Author Topic: Cam wear/damage?  (Read 2115 times)
Offline Davez134
Cam wear/damage?
« on: November 10, 2014, 05:00:28 PM »
I got a CB750 cam with some parts I bought, and I was wondering about the edges of these lobes. I have never seen this before, but then again I haven't seen a lot of cams.
The right edges of these lobes are raised up (or middle ground down? Depending how you look at it) with no other unusual looking wear. All 4 on this side of cam are like this, and all 4 on other side are completely smooth. Lift is same as other respective intake/exhaust lobes. Marking on the cam is "R3." Look like damage? Or an area not ground from casting?
Offline BPellerine
Re: Cam wear/damage?
« Reply #1 on: November 10, 2014, 05:19:15 PM »
just looks like area where rocker did not travel,other than that looks okay.bill
1978 CB 750K ard and webers
another anfob
Offline goldarrow
  • one day, i'll be an
« Reply #2 on: November 10, 2014, 05:26:07 PM »
The way I see it that cam is worn
CB550 K0
« Reply #3 on: November 10, 2014, 05:36:53 PM »
get a new one!
« Reply #4 on: November 10, 2014, 06:06:46 PM »
...worn out. That ridge where the rocker didn't ride, should never show. There should never be that much wear to the lobe that that ridge would appear.
« Reply #5 on: November 10, 2014, 06:11:44 PM »
That cam is the poster child for Zinc additive. ;)
« Reply #6 on: November 10, 2014, 06:16:08 PM »
Ha, good one. Probably. I'd suspect some beginning wear on the rockers slap faces should be showing, too.
Offline Davez134
« Reply #7 on: November 10, 2014, 06:53:37 PM »
Thanks guys.
« Reply #8 on: November 11, 2014, 02:56:17 AM »
Cam look bluish too. Running hot?
As said many times.... can be caused by the newer type of oils and/or blocked oil lines.
My old OEM cam that was used 65.000kms look new compared with this one. I did not change oil that often and the quality of the oil (often bubbling foam in the oil tank) was not good either which I noticed when the piston rings fell out in pieces when removing the cylinders 1983.
Offline lrutt
« Reply #9 on: November 11, 2014, 05:57:06 AM »
yup, shot. No doubt running standard new era car oil.
Wonder what the trans looks like :(
Offline Whaleman
« Reply #10 on: November 11, 2014, 05:58:04 AM »
Post pictures of rocker faces. I can't believe they are good. Dan
Offline Old Scrambler
« Reply #11 on: November 11, 2014, 07:42:33 AM »
Dave acquired the cam in a parts-lot.  Hopefully the other parts have some value...........this particular part used to qualify as 'land-fill' material...................but now we just re-cycle them to others.
Good catch, Dave.  I would think the cam-tower and rockers associated with that cam are also worn beyond use.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline goldarrow
« Reply #12 on: November 11, 2014, 08:41:36 AM »
use it as metal art project???
CB550 K0
« Reply #13 on: November 11, 2014, 08:59:35 AM »
I bagged that stuff up for a boat anchor.
Offline Davez134
« Reply #14 on: November 11, 2014, 09:02:09 AM »
Correct, I got this with other parts that I was looking for. No other associated motor parts with this to post pics of. I just wanted to know if it would be of any use in the future, but as I thought its trash. Using a Webcam on my current project.
« Reply #15 on: November 11, 2014, 10:30:43 AM »
You could slide it under the seat of your car for possible protection against road rage.
« Reply #16 on: November 11, 2014, 11:09:47 AM »
I have a 750 kicker under my seat...swing it around by hanging onto the rubber part.. Nasty..
Offline edwardmorris
  • Youngish
« Reply #17 on: November 11, 2014, 12:53:31 PM »
.....I just wanted to know if it would be of any use in the future..........
Can be used as an exchange core for one of the hard weld megacycle cams.
Offline Davez134
« Reply #18 on: November 11, 2014, 01:00:44 PM »
Very good idea. I carry a concealed firearm, but honestly might freak someone out more by swinging a cam around!
Offline dusterdude
« Reply #19 on: November 11, 2014, 02:56:00 PM »
Can it be re-ground?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #20 on: November 11, 2014, 03:04:56 PM »
Re-Grind...........Maybe...........if the journals are good.............but your looking at a few hundred bucks plus shipping............and you can usually buy for less (used or Cycle-X) if you are not looking for max-performance.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
Offline BPellerine
« Reply #21 on: November 11, 2014, 05:22:40 PM »
guess I did not look close enough,or my eyes are failing!haha
another anfob
