Author Topic: 1972 CB750K2 (start from scratch) project. Cases back together  (Read 121143 times)
Offline Davez134
Re: 1972 CB750K2 (start from scratch) project.
« Reply #500 on: October 26, 2016, 06:25:31 PM »
Very impressed, what a beautiful bike. Just showed the pictures to my wife and said I'd like to something like that someday. She said it looked great and if that's what I wanted to do go ahead. That's my opening and now I'm on the hunt. I still have some things to finish on my '72 750.
Once again nice job on the bike and the write up.
Thanks for the kind words! Glad I can give some inspiration, and facilitate the go-ahead from the boss
Offline Davez134
« Reply #501 on: January 12, 2017, 05:49:31 PM »
So I'm getting some things done this winter while it's cold out. First of all, I was leaking oil past a couple valve seals. I replaced The seals, but the leak came back. Most likely because the bronze guides are worn. They are being replaced with cast iron guides, valve job, new seals. Second, against my better judgement, I am splitting the cases to replace the crankshaft seal in the points side that I put in backwards originally (big oops). Some pics to come soon.
As it sits right now (minus head, which has been sent out)
« Last Edit: January 12, 2017, 05:55:29 PM by Davez134 »
« Reply #502 on: January 12, 2017, 07:15:03 PM »
That motor looks pretty clean.
Offline Davez134
« Reply #503 on: January 12, 2017, 08:19:21 PM »
Yeah, I was pleased to see the cam was well oiled and things were nice and clean. The pistons however were caked with deposits, and oil was even in the valve relief of #1. My head is in good hands now ;) wait that sounded weird.
« Reply #504 on: January 12, 2017, 08:43:54 PM »
I wonder if better gas or detergent gas helps keep deposits at bay.
Offline Davez134
« Reply #505 on: January 12, 2017, 09:13:35 PM »
Or maybe it was from oil leaking down into the chambers? Unfortunately I have nothing to compare it to.
« Reply #506 on: January 13, 2017, 08:42:58 AM »
Hey Davez....did you previously have this motor apart?
Offline Davez134
« Reply #507 on: January 13, 2017, 01:24:51 PM »
Yes, full rebuild.
« Reply #508 on: January 13, 2017, 07:06:55 PM »
Yes, full rebuild.
Twice the fun!  How many miles did you have on it Dave?
Offline Davez134
« Reply #509 on: January 13, 2017, 07:17:19 PM »
Yes, full rebuild.
Almost 6,000.  And everything else looks/checks out fine too. Just the worn valve guides. If I didn't want to replace that crank seal I wouldn't even need to split cases, but might as well. Got new rings, and going to do a quick hone before I set the gaps and re-install. I really didn't want to do all this, but trying to make the best of it.
« Reply #510 on: January 13, 2017, 08:09:50 PM »
It'll be tight and right.
Offline Davez134
« Reply #511 on: January 19, 2017, 08:40:21 PM »
I've regressed. I've got a roller!
Never mind the messy garage!
« Reply #512 on: January 19, 2017, 09:52:51 PM »
Sometimes it's two steps forward, ten steps back.  But it will be worth it.
Offline Davez134
« Reply #513 on: January 22, 2017, 07:31:34 PM »
Made a stupid "OOPS" today. I was splitting the cases to replace the crank seal. I have the engine on my stand, and when I flipped it over my brace that I made to hold the front wasn't locked in place. It slid out as soon as I removed the rod from the back of the lower case holding it to the stand. The top case swung down and I bent two of the Kibblewhite HD studs! Damnit! Thats what I get for not checking my equipment. :( I'll go take a picture when I feel less depressed!
« Last Edit: January 22, 2017, 07:38:42 PM by Davez134 »
Offline rickmoore24
  • Be led by your dreams, not pushed by your problems.
  • I <3 SOHC4's
    • Rosenbard Films
« Reply #514 on: January 22, 2017, 09:33:04 PM »
FUUUUUUUUUUUUUUGGG!!! That's such a bummer.
1972 CB750 K2 (Daily Runner)
1972 CB750 K2 (Sold)
1973 CB750 K3 (Hardtail 836cc)
1998 CBR F3 - R.I.P., went down on the 101 in Calabasas, Ca.
1995 EG6
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #515 on: January 23, 2017, 06:37:23 AM »
Me bending my brake rod removing my rear wheel doesn't seem so bad now.
A minor "D'OH" moment.
--Evan
1975 CB750K "Rhonda"
Offline Davez134
« Reply #516 on: January 23, 2017, 07:51:52 AM »
Yeah, I would at least bend that brake rod back. I'm not even thinking about fixing these, just bucked up and ordered new ones.
Offline edwardmorris
  • Youngish
« Reply #517 on: January 23, 2017, 10:33:00 AM »
Damn dude! Kibbles take some work bending! Oh well, hopefully not too much work for you to get it all back together.
Offline Davez134
« Reply #518 on: January 23, 2017, 07:54:57 PM »
Yeah, that's why I'm just getting new ones. Don't trust those two now after that force. I'm almost ready to mate the cases. Everything is all cleaned up, new Honda seals. I'm just gonna take a break for the night. I'll take a pic of the bent studs after the motor is upright again.
Offline Davez134
« Reply #519 on: January 24, 2017, 12:52:22 PM »
Here is my oops!
But I finally got this seal replaced right
Offline rickmoore24
  • I <3 SOHC4's
    • Rosenbard Films
Re: 1972 CB750K2 (start from scratch) project. Cases back together
« Reply #520 on: January 24, 2017, 01:07:05 PM »
Bent em pretty good! New ones are a good call.   :)
1995 EG6
« Reply #521 on: January 24, 2017, 02:36:44 PM »
Arggghhhh!!!!  :o  Yep, good call on replacing!
Offline BLAC
  • An espresso is a
« Reply #522 on: January 24, 2017, 03:23:50 PM »
Just read through pretty much your whole thread... amazing work.
your leak issues are making me feel a little queasy as I am mid engine build, but there are great bits of into here. Thanks for sharing all of these steps. Ill be checking the direction of my seals VERY carefully.
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
Offline Davez134
« Reply #523 on: January 24, 2017, 04:33:46 PM »
Thanks! Nothing to be queasy about, just learn from my mistakes. Use Honda seals when possible, and put them in correctly haha.
Offline Davez134
« Reply #524 on: January 27, 2017, 11:39:11 AM »
Bent studs? What bent studs?
