Author Topic: and so it begins, cb550k under the knife  (Read 44826 times)
Offline Riceman
Re: and so it begins, cb550k under the knife
« Reply #75 on: March 17, 2015, 09:07:34 AM »
First I've seen this post,enjoyed reading through it!
Offline DMcD
« Reply #76 on: March 17, 2015, 03:16:33 PM »
Any particular reason to form them at a 90 degree angle?
« Reply #77 on: March 17, 2015, 05:14:28 PM »
There you go!  Cal does raise a good question regarding the dissimilar metals.  Why not use the stock tubes or a steel bracket?
Offline Riceman
« Reply #78 on: March 17, 2015, 07:43:46 PM »
Aren't all rear sets bolted on?
Offline DMcD
« Reply #79 on: March 18, 2015, 12:08:46 AM »
Yes, I just intend boring some holes in steel, plate which will be welded to the frame, and the aluminium then bolted to it.
The passenger pegs would have done the job ok, but I just fancied making them from aluminium.
« Reply #80 on: March 18, 2015, 03:07:32 PM »
Have you ridden round for long with your feet on the rear pegs...?  Not very comfortable at all....
Offline DMcD
« Reply #81 on: March 19, 2015, 12:08:05 AM »
You are right, I will be going a little less extreme than the passenger pegs.  Considering trying to have some adjustment in the plates, if I can work out the hole geometry, gear linkage, brake cable mounting etc.
« Reply #82 on: March 19, 2015, 04:42:45 AM »
I agree with RR on this. Just for some perspective here is the rear set placement on my racebike. Maybe I'm not so flexible anymore but these are not comfortable for very long!  ;D
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #83 on: March 19, 2015, 03:44:28 PM »
Here's the approach I took.
9 way adjustable plates bolted to the frame via engine & swingarm bolts.
Rear-sets can then be bolted acordingly.
Offline DMcD
« Reply #84 on: April 22, 2015, 02:45:47 PM »
Been busy doing other stuff, (including a week on the Isle of Man with my BSA) but finally got a bit of time on work on the rear sets, just going slowly using hand tools.  Lots more metal to remove, but i like the holes.
Offline DMcD
« Reply #85 on: May 27, 2015, 03:19:34 PM »
Haven't got much done recently, working on other bikes, but mounted one of the foot rest hangers tonight.  I can remove more metal from the bracket and hangers if they look a bit too heavy duty.  Not really liking them at the minute, but I'll see how they fit in as the  build continues.
« Reply #86 on: May 27, 2015, 04:20:33 PM »
The brackets look a little clunky, but will likely do the job.
Offline DMcD
« Reply #87 on: July 06, 2015, 03:04:26 PM »
Got a little bit of inspiration today when I scored a cb650 cam off US ebay.  My budget is a bit tight but I can justify the rebore now for the Chinese pistons, and will keep saving for the cr29s and ignition goodies.
Advice from this site would be to leave the bottom end alone if it doesn't need touched, but I have a question, what is the best way to clean up the cases for painting if you are not doing a strip down?  I presume it is better to do the cleaning before taking the head and barrels off to keep the crap out of the bottom end?
That is horrible, cracked silver paint.
The chain guard was broken, but I was able to fix it with the tig.  You just need to remember to hold your breath when welding galvanised ;-)
Offline DMcD
« Reply #88 on: July 21, 2015, 02:21:56 PM »
Yippee!
650 cam Looks to be in good condition.
« Reply #89 on: July 21, 2015, 03:23:09 PM »
It's funny.  CB650 cams are getting scarce on ebay, but you can still buy an entire 650 or 650 parts bike relatively cheaply and part it out if necessary.  I'd rather not sacrifice an entire bike for a cam, so I just took the whole stinking cb650 motor to drop into my 550 frame and I'm keeping the titled fugly '82 frame in case I want if for something down the road.
Offline DMcD
« Reply #90 on: July 29, 2015, 02:33:16 PM »
Finally started into the engine.  What I thought was a clean bike, has had previous surgery.  Several stripped threads so far, and many odd fasteners.
Had enough for tonight, bit apprehensive about what lies ahead.  The bike was only showing 20k miles, so not sure why someone had the head off already.
Offline DMcD
« Reply #91 on: August 03, 2015, 03:24:53 PM »
The head would not come off the barrels due to the front centre bolt, which seems exposed to all the elements, and had seized.  It sheared off, but they would still not come apart, so I had to cut it with a dremmel, and then try to get the two halves of the bolt out.
This did not go well.  Ended up drilling it out, and making a big enough hole to fill with the tig.  Alloy soaked in oil for 40 years does not weld nicely!  Anyhow, I hopefully got enough new metal in there to take a thread insert.
I don't see this bolt as being critical anyway as it seems to be a bit crappy that it tightens onto the fins?
Can someone confirm these bolts are metric fine before I start re-threading thanks?
Offline DMcD
« Reply #92 on: August 04, 2015, 08:00:54 AM »
Left the barrels in for the cruzinimage rebore, and they asked me about piston clearance.  Research shows 0.002" let me know if this is wrong, as they won't do the work until next week.
Offline DMcD
« Reply #93 on: August 06, 2015, 11:28:05 PM »
Repaired another botch on the head last night.  Starting to think that Frankenstein has done a bit of work on this head in the past :o
Cut
Filled
Filed
« Reply #94 on: August 06, 2015, 11:47:16 PM »
I thought my 650 head had some issues.
« Reply #95 on: August 07, 2015, 05:37:20 PM »
I thought my head has some issues.
There I fixed that for you.... just kidding, I think it's more descriptive of myself of late.
Offline DMcD
« Reply #96 on: August 08, 2015, 09:19:49 AM »
Well that turned out better than expected, (head in dishwasher!)
« Last Edit: August 08, 2015, 10:24:43 AM by DMcD »
« Reply #97 on: August 08, 2015, 03:32:09 PM »
Just a water wash right, detergent soap for dishwasher would likely be caustic to the aluminum causing oxidation where it doesn't have anything protecting the bare metal.
Looks kind of dull matt grey in areas like aluminum exposed to lye.
Offline DMcD
« Reply #98 on: August 14, 2015, 07:30:49 AM »
Picked up the barrels today 605cc rebore for £120 (approx. $180).  Said they did the 3mm in 4 passes, as they couldn't clamp it down as nice as they would have liked for more aggressive cuts.
They didn't seem too concerned about how thin the remaining liner was.
Offline DMcD
« Reply #99 on: August 14, 2015, 08:05:06 AM »
Hmm you could be right, I put in about 1/4 the usual amount of detergent, as I wanted to degrease the aluminium for painting, maybe that was a mistake?  I don't know, but it is definitely clean.
