Author Topic: Tool recommendations for degreeing a cam needed  (Read 12182 times)
Offline tweakin
  • tear down
Re: Tool recommendations for degreeing a cam needed
« Reply #25 on: March 23, 2013, 05:43:44 AM »
B-  I have all the tools you need to degree your cam when you are ready.  Just shoot me a text or call.
Offline brandEn
« Reply #26 on: March 23, 2013, 08:22:20 AM »
right on man.
Offline tweakin
  • tear down
« Reply #27 on: March 23, 2013, 08:33:38 AM »
right on man.
I have a the APE degree wheel, so if you want something different you might want to pick a new one up.
Offline Big Jay
    • CBRzone
« Reply #28 on: March 25, 2013, 06:36:03 PM »
Bookmark this site;  http://racetoolz.com/
Offline brandEn
« Reply #29 on: March 25, 2013, 06:52:06 PM »
Thanks Big Jay, That piston stop is going to be a must have i think...
Offline tweakin
  • tear down
« Reply #30 on: March 25, 2013, 06:54:08 PM »
I have that for you to borrow also...
Offline brandEn
« Reply #31 on: March 25, 2013, 07:02:41 PM »
damn dude, is there any tool you don't have? haha. SWEET!
  • Moderator
« Reply #32 on: March 26, 2013, 03:22:20 AM »
just a big one.  ;D ;D ;D ;D ;D ;D ;D sorry Tige.  ::)
Offline tweakin
  • tear down
« Reply #33 on: March 26, 2013, 06:56:48 AM »
That was just too easy Sam... solid comment.
Offline brandEn
« Reply #34 on: March 26, 2013, 07:05:23 AM »
Yup that was a perfect set up!
Offline brandEn
« Reply #35 on: June 24, 2013, 04:38:46 PM »
I was wondering if there is a good way to mark the case and crank on TDC once I find it with a piston stop and wheel? Seems like this would be a good idea and make things more convenient when it comes time to check and set timing. Paint maybe? Scribe? Engraver? Bad idea?
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #36 on: June 24, 2013, 04:47:11 PM »
Branden
I would think you'd wanna mark the crank & case respectively, but there are iddy bits in the way. Having said that, isn't the "T" mark on the advance the TDC marker?
Offline brandEn
« Reply #37 on: June 24, 2013, 04:53:44 PM »
Yes, but I was under the impression that was not 100% accurate. Having never done this procedure I just dont know. I just want to make sure and mark it while I am degreeing it with the wheel if its needed....
« Reply #38 on: June 24, 2013, 04:56:19 PM »
When you mount a large wheel you'll see how such a tiny amount of movement can make. It is a bit of work finding true TDC and getting the wheel set but it'll be by far the most accurate approach to mount it when you need it.
Offline brandEn
« Reply #39 on: June 24, 2013, 05:15:22 PM »
Interesting. So marking things isn't worth the hassle then? How far from being accurate have you seen the stock advancers?
« Reply #40 on: June 24, 2013, 05:18:16 PM »
They are pretty close Branden.....certainly close enough for timing (ignition) purposes.
Offline brandEn
« Reply #41 on: June 24, 2013, 05:20:04 PM »
Thanks Mike, I just want to be sure and have everything right my first time with this procedure.
« Reply #42 on: June 24, 2013, 05:23:41 PM »
Plus you can always play around with ignition timing after its set up. Can't do that with cam timing.
Check your PMs.
« Reply #43 on: June 24, 2013, 06:28:00 PM »
Sorry brandEn, didn't read your post well, missed the ignition part of the question. I have to mount a wheel to check ignition timing with the Suzuki ignition on my 550 and it's a nuissance. I made some tiny chisel marks to go by and it saves a ton of time.
« Last Edit: June 24, 2013, 06:29:50 PM by bwaller »
Offline brandEn
« Reply #44 on: June 24, 2013, 06:37:35 PM »
thanks for the chisel idea!
« Reply #45 on: July 03, 2013, 03:23:57 AM »
See my timing experience here:  http://forums.sohc4.net/index.php?topic=120425.0
Check and recheck again to remove your own mistakes... same result several times after each other - probably correct.
The lash in the entire valve train will cause lower lift than expected.
I understood why some professional guys here set the timing with the lash used. Then going for a good lobe center which will determine when the inlet will open and the out ex will follow.
« Reply #46 on: July 03, 2013, 04:58:19 AM »
Absolutely. ;)
Offline brandEn
« Reply #47 on: July 03, 2013, 05:17:45 AM »
That's a great post and thanks for pointing me to it.
You should check out my K4 build thread. I am at the point of timing my cam now.
