Author Topic: 1976 Honda CB750K First Build  (Read 25281 times)
Offline ponishenko3136
    • www.civilcustoms.com
« on: March 26, 2015, 09:48:27 PM »
hey  everyone, I'm new here. 22 years so I'm new to this bike building world even though I've always been fascinated by old machines. this is my 1976 cb750k i just acquired. doesn't look like much but i got plans for it. progress will be slow, when i get money and time to work on it i will but i hope you enjoy my build. and I'm looking forward to hearing tips, advice and critique seeing as how i don't know much. thanks in advance
« Last Edit: March 31, 2015, 11:43:09 AM by ponishenko3136 »
Live To Build Another Day
Re: 1976 Honda CB750K
« Reply #1 on: March 26, 2015, 10:31:21 PM »
Decent roller -- "it looks better than it did."  ;)
Did you get a motor with it??
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #2 on: March 27, 2015, 07:20:39 AM »
Looks like it will be a brat/tracker style? Hope you got an engine too!
--Evan
1975 CB750K "Rhonda"
« Reply #3 on: March 27, 2015, 09:05:21 AM »
Ya I got a motor with it. The previous owent took it out. So i hope it won't be too challenging to put together. And that quote was under a piece of tape I took. I think it looked better though
« Reply #4 on: March 30, 2015, 05:38:48 PM »
so i had some time after work and i decided id go cut some tabs off...got a little carried away and took it all apart. but I'm not complaining. i cut off what i didn't need but i still have some cleaning up to do. didn't have too much trouble with rusted bolts. forks gave me a bit of a fight but got em off. slow progress but it'll get there
Re: 1976 Honda CB750K First Build
« Reply #5 on: April 10, 2015, 06:58:30 AM »
No major progress but i cleaned up all the extra metal after i cut some tabs off. ordering some parts for the mock up before i i get the frame ready for paint.
« Reply #6 on: April 23, 2015, 07:02:13 PM »
got my hoop in today and had some time so i welded it on, and did a little more frame work. some more mock up to do. and then to get it ready for paint. might work on the seat pan too
Offline evanphi
  • Apparently I'm an
« Reply #7 on: April 24, 2015, 05:37:34 AM »
+1 on the frame kit. I did mine for a top-end restore... but when it comes time to remove the engine at some point, it will be a godsend!
--Evan
« Reply #8 on: April 24, 2015, 09:06:36 AM »
Yes. I cannot agree more.
« Reply #9 on: April 27, 2015, 08:25:54 PM »
thanks for all the info and advice. where would be a good place to get a frame kit. and yes I'm waiting until I'm done with everything before paint. i was gonna powder coat but the closest place to me want to much in my opinion. so ill just paint it i think
Offline evanphi
  • Apparently I'm an
« Reply #10 on: April 28, 2015, 04:59:49 AM »
Send a PM to 754 aka Frank.
You can check my build thread for some pics.
--Evan
« Reply #11 on: May 06, 2015, 07:26:00 PM »
made my first seat pan but didn't like how it turned so i gave it another shot. i like this one a bit more than the first. now i need to get it ready for paint and get the seat done. i still need to trim up the edges do a little more work on it but thats the general idea.
Offline evanphi
  • Apparently I'm an
« Reply #12 on: May 07, 2015, 08:32:52 AM »
Good job. I'd like to try this some time.
--Evan
« Reply #13 on: May 07, 2015, 07:15:00 PM »
thank you. its not too hard. I've never worked with fiberglass before so i had to get the hang of it. youtube how to build a cafe racer seat, and its the dime city cycles one. but what i learned as i was doing it, use smaller pieces of cloth. in the video he uses one big piece, thats what i did at first but its a lot harder if you you've never done it before. but ya give it a shot. its another thing i can say i did by myself
Offline evanphi
  • Apparently I'm an
« Reply #14 on: May 08, 2015, 09:55:00 AM »
Yes I have worked with glass before, and I've seen the video too... Very straightforward project, just needs the time taken to do it right!
--Evan
« Reply #15 on: May 08, 2015, 06:46:05 PM »
Yes. I've learned so far it's better to take the time and do it right instead of doing it again.
« Reply #16 on: May 08, 2015, 06:50:01 PM »
Here's how I will mount the seat pan to the frame. I will build and weld brackets to the frame for the bolts. I welded he bolts to the little bracket piece between both bolts to keep them from spinning when I tighten them. Then fiberglassed over them. I'm done with the glass work. Next step is to make it pretty
« Reply #17 on: May 14, 2015, 03:47:36 PM »
done with trimming the seat pan and making it work. and put the first layer of bondo on. progress is slow but step by step is how you do it
« Reply #18 on: June 08, 2015, 10:56:05 AM »
a little update on my progress. got some parts in. the rear shocks from cyclexchange and all balls bearings for both wheels and the triple tree. going to start the assembly before disassembly soon
« Reply #19 on: June 24, 2015, 04:26:13 PM »
another update...got the motor in for more mock up. working on the tank and seat, trying to get it perfect. and also bought a sandblaster and powder coating gun. lots of parts coming in to install soon
« Reply #20 on: June 24, 2015, 04:40:36 PM »
Do NOT sandblast the engine unless you are going to do a complete disassembly and clean it multiple times with liquid and compressed air.
« Reply #21 on: June 25, 2015, 03:53:08 PM »
ya i wasn't planning too, i know it wouldn't be good having leftover media in the engine lol but thank you for letting me know anyways. i appreciate it
« Reply #22 on: June 25, 2015, 05:13:25 PM »
You'd be surprised what people do.  It is a PITA to get every grit of sand out of every crevice.
« Reply #23 on: July 13, 2015, 02:42:31 PM »
did a few more things, got the tray/pan done for the battery and electrical. made some mounting brackets for the rear sets, did some powder coating (still need to some more parts) and laced the wheel, and now gotta true it and do the rear wheel. mounted the swingarm and rear shocks. progress is slowly moving along
Offline Desert-SOHC
  • It's old
« Reply #24 on: July 13, 2015, 03:20:02 PM »
Coming right along
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
