Author Topic: 1970 CB750 K0... My first bike  (Read 14133 times)
Offline cmoses
Re: 1970 CB750 K0... My first bike
« Reply #50 on: April 20, 2014, 02:53:12 PM »
Nice Steve-o!  I havent had time to work on it until today... I will try that set up with the strap and angle iron.  I have read the bearing thread.... talk about LONG haha.  It helped out a bunch.  Just getting to stripping the front end all the way down.... had everything off of the bars already so hopefully ths is easy.... will keep you all posted.
1970 CB750 K0 - Sold
1975 CB550 Super Sport
My 1970 CB750 K0 project
Offline cmoses
« Reply #51 on: August 16, 2014, 05:15:29 PM »
Well its been a long 4 months but im back! I have the tapered bearing in and the new tree installed. Still havent had any luck with the D washers for the new tree and was hoping someone could point me in the right direction? Also really having trouble getting the wiring hooked back right. Any help would be appreciated. I am getting ready to oreder what ihope is the last haul of parts before this thing is on the road... finally.
« Reply #52 on: August 16, 2014, 05:33:54 PM »
The D spacers are discontinued so this seller is taking advantage of it....
http://www.ebay.com/itm/Honda-CB350-350G-G-Spacer-Washer-Kit-Top-Fork-Bridge-Triple-Tree-53235-300-000-/400619960276
« Reply #53 on: August 16, 2014, 05:52:25 PM »
« Reply #54 on: August 16, 2014, 06:43:30 PM »
Just make your own by grinding an edge into a washer. Not difficult.
True, I have done it. Trick is getting the correct thickness, the spacer is thicker than a standard washer.  I believe the cylinder head washer is the correct thickness.
Offline cmoses
« Reply #55 on: August 19, 2014, 09:03:16 AM »
Yeah I read that the thicknes should be .09 and the cylinder head washer is at .093 so it just needs filed down a bit. Ill check ebay for them. Wish there was a honda store around! Any suggestions on a good wiring diagram? Like a smart guy I didnt take any pictures of the wires and want to make sure I hook everything up right.
Offline Johnie
« Reply #56 on: August 19, 2014, 02:23:59 PM »
If you have the OEM wiring harness in there just connect color to color. Plug and play :) Everything that goes into the headlight bucket gets connected to the main harness which also comes into the bucket. Be sure to check for corrosion and some guys put dielectric grease on the bullets too.
« Last Edit: August 19, 2014, 02:28:38 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Phoenix
  • 4 wheels move the body. 2 wheels move the soul
« Reply #57 on: August 19, 2014, 03:23:58 PM »
Unless I'm mistaken, on a 71, the front turn signals have green and black pigtails.  The greens hook up to greens but the blacks hook up to light blue for right and orange for left.  Again, this is a 71,don't know about a 70.  fwiw, this is coming from someone that's colorblind
Ed Spengeman
Indy
1971 CB750K1 (Stock)
1973 CB350 Twin  (Gone)
Offline 01Thomas
« Reply #58 on: August 20, 2014, 09:31:06 AM »
That's correct, but those indicator pigtails have a short colour-coded band (featuring the correct light blue & orange colour) over them close to the bullet connectors.
regards
Thomas
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
Offline Johnie
« Reply #59 on: August 20, 2014, 04:43:32 PM »
Correct sir...you can see the bands on the pic above.
Oshkosh, WI  USA
Offline cmoses
« Reply #60 on: August 21, 2014, 08:51:17 AM »
Great. The p.o. has done some hacking in here. My turn signal wires are grey and some colors arent on the harness. Mine looks like a total mess compared to yours. Also is my bike a "sandcast".  I will post pictures asap of the bike.
« Reply #61 on: August 21, 2014, 11:39:09 AM »
I have a thread in Tricks and Tips about this. Yes its the CB750 cyl head washer (maybe others) that is the correct thickness. I'll get a link. Strongly suggest you not using a standard washer as I've seen the tree crack with them as well.
http://forums.sohc4.net/index.php?topic=72765.0
« Last Edit: August 21, 2014, 05:35:15 PM by MCRider »
« Reply #62 on: August 21, 2014, 05:32:00 PM »
What is your engine number? If under 7414, then yes.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #63 on: August 24, 2014, 03:49:33 PM »
He's about 30,000 too late ;)
Here is the motor
Offline cmoses
« Reply #64 on: August 25, 2014, 09:07:08 AM »
Thanks! Everyone always asks me and I could never answer them. Will hopefully have time to play with the bike these next couple weeks. Would like to put it on the road this fall. As of now electric start doesnt work. Looks like the wires that run through the bars are disconnected from the bottom half of the controls where the button is. REALLY short.
Offline Tews19
  • I am no
« Reply #65 on: August 28, 2014, 06:24:30 PM »
Cmoses. I have a k1 control. If you want I will look in my stash and it's yours for free. Pay the shipping and we good. Pm me if you want it.
1970 Honda CB750 survivor.
