Author Topic: Tews' 605 build, On the road! 5/4!  (Read 92290 times)
Offline Godffery
  • Godffery's Garage
Re: Tews' build Benelli tank mounted 7/11
« Reply #125 on: July 13, 2013, 12:34:32 PM »
Come on Godffrey, that can't be right...it doesn't credit Carpy's dad for his inventing the Cafe Racer. Next you are going to tell us Al Gore didn't invent the internet.
(Sorry, couldn't resist...haven't looked at the link...just figured it was truthful and not propaganda...)
Ha, Don't get me started on Carpy!
Offline RustyOlive
  • rustyolive.com
« Reply #126 on: July 19, 2013, 09:23:28 AM »
Looking great man!!
Offline Tews19
  • I am no
« Reply #127 on: July 22, 2013, 02:02:42 PM »
2013 dyna hub is in... mounted it but will need new bearings as one side is missing.... also the hayabusa rotora are not direct bolt ons as stated on anither website and build thread.... ehhhhh.... still looking for a rim..... should I go with the stock hond  rim or continue looking for a harley 19x 2.5?
I also pulled the engine from the frame.... This engine ia filthy. ..
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
1970 Honda CB750 survivor.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #128 on: July 22, 2013, 02:19:04 PM »
For all the excellent work you're putting into it, I'd get an aluminum rim.
Akront, DID, Excel all make awesome hoops.
Offline Tews19
  • I am no
« Reply #129 on: July 22, 2013, 03:18:57 PM »
I had to see the stance off the center stand... Big props to Harisuluv! I had to file the inside of the frame but his hoop fits perfect!. I like the angle and the lay of it......
Tomorrow I am going hunting for foam to mock up a seat..... any recommendations of foam and where to get?
Offline Bankerdanny
  • Endeavor to persevere
« Reply #130 on: July 22, 2013, 03:33:21 PM »
Nick,
can you confirm the size of the two bolts that attach the electrical panel to the frame? I am going to use the harness that came with my basket case F, but it only came with the full harness, not the bolts that attached it and the '75 bike didn't have a harness on it.
Offline davidtime
« Reply #131 on: July 22, 2013, 03:36:09 PM »
What shocks are those?
Offline Tews19
  • I am no
« Reply #132 on: July 22, 2013, 03:49:35 PM »
Stock 550F shocks... the bolts are 10mm Danny
Offline Bankerdanny
Re: Tews' build hoop mounted/engine removed 7/22
« Reply #133 on: July 22, 2013, 06:01:01 PM »
Thanks Nick
« Reply #134 on: July 22, 2013, 06:18:51 PM »
Looks real good, Tews.  Get foam at a commercial upholstery supply such as this one below. Call em, ask em if they carry high density foam, you don't need much. Get a yard of marine vinyl while you're there for a cover.
http://www.duboisfabrics.com/category_s/6.htm
Offline Tews19
  • I am no
« Reply #135 on: July 22, 2013, 06:38:13 PM »
Thanks Stev-o.... just ordered a complete dyna wheel.... I got the 2013 hub into today but will need spokes and a rim plus new bearings and sleeve..... now time to sell the hub...
Here is another pic of the stance w my oldest on it.
« Reply #136 on: July 22, 2013, 08:46:52 PM »
Left front side of stator cover is not just dirty, that looks pitting from oxidation, that would require some time with several sandpaper grits to level and return it to a smooth surface. Then you could paint or polish or powder coat it...
Sounds like you need a better/more accurate build thread to follow for the GSXR? forks...
Offline Tews19
  • I am no
« Reply #137 on: July 22, 2013, 08:57:27 PM »
Hey Rafster
The engine doesn't have any oxidation... Its been spray painted... The outside carb bodies were sprayed, the frame has spray paint.. Even the manifold boots to the carbs have spray paint.
I think I fixed the title...Is that what you meant?
Offline Elan
    • Vital Motor Parts
Re: Tews' build GSXR front end, engine removed 7/22
« Reply #138 on: July 22, 2013, 09:32:34 PM »
Hey I have a new set of bearings for that harley hub if interested. I bought em for my conversion but didnt bother changing them. cheap ;D
76 750k
Offline Godffery
  • Godffery's Garage
« Reply #139 on: July 22, 2013, 10:35:57 PM »
As for Rim selection;
Very much recommend 18" Front & rear, it will give you a wider verity of tire choices & better handling.
And I'll second that suggestion about going with aluminum!
Offline Tews19
  • I am no
Re: Tews' build GSXR front end, PARTS AND SEAT MOCK UP 8/16
« Reply #140 on: August 16, 2013, 11:26:38 AM »
This build continues at a snails pace.... I am taking my time, gathering parts and attempting to do it properly..... I waited for the seat.. I needed it to get an idea if I was able to use the stock frame for the rear.... Not looking like it....
I had my first attempt at cutting and shaping the seat.... Seat came from Roc City Café.... Great work.. Much better quality then the one I got from DCC....
Who would have thought cutting and shaping fiberglass would be itchy as #$%*..... :o :o :o...
The entire frame will be cut off and redone soon... Now I need to find a local welder who is willing to help do it and make it safe...
I want to go with the mono shock but after seeing the mock up I am not sure... I "faked" mono shock with a stock rear shock... EHHHHHH.....
I do however want to run a disk rear wheel.  I am curious if a stock 750 F spoked single disk wheel would would... I do not know why it wouldn't......
I did kinda mock up the rear sets from an 06 R6... I have all the components to run a rear disk wheel minus the wheel.....
I know it's ugly right now and now to spec but here are a few mock ups....
Offline Tews19
  • I am no
« Reply #141 on: August 16, 2013, 11:28:26 AM »
Pics....
Offline Tews19
  • I am no
« Reply #142 on: August 16, 2013, 11:29:48 AM »
The seat looks to big in comparison to the tank height.... Once the rear is reframed it will sit lower and line up with the tank better....
Can someone please tell me the size of pipe the frame uses and what is the best to use?
Offline KennyRedman
  • 1976 CB550F, Indiana
« Reply #143 on: August 16, 2013, 01:10:59 PM »
very cool, man.
Offline Godffery
  • Godffery's Garage
« Reply #144 on: August 16, 2013, 04:50:24 PM »
I have an 04-05 GSXR Tail Light that may look better in there:
Offline Tews19
  • I am no
« Reply #145 on: August 16, 2013, 05:17:19 PM »
It does look really good. Prolly will fit better too but this taillight has the turn signals as part of the taillight...
http://www.youtube.com/watch?feature=player_embedded&v=_2xnoZ35vsA#at=11
Offline Godffery
  • Godffery's Garage
« Reply #146 on: August 16, 2013, 06:44:24 PM »
Well now, if you want to get all fancy then, yah... go with that.  8 D
Offline Tews19
  • I am no
« Reply #147 on: August 16, 2013, 06:55:50 PM »
PM coming Godffrey
Offline davidtime
« Reply #148 on: August 16, 2013, 08:27:35 PM »
I see you went for the same seat as I did after all. Godffrey is right though it is a big back tail section.
Offline Tews19
  • I am no
« Reply #149 on: August 16, 2013, 08:42:54 PM »
I think the tail won't look as big as now once the rear frame is cut off and new rails are welded to the frame for the lower stance.
I do have a problem with the seat though... For some reason it is shorter then I thought.
