Author Topic: A Bike Is Born....750/1000cc  (Read 45292 times)
  • Moderator
Re: A Bike Is Born....750/1000cc
« Reply #125 on: February 21, 2013, 05:36:40 PM »
Apart from the loud exhaust and the extended swingarm, Samauto would be quite happy on the road. 8) 8) 8) 8) 8)
Would scare a few people $hitless, ;D ;D ;D ;D ;D ;D ;D  it does me.  ::)
Sam. ;)
Offline Bill/BentON Racing
    • BentON Racing
« Reply #126 on: February 21, 2013, 06:43:13 PM »
Wanna ride the Turbo?!!!!!!! ;) ;D It will get your attention!! ::) ;D Bill
BentON Racing Website
BentON Racing Facebook
    • BentON Racing
« Reply #127 on: February 22, 2013, 06:06:05 PM »
Alright,look what came fron Mr.Honda today!! Piston on the rt......going to be 1180cc with 6mm stroker 900F crank! :D 8) In order CycleX 915cc, RC 970cc,APE's 1000cc,Honda 1080cc,17mm pin.
another
again
736,812,836,836,915,979,1000,1080,73.25! 8) Bill...lots to do! ;D
    • BentON Racing
« Reply #128 on: February 25, 2013, 07:59:59 PM »
Alright, primary chain finally arrived from Ontario. Sold my shoe brake WM6  complete wheel assembly  to another forum member.So ordered today from Buchanan's WM6 3.50 x18 and stainless steel H/D spoke kit, of course, I'm getting it gold anodized! ;D Going to use CB750F hub, with it's large diameter disc, but drilled and maybe blanchard grind for weight savings.Front going to be CB750 F triple tree(a little more rake) and a set of Ceriani's up front 35 mm, as soon as I can find them.Frank 754 c'mon man! Chrome moly frame w/ swingarm, will sit low, engine mount higher than frame rails, also has deep pan to consider.Wheel base 72 inches.Remote starter, fuel tank alum cell, make or buy.
Brakes PM probably, we'll see. Want this one light!! WM3 or 4 up front, probably 2.15x18.Wow, lot's going on.Still gotta call Mr CFM (Mike Rieck). Got feelers out on rods CB1100F.Still waiting.More later.Thanks for the support.Bill
Offline dragracer
  • CB750F Dragbike
« Reply #129 on: February 26, 2013, 06:56:59 AM »
Hey Bill, i was thinking you were setting this one up like a street bike. Remote start??? Ok,  Pro ET bike then.
Keep it coming man!!!!
Offline chris mcshifty
« Reply #130 on: February 26, 2013, 10:08:29 AM »
Subscribed
    • BentON Racing
« Reply #131 on: February 26, 2013, 05:09:39 PM »
Can't run my chrome moly chassis in street ET! Custom made by the best..initials same as a motorcycle race ;D Bill
« Reply #132 on: February 26, 2013, 08:28:28 PM »
Lots of Betor forks out there, more reasonable than Ceriani. Abit hard to find the Betors with Fender/ brake mounts.. CanAm used them..
Offline dragracer
  • CB750F Dragbike
« Reply #133 on: February 26, 2013, 09:13:34 PM »
Yes, you can run a chromemoly chassis in street ET. But, it must be self starting and it must have functional tail light and head light. No flashlight. So... put on a dummy light thats been gutted out, add a low current draw LED light inside and an LED light on the tail but don't turn it on. Bam, its functional if necessary.
    • BentON Racing
« Reply #134 on: February 26, 2013, 09:34:18 PM »
We can jump on the kickstarter ....together! ;D Bill
Offline dragracer
  • CB750F Dragbike
« Reply #135 on: February 26, 2013, 09:53:33 PM »
No sir, we will come up with a way to put an onboard starter on this thing. i guess i will do my best to make this my contribution to the project. I still have my 79' DOHC 750 under the old shed. The motor is complete so i will try to pull it out soon and take a good look at the starter clutch set up. We've got to adapt it all to the SOHC cases. I have some cases i can dummy up just for this purpose o it looks like i'll be trolling Ebay for a 900F crank and rods. I used the starter motor from the DOHC on my no bar Kaw but i think i have another someplace. We probably will need to wire the starter up at 24 volts to get that stroker to turn over so leave room on the chassis for an extra battery(small one).
Offline jweeks
« Reply #136 on: February 27, 2013, 05:04:51 AM »
    The bike can compete in Pro ET. The challenges are the need for support people. You don't drive a 13:1 motor back down the return road through the pits. Per Rick Stetson, keep it 12:1 or under for that. The oil temperature would otherwise be too high for the next round. Having an external starter is fine but you'd need 2 of them. One in the pits and one at the front of staging lanes or someone to roll the starter from the pits to staging lanes and back again each round. You'd also need someone to tow you back down the return road to the pits after each round.
     Managing your oil temperatures correctly and you can run sub .030 packages all day long with the right back brake. That's why my big motor is 11:1 and I bring a friend when I race it. The friend hauls the starter cart around.
     Yes, electric starts are possible with 900F cranks. Frank, when you figure out the spacing, please document and post dimensions for the rest of the world. We'll all thank you for that! ;)
        Jon Weeks
    • BentON Racing
« Reply #137 on: February 27, 2013, 05:12:27 AM »
Jon,good points,maybe be wiser to go 12-1 to start with,can always increase! I "always" listen to what Rick says,9 times in a row champion,hell we start listing his acomplishments,I'll be here all day! I have a feeling cylinder work,and head coming out of the "Boston" area!!! ;) ;D Thanks,Bill
Offline joe p
« Reply #138 on: February 27, 2013, 05:41:17 AM »
I had 13.5:1 pistons and had about a 1/8' off the head. I Kick-started this motor all the time. although I weighed 220 back then :).
Offline dragracer
  • CB750F Dragbike
« Reply #139 on: February 27, 2013, 05:45:58 AM »
        Jon Weeks
Will do my best not to let you guys down. Bill, just get the rest of the package figured out please.
    • BentON Racing
« Reply #140 on: February 27, 2013, 06:45:48 AM »
Rear wheel on the way ,but my drilled disc and hub went away with the CB750F 75 cafe bike yestrerday in the Chapman bike purchase! ::) Think I got another hub,gotta look! ;) ;D Frank,still debut for opening round 2014! Chapman bike sooner,much sooner,GOT to check it out first!!! ;D Bill
« Reply #141 on: February 27, 2013, 11:20:55 AM »
Bill,
Glad to do my part for the Chapman by 'donating' all those 75 750F parts I needed on that list I sent you that were going to come from your cafe parts bike.  ;D ;) ::)
    • BentON Racing
« Reply #142 on: February 27, 2013, 12:26:11 PM »
Jerry...that's K! Probably still fill most of list!!! ::) ;D Bill
    • BentON Racing
« Reply #143 on: April 18, 2013, 06:41:30 PM »
A little update on chassis! I been busy....ok,Gary's been busy!!! ;) ;D
another
again
Fiberglass tank! Bike should be light,told me last night to send my spare turbo unit,gouing to make brackets for it,and removable engine mount so we can run A,F,or K engine!!! 8) 8) 8) 8) 8) 8) 8)
Better get to work! Only problem,I'm sick,caught a cold or something!Damn,still racing Sat! Bill
And yes ,I told George about the RC sidewinder on the bike behind mine! ;) ;D ;D ;D ;D ;D ;D
Offline jweeks
« Reply #144 on: April 19, 2013, 06:17:04 AM »
     Longer wheelbase than I have on my chassis. Good for clutch motors, not as needed for automatics. The 1180 that I have does a power wheelie in low at least 150 foot down the track, when the motor gets into the meat of the powerband. The wheelie bars that I run are used there to put the front end back onto the track. I chose the shorter wheelbase to lighten the overall bike a little. No, I'm not running the 295 cam on my combination. It's a very gentle power wheelie that just goes up around 2" on the front until the wheelie bar hits, then it comes right back down. The longer the wheelbase, the more gentle the front end comes up.
     The big displacement screams for air going into the cylinder head. The Cycle X roadracing relocated intake ports cylinder head would be very interesting in Bill's combination. More air coming in with some velocity will make that motor a beast. As you build some serious horsepower, the rear brake becomes critical. It has to work correctly to allow you to compete in Pro ET. When you get Sam's 'matic rear brake working correctly, you'll understand how it changes your bracket racing. You'll be doing it right when you get people questioning your sanity with the rear brake setup that it will need to have. Dual rear racing calipers won't be seen on any dragbike except a big motored Hondamatic. Good luck with the 1100F rods. I looked for a long time, but never could find any at an affordable price. ;)
Offline joe p
« Reply #145 on: April 19, 2013, 06:32:36 AM »
WOW! Nice Drag Bike.
Offline dragracer
  • CB750F Dragbike
« Reply #146 on: April 19, 2013, 07:34:05 AM »
Looking good
  • Moderator
« Reply #147 on: April 19, 2013, 01:14:18 PM »
 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8) 8)  did I say cool ?  ;D ;D ;D ;D ;D ;D
    • BentON Racing
« Reply #148 on: April 19, 2013, 04:47:01 PM »
Thanks.Frank....we might get the seat and bars right!!!!!! A proper dragbike!! ;) ;D Bill
« Reply #149 on: April 19, 2013, 09:24:57 PM »
Very cool chassis
