Author Topic: "The Basement Build!" 1973 Cb350F  (Read 64848 times)
Offline silentsvn
« Reply #275 on: April 04, 2014, 06:58:06 AM »
If you pull the kick starter assembly there is a spring on the inside. If you look in the hole where the assembly slides in there is a pocket at about the 10 o'clock position that the tab on the inner spring slides into.
If you don't get that tab seated you'll have a limp kick starter. No one wants limp kick starter.
« Last Edit: April 04, 2014, 07:00:06 AM by silentsvn »
1973 Honda CB350 Four
2004 BMW GS 1150 Adventure
1967 Honda CL 90
Stuff for Sale
Offline 2strokeTrush
  • Can you get that back together sonny?
Re: "The Basement Build!" 1973 Cb350F
« Reply #276 on: April 04, 2014, 08:43:40 PM »
Found the 10 o'clock tab, The spring is sitting how in that pocket in the pictures, how i assume it would supposed to be, since it would keep some tension on the kickstarted to bring it back up after a downward kick.
If You Aint First Your Last!!
 350F project-http://forums.sohc4.net/index.php?topic=133079.0
500F Project-http://forums.sohc4.net/index.php?topic=135660.0
Offline grcamna2
« Reply #277 on: April 04, 2014, 09:30:32 PM »
Tyler,
Have you tried slipping that kickstart lever onto the splined kickstart shaft while the clutch cover is off just to see if you have any initial tension on the lever?,not that you would try to kick it over but just see if it has tension by moving the lever down an inch or two. That should give you a good indication of spring tension.  :)
75' CB400F/'bunch o' parts'
Offline Nick0
« Reply #278 on: April 07, 2014, 05:51:35 PM »
I don't know if this will help but I was flipping through my manual and found myself on the kick starter page so I thought I'd send it your way. Best of luck
« Last Edit: April 07, 2014, 05:53:08 PM by Nick0 »
« Reply #279 on: April 07, 2014, 07:55:41 PM »
Tyler,
Yep got it working!  Thanks man good idea.
Thanks!  This did help me figure out which way it slides in!
Offline Nick0
« Reply #280 on: April 07, 2014, 08:31:02 PM »
[/quote]
[/quote]
Glad to hear it helped, I just got my 350f running today almost finished with my build
« Reply #281 on: April 08, 2014, 07:50:05 PM »
Just received word my carbs will be done soon, So tomorrow My friends and I will move her out of the Basement and inside where I can reinstall everything and get her ready to rumble.  I will have everything set so all I have to do is throw in the carbs and Hit the Starter.  Things should begin moving pretty quickly from here on out.
Heres just a little teaser, I treated myself throwing on a few things to see how she looks.
« Reply #282 on: April 09, 2014, 09:16:35 PM »
Here ya go guys!  Coming together quite nicely!
Im really liking the progress and I can't wait to get my carbs back and ride her!
« Reply #283 on: April 09, 2014, 09:24:49 PM »
Almost there.
Offline grcamna2
« Reply #284 on: April 09, 2014, 09:43:17 PM »
Nice Work Tyler.
« Reply #285 on: April 10, 2014, 05:35:10 AM »
Looks good, where are the carbies?
Offline sanxa_
« Reply #286 on: April 10, 2014, 07:06:52 AM »
looks good man
'73 Honda cb350f (project)
'78 Kawasaki kz200
« Reply #287 on: April 10, 2014, 07:28:04 PM »
using my Tax Return on them, sent them off to Harisluv and they are coming back better then ever, with a few surprises to!
looks good man
Thanks!
Offline grcamna2
« Reply #288 on: April 10, 2014, 09:37:40 PM »
I envy you with the basement work area !
« Reply #289 on: April 11, 2014, 06:58:57 AM »
The basement was all pictures before the bike with the tires on,  I took it out of the basement with the frame and engine and front end.  Reassembled in a building ( Hall ) next door that my dad owns.  It won't stay there to long though!  I Just have to set points ( still a little confused on that to be honest, and Align the rear tire ) then as soon as the carbs come in we are good to go!  He is doing a few custom touches to them as well!
Offline grcamna2
« Reply #290 on: April 11, 2014, 07:04:04 AM »
Tyler,
How does your service manual explain it? the reason I ask is because some manuals have a little different way.
« Reply #291 on: April 11, 2014, 07:38:42 AM »
Tyler,
If you are referring to the points, basically line up the marks, and set the gap with the screws for each point.
Offline grcamna2
« Reply #292 on: April 11, 2014, 08:54:42 AM »
You don't sound confused at all on how to set points  ;)
« Reply #293 on: April 12, 2014, 09:37:03 PM »
Well, sorta confused I guess.  Tomorrow ill put on the tank pads, battery and pipes all ready for those carbs! Im so excited to ride her!  But I am kinda liking the no exhaust look, defiantly more cafe then the 4into4.  Makes me want to find a decent 4into1 !!
Offline grcamna2
« Reply #294 on: April 13, 2014, 01:29:21 AM »
When I first started adjusting points I Always thought it was strange that the points will fire the cylinders on the instant they 'open'...,huh ? I didn't think that was logical but it's true.  ;)
« Reply #295 on: April 13, 2014, 08:43:48 PM »
Pipes and knee pads on.  Really liking the painted exhaust collars, I think they go well with the rest of the painted parts on the bike. Wasn't sure how I would feel about the tank pads, but I really like them.  Basically set now as soon as the carbs come in!
« Reply #296 on: April 13, 2014, 08:49:07 PM »
Looks good, have side covers?   Any plans for that nasty seat rip?
Offline grcamna2
« Reply #297 on: April 13, 2014, 09:06:08 PM »
Try some thick Sail makers thread and temporarily stitch it up
« Reply #298 on: April 14, 2014, 05:25:31 AM »
Yep I have them, 2 sets actually,  that seat rip really makes me mad,  A ratchet strap broke when it was in my truck and it fell over!  I'm most likely going to stitch it up!
« Reply #299 on: April 16, 2014, 05:02:32 PM »
Wish I had more to update guys, For now i have just been sitting on her, cleaning and thinking of the day my freaking carbs will come in, as there was some sort of delay with shipping them.  Only thing thats bothering me is the oil light is staying on and refuses to go out.  Could this be because the bike sat with no oil for 3 weeks?  Would it go away when I finally start to ride?
