Author Topic: Sexy Italian Sister..oh lordy.  (Read 27995 times)
Offline toytuff
  • "watching the pinheads"
Re: Sexy Italin Sister..oh lordy.
« Reply #75 on: January 12, 2015, 04:35:37 AM »
May need a "trim pot" adjustment as seen in last picture. (next to the EPROM)
I would have tried that first: given it's an open-loop system, perhaps they leaned it out to pass emissions, while giving the end user some adjustment range to correct the issue?
You could but how would you know the correct setting? Without a wideband AFR it's just a guess.
The idle trimmer is a little metal square just next to the eprom with a plastic rotating pot inside. This adjusts the idle mixture, working the same as the electronic idle trimmers in the 1.5M and 5.9M ECU. It adds or subtracts a given pulse width from the map fuel number across the whole map, therefore having a much greater percentage effect at small pulse widths.
Back then the manual says to use a gas analyzer for CO% readings. Old school stuff. (picture) Before doing anything to the trim we need to know the fuel map. Given the eprom that's in it we need to check that first or put a factory eprom, which we have. (In the UK)
So, to use the wideband controller we need to weld a bung in the mid pipe, install the Bosch sensor and read the AFR. Once that is done the wideband can be hooked to the data logger recording the AFR thru the entire range to a log file as shown in previous posts.
Any changes to the eprom has to be burned. With a Microtek ECU this can be done via laptop but it comes as a huge cost thus going this route first. Logger and wideband easily sold on forums.
tt
« Last Edit: January 12, 2015, 04:39:33 AM by toytuff »
« Reply #76 on: January 12, 2015, 07:02:44 PM »
With an open loop system it's always a calculated guess. ;) So the stock ECU only has the RPM and TPS for the major inputs? No MAP or MAF sensor?
Offline toytuff
Re: Sexy Italian Sister..oh lordy.
« Reply #77 on: January 13, 2015, 04:40:47 AM »
Remember one thing here. It's Italian! Nothing is normal. Only the Wine!
Oh, we have a sensor for the timing, a IAT sensor, water temp sensor, sensor for the cooling fans, side stand sensor, neutral sensor, blah blah blah.  ;D
This is a print out from a PDF file before buying the books. There are more pages but you get the idea.
tt
Offline toytuff
« Reply #78 on: January 13, 2015, 05:07:41 AM »
Here is my fav!  ::)
tt
« Reply #79 on: January 13, 2015, 05:30:47 AM »
At least it's in English. But may as well be in Italian?
Offline toytuff
« Reply #80 on: January 13, 2015, 05:34:43 AM »
 ;D
Well said. Pass the Wine.
tt
Offline toytuff
Re: Sexy Italians Sister..oh lordy.
« Reply #81 on: January 14, 2015, 04:10:57 AM »
OK, EPROM and logger shipping to the UK. Mid pipe in LA. Carbon Fiber shipping out of Canada.
Where in the heck are the Italians? Should of known.  ::)
tt
« Reply #82 on: January 14, 2015, 03:26:24 PM »
Yes, we are eating pasta and drinking wine, what else?!
« Reply #83 on: January 14, 2015, 03:29:11 PM »
Pizza of course..... ;D
Offline faux fiddy
  • bike in a box
« Reply #84 on: January 15, 2015, 12:59:29 AM »
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline toytuff
« Reply #85 on: January 23, 2015, 11:57:39 AM »
Offline toytuff
« Reply #86 on: January 23, 2015, 12:09:15 PM »
Boy, am I glad this is over! Living in a construction zone since the day after Christmas. Good Lord. The walk in shower is wonderful however. Took a couple of days just to clean up the mess. 26 foot wall on Tuesday but I hired that done.  ;)
With Doctors appointments and such there was no time to work on the Brutale other than a little morning time. Mid pipe comes tomorrow with the bung welded in so I can get the exhaust mounted up on Sunday. The logger has arrived in the UK but that will be another couple of weeks before it returns.
I did manage to get the matte finish CF installed. So much better than the factory plasitic. I had to wait for the matte finish but given the frame is flat black as well as other tid bits on the bike I'm happy with it. Rear hugger, chain guard and front fender air damper. A rear seat cowl is also ordered but 5 weeks out.
Tomorrow is "dedicated Ducati day." A long ride and some coffee stops with friends. Looking forward to it. 70 degree weather makes it all the better.
tt
« Reply #87 on: January 23, 2015, 03:31:42 PM »
Hey Toy -  my wife must of heard you did the bath remodel, now she wants to do ours!
Get a couple pics of the Duc out on the road for us...
Offline toytuff
« Reply #88 on: January 24, 2015, 05:00:51 AM »
I sure don't envy you on that project. Get's expensive when you start upgrading a few things but use porcelain tile. It's a little higher on price. We also went with cigar trim, center tile strip and two corner shelves. Replaced both toilets with comfort height models and new shower doors in both bathrooms. Installed a few handles as we are not getting any younger.  ::)
Hard to take full pictures but you get the idea.
Ducati ride cancelled due to Wind Advisory. Gust to 32 mph already.
tt
Offline toytuff
« Reply #89 on: January 24, 2015, 05:07:30 AM »
Fooled me! I would of swore a lean condition.
I have read the eprom and compared it to the standard one I have – yours is a little richer at the lower end.
Again, I’ll go right through it over the w/e
Would of been nice to see what the wideband AFR read.
tt
« Reply #90 on: January 25, 2015, 08:31:45 AM »
Looks good!   We plan on using Travertine in shower and floor, but haven't picked shape/style yet, this is where we like to get creative (like in our kitchen). I'll install it so we can save some bucks there.
The cabinets are solid oak and in great shape, so just the counter will be replaced there with granite along with new plumbing fixtures.  I do a lot of storefront glass business with a contractor though work, he's offered me a 50% discount on the frameless shower door/enclosure.
Offline toytuff
« Reply #91 on: January 25, 2015, 09:51:22 AM »
Pays to have connections that's for sure. I not only didn't have it in me but way above my talents. Removing a tub, locating a drain that involved concrete work let alone positioning new pipes and fixtures. The hardy board, red coat and 18 inch tile and grout forget it.
Just glad it's done.  ;)
tt
Offline toytuff
« Reply #92 on: January 25, 2015, 10:02:04 AM »
The wind is still howling across the desert. No riding today, rest of the week busy with continuation of Spring cleaning. I'm just beat.
This morning around 0430 hrs. I started on the exhaust. Went together with only a few issues but done now. The stock silencers should be a lot quieter than the full race. My, they were loud.  ::)
A MV forum friend welded in a bung for the O2 sensor and I ran wiring up to the battery area. I went for the right side due to connector size and length of wiring. I used cable guides to avoid the swing arm and exhaust. The left side would of hid the sensor better but due to routing and clearance I opted for right side.
Changes are being done this weekend to the logger and the chip. Will see what Adam comes up with. Still think it was a crap MAP on the eprom.
Onward...
tt
Offline toytuff
« Reply #93 on: January 29, 2015, 03:19:12 PM »
Two (2) eproms ship tomorrow with added data logger functions. Adam changed the timing and fuel on the lower end.
The reason for two identical chips is the fact that more tweaking will be done down the road. We can read the data and pinpoint the changes that might be needed. I can still ride the bike while one is in the mail. Of course removing the fuel tank again.  ::)
I got the wide band programed this morning calibrating the Bosch O2 sensor then changing the lower analog reading to 10 AFR and the upper analog reading to 20 AFR.  It's all wired and hooked up to switched power.
Onward.
tt
I forgot to add that I "finally" found a set of Oberon billet reservoir covers in titanium finish. Wanted to match the handle bars and triple tree.
« Last Edit: January 29, 2015, 03:33:50 PM by toytuff »
Offline toytuff
« Reply #94 on: February 02, 2015, 07:30:26 AM »
I REALLY need to stop looking at these.  :o ( F4/F3)
Does the "I want" ever end? Lordy. The first picture is the Titanium Edition and is for sale.  8)
When I turn 701/2 years young and have to withdraw 29% of my 401K this is not going to be pretty.  ;D
tt
« Reply #95 on: February 02, 2015, 05:02:03 PM »
No... well, maybe when we are dead?
« Reply #96 on: February 03, 2015, 04:36:52 AM »
I have to admit, I am immune to Italian sisters.  Is it good or bad?
« Reply #97 on: February 03, 2015, 05:32:23 AM »
That could be bad, do you have a pulse?
Offline toytuff
« Reply #98 on: February 03, 2015, 06:48:51 AM »
I admit, you're right.
tt
