Author Topic: So what kind of battery is everyone running? (CB750)  (Read 27793 times)
Offline ChopSticks
« on: April 27, 2015, 11:04:33 AM »
I've tried everything in regards to search keywords, but most of the things that come up for replacement (new) batteries are posts of old (new) bikes that say they are going to throw a new battery in them. No real details to what brand/type of battery is recommended. I know there are a slew of differences like lithium, AGM, etc but is there one specific one that the masses prefer?
Also this is probably a dumb question, but I understand to get a bike started 4 things are needed compression/air/fuel/spark, so is it possible to kick start a CB750 dead cold without a good battery? For example if the battery reads less than 12v but all lights work?
Offline Davez134
Re: So what kind of battery is everyone running? (CB750)
« Reply #1 on: April 27, 2015, 11:16:36 AM »
I think it depends on what you are using the bike for. If it is a daily rider, not trying to save any weight or space, I would recommend an AGM battery. For my 750 I used a scorpion AGM battery, it fit in factory location, does its job, and it is sealed so no maintenance/filling.
« Last Edit: April 27, 2015, 11:48:31 AM by Davez134 »
Offline ChopSticks
« Reply #2 on: April 27, 2015, 11:23:22 AM »
I think it depends on what you are using the bike for. If it is a daily rider, not trying to save any weight or space, I would recommend an AGM battery. For my 750 I used a scorpion AGM battery, it fit in factory location, does its jog, and it is sealed so no maintenance/filling.
Not sure exactly what kind of riding I'll be doing (at this moment it's looking like a weekend warrior since I have a daily), I just got it earlier this month and trying to get it running again. The PO mentioned it had a "new" battery, but after charging it once trying to get the bike started and charging it again it doesn't read 12v, it does have some plastic screws at the top, I'm assuming that's what you meant in regards to maintenance filling? Sorry I've never had any experience with these types of batteries (only owned AGM) so could that be my problem? I figured I might just pick up a new battery, but didn't realize they are a bit pricey.
Offline Davez134
« Reply #3 on: April 27, 2015, 11:24:35 AM »
You need to fill with distiller water if it has caps
Offline ChopSticks
« Reply #4 on: April 27, 2015, 11:29:29 AM »
Does it matter if I already charged it / hooked it up / and recharged it already? does it have any irreversible affect if it's been dry?
« Reply #5 on: April 27, 2015, 11:31:54 AM »
Yes, if it was dry, it probably is sulfated....never to retain a usable charge again.
+1 for scorpion agm...
http://www.batterystuff.com/powersports-batteries/sYTX14AHL-BS.html
« Last Edit: April 27, 2015, 11:33:40 AM by flybox1 »
« Reply #6 on: April 27, 2015, 11:44:32 AM »
Sealed GEL battery, 14A without any outlet hose. I bought a cheap one.
Offline ChopSticks
« Reply #7 on: April 27, 2015, 11:49:58 AM »
Possible to link to the one you bought? Hows it holding up for you?
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #8 on: April 27, 2015, 03:44:52 PM »
i put a shorai in my cb550.
It weighs ... nothing, or close to it.
And it cranks the bike so fast it's as though there is no compression (but there is).
I recently restored and sold a 77 cb750f, and am nearly finished with a (former basket case) cb750k5.  This is a place to share, learn and enjoy.  I am grateful to and for 99+% of this site's membership.
Offline faux fiddy
  • bike in a box
« Reply #9 on: April 27, 2015, 04:02:32 PM »
Someone posted this link to a NAPA battery for under $30 w/o tax. I'm  Not sure who is using them, but that's a smokin' deal and if it dies early you can find a place to get a new one nationwide.
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Battery-NAPA-Power-Sport-Specialty/_/R-SBE12N12A4A1_0400270734
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline OT7
« Reply #10 on: April 27, 2015, 04:27:52 PM »
 :) I used a scorpion AGM battery.
Offline przjohn
« Reply #11 on: April 27, 2015, 04:41:48 PM »
Lithium, step to the future.
Offline ChopSticks
« Reply #12 on: April 27, 2015, 05:23:41 PM »
« Reply #13 on: April 27, 2015, 06:18:20 PM »
Shorai lithium.
http://shoraipower.com/batteries-c41
Gel if $ is tight.
Offline ChopSticks
« Reply #14 on: April 27, 2015, 06:20:34 PM »
Shorai lithium.
Gel if $ is tight.
Thanks! Any idea the disadvantages of gel?
« Reply #15 on: April 27, 2015, 06:34:38 PM »
Shorai lithium.
Hey Don - seems like you highly recommend these. What, other than size, does this have over the AGM Scorpion to justify the cost?
Offline flatlander
« Reply #16 on: April 27, 2015, 07:29:04 PM »
do the lithium ones work with the stock regulator/rectifier?
Offline ChopSticks
« Reply #17 on: April 27, 2015, 07:37:54 PM »
Size, weight, vibration proof, can be mounted in any orientation, smart charging. Can store themselves for months without any parasitic loss.
wait those aren't disadvantages to the gels right?
EDIT: just realized you were replying to the comment above you. So AGMs are not vibration proof?
« Last Edit: April 27, 2015, 07:40:58 PM by ChopSticks »
Offline ChopSticks
« Reply #18 on: April 27, 2015, 07:39:05 PM »
how's scorpian compared to yuasa?
« Reply #19 on: April 27, 2015, 07:46:31 PM »
I am also running a couple Scorpions in my 750's.  The Yuasa is the stock type wet cell battery whereas the a Scorpion is a sealed AGM.
I simply do not want the chance of spilling acid on my bike, it's AGM for me every time.
Offline Puntas13
  • '73 cb500 '74 cb750 '09 Triumph Speed Triple
« Reply #20 on: April 27, 2015, 07:46:42 PM »
$42 cheapo YTX14AHL-BS AGM battery off ebay. Works for me.
Offline ChopSticks
« Reply #21 on: April 28, 2015, 08:19:09 AM »
So is it safe to order the batteries from best to not best
Lithium
AGM
Gel
Wet cell
Am I missing anything?
« Reply #22 on: April 28, 2015, 08:36:00 AM »
anyone?
« Reply #23 on: April 28, 2015, 09:28:55 AM »
They are much smaller and MUCH lighter than gels and suffer almost no parasitic loss.
They also provide more cranking amps.  Great for cold starts.
« Last Edit: April 28, 2015, 09:34:17 AM by CB750 Cafe Racer Fan »
« Reply #24 on: April 28, 2015, 09:29:30 AM »
Yes!
