Author Topic: New guy, first build  (Read 62503 times)
Offline P.abrera
Re: New guy, first build
« Reply #25 on: March 20, 2014, 03:52:17 AM »
Cleaned the forks as well to see what im dealing with. Lowers cleaned up ok. Dunno of the legs are salvageable. One is pretty badly chewed up near the fork seal. Will study my options...
Fork covers/headlight bracket looks to be in ok shape, though i probably wont use those. Imagining a more stripped down look for the bike.
Next session ill check the condition of the bushings. God knows what's waiting for me inside those.
Offline iron_worker
« Reply #26 on: March 20, 2014, 08:42:47 AM »
If you can feel any of those markings on the fork tube surface with your finger nail then they likely will tear up new seals in a hurry.
IW
Offline grcamna2
« Reply #27 on: March 20, 2014, 11:48:05 AM »
p.abrera,
What do you have to choose from in used Vintage Honda parts over there? are you near Singapore ?
75' CB400F/'bunch o' parts'
Offline P.abrera
« Reply #28 on: March 20, 2014, 03:36:55 PM »
Yep, these are pretty deep nicks and scratches on the stanchions. Easy pares and salavage yards are just a dream here, so im looking into the possibility of re-chroming. If thats out, guess ill have to pony up for new stsnchions orderedfrom overseas.
@grcmna2 were not far from Sing, maybe a 2-3 hr flight
« Reply #29 on: March 20, 2014, 04:32:13 PM »
I would not recommend used fork tubes.  You can purchase them from a US vendor like Cycle Exchange.  Shipping will be pricey, but you know what you will be getting.
Your fork tubes are toast.  Even if you use new fork seals, the pitting will cut holes in them quickly.
Offline P.abrera
« Reply #30 on: March 20, 2014, 10:39:13 PM »
Totally agree. But for a few more clams i cud chance upon a decent "modern" front end on ebay. Seems like replacement tubes are at least $150.
...of course that means the headache of matching the triples the steerer and the brakes and wheels
« Reply #31 on: March 20, 2014, 10:47:09 PM »
Yes but you'll also get better handling and braking.
Offline P.abrera
« Reply #32 on: March 21, 2014, 12:04:57 AM »
I'll be travelling stateside in october and will see what solution i can take home with me. The hunt and figuring out what will work is half the fun.
« Reply #33 on: March 22, 2014, 01:27:13 PM »
Where in the US?  You should make a list and bring back a case full of parts.
« Reply #34 on: March 22, 2014, 02:10:12 PM »
Depending on where you are visiting, you could buy the parts you need on ebay and have them shipped to a member where you are visiting.  Then you can pick them up and haul them home!
Offline grcamna2
« Reply #35 on: March 22, 2014, 04:26:42 PM »
Just make sure to bring a large suitcase with you  :).
« Reply #36 on: March 22, 2014, 06:14:16 PM »
Definitely!!!   8) 8)
Offline P.abrera
« Reply #37 on: March 23, 2014, 08:23:47 AM »
Gonna need a large suitcase gor sure
Offline P.abrera
« Reply #38 on: March 27, 2014, 02:42:50 AM »
Got curious to see what i was dealing with under the paint of the tank and did a quick strip. A few dings and rust but no holes as far as i can tell. Should do fine after a thorough strip and clear seal.
Offline P.abrera
« Reply #39 on: March 27, 2014, 02:45:39 AM »
Also prepping some aluminum bits for a bit of polish and am wondering if i should straighten this out? I can pass a tip cleaner through it so the passage is actually clear and kink free. Worried i might make it worse if i take a pliers or light hammer to it.
« Reply #40 on: March 27, 2014, 02:54:40 AM »
I would be very careful with that as I have seen them snapped off.  A bit of heat may do the trick.
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #41 on: March 27, 2014, 03:13:47 AM »
Cool thread, subscribed.
Don't care for the instagram style filter on your photos, makes it hard to see and help. Save that retro patina effect for when it's done maybe? My $.02 - everyone else probably loves it.
Bottom of your fork = fork leg
Thinner chrome part of your fork = fork tube
Welcome!
I have a motorcycle problem.
Offline P.abrera
« Reply #42 on: March 27, 2014, 03:38:43 AM »
Good point, these actually off my instagram feed. :-D will save the purdy-fied pics for IG.
Offline P.abrera
« Reply #43 on: March 29, 2014, 09:51:57 PM »
After a bit of frame cleaning i discovered im gonna have to cut out some rot and a crappy repair from before and weld in a clean gusset for the swingarm pivot/bushings. Argh!
« Reply #44 on: March 30, 2014, 07:57:43 AM »
Sorry to hear, that is an ugly "repair".
Offline P.abrera
« Reply #45 on: March 31, 2014, 05:04:32 AM »
You said it :-( Was hard to spot underneath all the crud that was on the frame when i got it. Consulted with a local shop, hes confident it can be repaired strong...it wont look stock though. Shame this wasnt better cared for.
Offline rb550four
« Reply #46 on: March 31, 2014, 02:49:59 PM »
Wow ,that's a nasty frame. What's the rest of it look like? Is the other parts of that frame thinned out by rust too?
  I'm about to say something that I would never say but here goes, That looks like a good candidate for a hard tail.
  I hope your welder is really, really good . I wouldn't even consider  repairing  that . tricky spot.
                                           Truth time,
I don't want to be the pooper at this party but, I think it's time to split the engine down to find out if there is anything in it that is salvageable in there before you waste too much time and effort on something that  may not be able to be repaired. If you open up the clutch side and every thing is white powder , and the primary drive bearing looks wasted.....like this
 It's most likely wasted.
  If you open top end and the cam and springs looks wasted.....you know
Please ,do yourself a favor , take the engine apart and take plenty of pictures of everything and get opinions here if it's repairable. At least you can get an Idea of what will have to be done, then you can decide if it's a project that you will be able to tackle and complete.
« Last Edit: March 31, 2014, 05:10:53 PM by rb550four »
Offline grcamna2
« Reply #47 on: March 31, 2014, 05:48:28 PM »
Keep up the Good Work P.abrera  :).
Offline P.abrera
« Reply #48 on: March 31, 2014, 06:36:28 PM »
@rb55four i share your concerns,  frames pretty solid everywhere else. Ill see how it goes.
Due to crack open the engine once i get it washed and cleaned.
Offline P.abrera
« Reply #49 on: May 17, 2014, 11:49:34 PM »
Slow progress. Nothin much to add for now other than makin some bits shiny and getting the engine washed and on a stand. Waiting on some parts to come in for rebuilding the carbs as well as the top end gasket kit and rings.
