do you do your own small stuff then?
Sent from my iPhone using Tapatalk 2
No, I use a coater near my house
Offline brandEn
« Reply #427 on: June 30, 2013, 07:59:16 PM »
So this is my first attempt at timing a cam and I "think" I got it. If anyone can check my work I would appreciate it.
Mega Cycle 125-65
A duration at .040"
Lobe center 103.5 deg
intake open 25 BTC
intake close 52 ABC
Start at TDC
Measure until I have .040" of lift measured at the intake retainer
Verify I am at 25 deg BTDC
Find lobe center to be 103.5 deg
Am I doing this right?
« Last Edit: June 30, 2013, 08:01:08 PM by brandEn »
Offline brandEn
« Reply #428 on: June 30, 2013, 08:02:11 PM »
Hey Ron.... any chance you can delete those ebay links for the oil pumps?
Offline CBcafeJunkie
  • 75 CB750F
« Reply #429 on: June 30, 2013, 08:02:45 PM »
Share the source :) gonna need some stuff done soon.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #430 on: June 30, 2013, 08:19:03 PM »
Great photo illustrations Branden.
Offline brandEn
« Reply #431 on: June 30, 2013, 09:33:40 PM »
Thanks Jim, I just hope it's right.
Offline tweakin
  • tear down
« Reply #432 on: July 01, 2013, 06:08:25 AM »
Glad the MEGA wheel and tools worked out, thanks for the beers!  8) Looks like you did everything correctly and great picture documentation ad usual.  Hopefully some of the other engine gurus will chime in since I have only degreed twice.
Damn B, your frikkin nuts working in this heat, does S stand next to you with a spray bottle and mist you while you wrench???  :o
Offline brandEn
« Reply #433 on: July 01, 2013, 06:27:08 AM »
Haha, no I work in intervals. 5 minutes work followed by 15 minutes of rest supplemented with 12oz curls. Works like a charm.
« Reply #434 on: July 01, 2013, 07:59:03 AM »
Sounds like you work in commercial breaks...
Good work.
Offline Godffery
  • Godffery's Garage
« Reply #435 on: July 01, 2013, 08:18:16 AM »
I'm just going to throw this in for fun;
My shop is in the basement of my house and the average temp is about 68 o F.  ; b
Offline brandEn
« Reply #436 on: July 01, 2013, 08:22:26 AM »
Good work.
Yup except every commercial involves cold frosty beer! haha
 8)
« Last Edit: July 01, 2013, 08:26:04 AM by brandEn »
Offline brandEn
« Reply #437 on: July 01, 2013, 08:25:00 AM »
Wow that would be nice this time of year.
Up here the heat doesn't bother me as much as the humidity when it does get hot. I am originally from Northern California (Chico and Redding) and it gets above 100 F routinely during the summer but its not nearly as humid.
Offline brandEn
« Reply #438 on: July 01, 2013, 08:34:20 AM »
So after some reading up on the Web Camshaft site and a few helpful posts from this forum I got a better understanding of this whole cam degree task. I came home from work and double checked everything and measured total lift and crunched some numbers and calculated duration. I compared everything to the cam specs and it matched right up. Confident I got everything where it needs to be I applied some blue loctite to my cam sprocket bolts and snugged them up. Next I will adjust the valve lash and recheck everything. It feels good knowing how to do this! I have read that on the SOHC to adjust the intake and let the exhaust side fall where it does. I plan on doing this but I also plan on measuring the exhaust side just for the experience and to know whats going on with that side of the cam.
Offline brandEn
« Reply #439 on: July 02, 2013, 09:22:29 AM »
Got some covers on.
Offline tweakin
  • tear down
« Reply #440 on: July 02, 2013, 09:36:07 AM »
Looks great.  Any paint updates?
Offline brandEn
« Reply #441 on: July 02, 2013, 09:47:45 AM »
Yup.
Its getting painted now.
« Reply #442 on: July 02, 2013, 09:52:17 AM »
I'm curious about one thing. You are timing the intake side and letting fate rule the exhaust side. I think I read this somewhere too. But I think I also read to split the difference. Did you see that anywhere?
Offline brandEn
« Reply #443 on: July 02, 2013, 10:04:55 AM »
Yea actually I have read a few posts suggesting that. I went with a suggestion from Mike saying just go with lobe centerline, so that was what I focused on getting right. Hopefully I did it right!
Offline iron_worker
« Reply #444 on: July 02, 2013, 10:16:50 AM »
If the cam is ground at all accurately it should line up pretty much exactly to the specs. There shouldn't be much "splitting the difference" involved. Not a bad idea to check though.
It looks like your degreeing process is OK. If your numbers lined up with your cam specs then that is good reassurance that you did it correctly.
IW
« Reply #445 on: July 02, 2013, 10:18:39 AM »
Is your piston to valve clearance good?
Offline brandEn
« Reply #446 on: July 02, 2013, 01:15:41 PM »
Yes it is.
Offline SKTP
« Reply #447 on: July 02, 2013, 01:30:33 PM »
Its looking gooooooooood
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #448 on: July 02, 2013, 02:40:57 PM »
Yes but you have to check the both sides.....the lobe seperation can be off a small amount which will effect the LC numbers....that's when you "split" the difference. Also...keep the indicator shaft parallel with the valve stem to avoid side deflection. ;) That retainer is plenty large enough... ;D
Offline Bankerdanny
  • Endeavor to persevere
« Reply #449 on: July 02, 2013, 02:42:36 PM »
I am jealous that the 750 rockers are attached to the head and not the cover, so you can adjust them with the cover off instead of having to fit the damn feeler gauge in the little access port like I will have to do on my 550.
