Author Topic: 72 cb750 Project,GSXR front end- Version 2.0 coming  (Read 57143 times)
Offline jojo
Re: 72 cb750 Engine Rebuild/ GSXR Front End-- Wheels are done!!
« Reply #175 on: March 04, 2014, 08:17:00 PM »
Finally some progress.
fabricated a new seat pan since that abs plastic stuff is too soft. I used rivets to attach it to the seat. Then i used threaded pop rivets to mount them to the frame using studs and butterfly nuts. fits like a charm
Uploaded with ImageShack.com
Jojo,
I know this was further back in your thread, but I was interested in the mods to your DCC seat.  Is the base of the seat made out of ABS plastic vs. metal?  Did you remove the seat base before attaching an aluminum pan?
I'm curious as I was thinking of using the DCC seat for an upcoming 550 project.  It's between the DCC seat, a fiberglass Carpy seat, or a bratstyle flat seat with a removable cowl hump.
Don
THe base is made out of abs plastic. I originally tried to install the pop rivets in the plastic but jt was way too soft and gave in when I tried to install it. I used the aluminum sheet to add rigidity to the seat pan, after I riveted the pan to the plastic it was much sturdier and easy to adjust. The pop rivet tool was 50 bucks plus another 10 for the actual rivets so its not a bad investment. I used wing nuts to fasten the seats to the frame and its super easy to remove and has height adjustability as well. Its very rudimentary but it works. Ill post some more pics for ya
Offline jojo
Re: 72 cb750 Project,GSXR front end- brakes done, tail light wiring issue?
« Reply #176 on: March 04, 2014, 08:30:11 PM »
question for the wiring guys? I used the original GSXR controls and spliced them to my Honda harness. Now, I don't have high or low beam and tail light does not work unless I hit the brake lever.  :-\ :'( :( >:(
Offline CognitoMoto
  • Cognito Moto
    • CognitoMoto
« Reply #177 on: March 04, 2014, 10:19:18 PM »
Just have to chase wires. Sounds like the high beam is getting its power signal through brake switch. Start at the hand control high beam wire.
www.CognitoMoto.com
www.CognitoMoto.com
GSX-R Fork Conversions/Laced Hubs and Cafe Racer Parts
www.facebook.com/cognitomoto
Offline jojo
Re: 72 cb750 Project,GSXR Front end--carb questions please help
« Reply #178 on: March 05, 2014, 09:20:05 AM »
I got my 550 pipe from Lossa Engineering.
do you have any sound clips of it?
im debating between that one and the carpy system
« Reply #179 on: March 05, 2014, 12:18:26 PM »
Jojo,
I'll see if I can make you clip of it this weekend.  I just had to replace the sump gasket (leaking) and I'm swapping out the old control switches for the NOS ones I took off my 750K7.  I'll have it ready for riding this weekend.
The Lossa pipe looks fairly identical to the Carpy pipe.  It's a one-piece design and does not have the spring tension mounts to the head (as distinguished from the MotoGP Werks pipe).  Fitment was superb and it came with a mounting tab to the passenger peg.  I believe that Carpy's pipe hangs free from the head, unless you fabricate a mounting tab.  Just my $0.02 but I think this is a key difference.
I got mine ceramic coated black.  Both the Lossa pipes and Carpy pipes are priced the same for bare stainless -- $350.  I do not know who is making Carpy's pipes anymore.  He used to use Power Pros Exhaust, but I think they are no longer operating, and that MotoGP Werks bought their jigs/tooling.
I think that the MotoGP Werks design is inherently superior, since you can replace the tail section if it becomes damaged, and it provides for easier removal with the springs.  That said, I think the Lossa pipe is a great product and value.
Don
Offline sethdhawkins
« Reply #180 on: March 07, 2014, 06:53:31 PM »
I'll say, that I would not buy another Carpy pipe. The fit was/is horrific. Spend a few more bucks for something better.
All a man needs in this world is someone to love, if you can't give him that, give him hope, if you can't give him hope...just give him something to do!
1972-ish CB750K
1974 CB450
1974 CB360
1976 136' Ocean Going Tug
Offline jojo
« Reply #181 on: March 11, 2014, 01:38:25 PM »
Jojo,
Don
Thanks for the input guys. I think what im going to do is have a local exhaust guy fab up the second half of my exhaust to match that yoshimura look/sound and then have him ceramic coat the whole thing. I currently have 4 to 1 pipes that came with the bike when i bought it. It sounds nice but its  quieter than I would like it to be. from what I have read not to many people are overly excited about carpy's so I will stay with my current pipes just a bit modded.
they do a lot of custom exhausts and work mostly with older bikes.
http://www.jemcoexhaust.com/
« Reply #182 on: March 11, 2014, 01:46:46 PM »
Jojo,
Don
Just to clarify, the Lossa pipe is not the same as Carpy's.  Same basic design but I believe Lossa uses a different supplier/manufacturer.
Offline jojo
« Reply #183 on: March 11, 2014, 03:21:55 PM »
got it. I like the bikes they have built for cafe racer tv.
on another note, hopefully i will be able to update the thread tonight. got my mirrors, plate holder , alternate tail light installed. also managed to fix the relay issue. have some pics to go with it
Offline PGF550F
« Reply #184 on: March 15, 2014, 01:06:53 PM »
Hey jojo, have you figured out what change in trail that the modern forks with less offset will give you? I would be interested to hear any comparison you have over stock if you have ridden it much to compare.  Your build certainly has inspired me to look into something like this for my 550.  :D
Offline jojo
« Reply #185 on: March 17, 2014, 11:44:53 AM »
I havent....yet. Im actually going visit a shop to have them give me the full detail and have it setup for me because I want to have it dialed it and ready to go as soon as the weather clears up.  Right now im waiting for a new clutch cover gasket as i managed to ruin the last one when i was changing out the springs.
02z06dave
Re: 72 cb750 Project,GSXR front end- light at the end of the tunnel
« Reply #186 on: March 18, 2014, 07:01:23 PM »
Where did you get the rod for the rear brake?  Ive been looking for something like that for mine.
Your bike looks awesome! Nice work
Offline jojo
« Reply #187 on: March 19, 2014, 09:05:19 AM »
Thank you sir, glad you like it def means alot.
I actually picked up the rod linkage for the rear from Motobits.com--- super helpful, great customer service and even better prices. Give them a shout and they will hook you up.
Offline Calumjs
« Reply #188 on: March 19, 2014, 09:17:39 PM »
Sorry to ask a stupid question, why is there a need for using a different hub for the front wheel? Is it because the front wheel of the gsxr is a different size than the stock front wheel?
« Reply #189 on: March 19, 2014, 10:05:41 PM »
The stock CB750 hub is narrower than the GSXR hub.  To use the stock hub, you would need to machine spacers to place between the hub and brake discs, so that the discs are properly aligned for the spacing of the calipers provided by the mount points on the GSXR forks.  The hub provides for the correct amount of spacing to simply bolt on the discs to be properly aligned for the calipers while retaining a spoked wheel.  Then all you have to do is lace up the hub.  Plug and play.
« Reply #190 on: March 20, 2014, 03:01:58 AM »
I wonder if i could use that front hub , with different bearings, on a 1989 GSXR1100K front end...?
« Reply #191 on: March 20, 2014, 03:08:54 AM »
If you go to Devin's website, there are some cad drawings and specified years. You could ask him for some additional measurements (I'd take some for you, but mine is laced now).
1972-ish CB750K
1974 CB450
1974 CB360
« Reply #192 on: March 20, 2014, 01:28:54 PM »
I have the hub also for an upcoming build. The axle shaft thru the hub is enormous and different bearings are definitely an option for different fitment. Obviously, the width and rotor spacing is fixed and will determine your fitment compatibility.
Looking at the hub theres plenty of scope to remove some material or make spacers up to make the discs line up with my front ends, or measure my 1100 front wheel and give the dimensions to cognito and have him machine  them to suit..  I need at least 2 front hubs, maybe 3...
Offline jojo
« Reply #193 on: March 21, 2014, 08:18:09 AM »
no such thing as a stupid question. i asked myself the exact same thing when i started figuring out all the parts for my build. hopefully everyone was able to help with your questions.
glad to see more helpful discussion on the thread :) :D
Offline jojo
« Reply #194 on: March 25, 2014, 03:01:08 PM »
So I have been trying to fine tune the last bit of details before I can take her out for a long trip and today I that the reason my clutch cover was leaking was not a bad gasket but instead it was  a warped cover. I tried it without gasket cinch and it sucked it right in.  then used gasket cinch and it still wouldnt sit flat so now i have to source a clutch cover.
Any one have a spare one sitting around that they would be willing to sell?
Offline edwardmorris
  • Youngish
« Reply #195 on: March 25, 2014, 05:20:31 PM »
Try PMing Bill Benton, he may have one...
Offline iron_worker
Re: 72 cb750 Project,GSXR front end- Oil leak, Warped Clutch cover
« Reply #196 on: March 26, 2014, 09:17:23 AM »
You could try lapping it flat ... use some contact cement or something to glue some sandpaper down to a pane of glass (or a very flat surface ... granite surface plate would be best but not everyone has one). Drag the cover over the sandpaper (maybe 320 grit?) and keep checking ... the high spots will be easily spotted after a few strokes and the low spots will be untouched.
This method only works if your case gasket surface is not also somehow warped ... but I doubt that.
IW
Offline jojo
« Reply #197 on: March 27, 2014, 02:04:47 PM »
Well if its not one thing its another. I managed to get the cover to seal completely. Now that the carbs have been synced im sputtering through the mid revs but only while its riding, not if its in neutral. Gonna double check my wires to make sure they are getting spark, plugs, and jets to make sure nothing is out of the ordinary?
any other suggestions on what might be making it sputter all of a sudden?
Offline CognitoMoto
  • Cognito Moto
    • CognitoMoto
« Reply #198 on: March 27, 2014, 02:45:31 PM »
As you've undoubtedly seen from numerous posts, Devin is an extremely good guy and his hubs (and other parts) are very well-made. I've dealt with him a fair bit, and met him a few times. Each time, I've come away from my dealings and interactions with him I've been pleased and impressed.
I do know he has the hubs contracted to him as he does not currently own a CNC mill. His other parts I believe he's moving in-house, especially now that his shop is up and running.
Best of luck on your hubs-
I follow this build and saw all this. Sorry for the late reply. We are working on 4 different hubs now. CBR600/ 2003 GSXR / 93 GSXR / CBR1000. These seam to be popular request so we have pursued them. We can make a hub for any application. All I really need is the oem wheel to pull dimensions from.
Cal, the family business is machining and we own a full blown machine shop with CNC and all. We manufacture everything we can in house. The machine shop is in actually located in Richmond.
www.CognitoMoto.com
www.CognitoMoto.com
Offline iron_worker
« Reply #199 on: March 28, 2014, 08:34:28 AM »
If it's only sputtering in mid range I would suspect air:fuel issue as opposed to electrical. Electrical would usually either be a problem all the time or it would come on randomly/intermittently.
Is it idling better after the sync?
IW
