Author Topic: Fuel hose size??  (Read 15045 times)
Offline dgilling
Fuel hose size??
« on: May 19, 2015, 09:42:06 PM »
I tried to search the forum for the answer but came up short. What is the actual fuel hose size you guys are using? I got a 1/4 in hose that seems to fit but Hondaman said it would probably leak. He gave me some 5mm hose (I think that's what he said) and said it was stock. That hose was so crazy tight I could barely get it on but I did.  Then when I tried to pull it off the petcock I had to pull with all my might and it broke the petcock off.
Anyone else using 1/4 in? Seems like that is what all the online places sell.
Offline CycleRanger
  • No comment about being an
Re: Fuel hose size??
« Reply #1 on: May 19, 2015, 10:10:59 PM »
OEM hose is 5.5mm. It's a tight fit for sure.
Offline Davez134
« Reply #2 on: May 19, 2015, 10:11:22 PM »
5.5mm I believe is correct size
Edit:^^beat me to it  ;D
« Reply #3 on: May 20, 2015, 04:08:52 AM »
I buy Tygon line  ID 3/16" OD 5/16" on eebay or at local power equipment store and it goes easy on and easy off and never leaks.
Like this one:
http://www.ebay.com/itm/5-Ft-Tygon-Clear-Yellow-Fuel-Line-ID-3-16-OD-5-16-/230942030772?pt=LH_DefaultDomain_0&hash=item35c537bbb4
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: May 20, 2015, 05:00:12 AM »
The trick to rubber lines is to not just pull on them, that just causes them to grip down harder on the thing you're trying to remove them from.  Instead push from the ends so that the hose expands from the pressure instead of stretching and contracting.
Just like a "Chinese finger trap".
mystic_1
- John Augustus Shedd
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #5 on: May 20, 2015, 05:37:46 AM »
How on earth do you type a post with your fingers trussed up like that? Astonished!  ;)
--Evan
1975 CB750K "Rhonda"
« Reply #6 on: May 20, 2015, 05:57:11 AM »
Like this one:
That stuff is great. Thin and flexible, easy to route without kinking, and self clamping.
« Reply #7 on: May 20, 2015, 06:46:41 AM »
I use USA made Gates Barricade  6mm ID, 13mm OD
Fits really nice on the petcock nipples (old dual version). Withstand modern fuels too.
But my carbs have 8mm connections so I have adaptors and use Gates Barricade fuel hose 7.9mm ID too.
Do not buy crappy cheap hose that will not cope with the fuel. I have done that mistake earlier this year.
Offline mcswny
« Reply #8 on: May 20, 2015, 07:13:36 AM »
Just go OEM 5.5mm if you can. After all, it was made for these bikes. Makes taking lines off super easy. Used to have crappy 1/4" and in the end I had to use a heat gun to get it off, so dumb.
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Offline dgilling
« Reply #9 on: May 20, 2015, 08:22:09 AM »
mystic_1
definitely tried that.  it was not budging.  crazy tight.
Like this one:
does self clamping mean you don't need to add an external clamp?
6mm sounds like a good option.   I feel like taking off a tank is pretty common process and it shouldn't that difficult.  However, I have zero interest in gas spilling on my newly painted engine.  I went thorough already and had to do some re-painting.
  shouldn't the 1/4in fit way more loose than the 5.5mm?
Offline dgilling
« Reply #10 on: May 20, 2015, 08:26:52 AM »
also, do you need clamps with the 5.5mm hose?  doesn't seem like you would.  If you do, where do I find those?  All I see is 1/4 or 3/16 online.
« Reply #11 on: May 20, 2015, 08:27:25 AM »
Remember that ethanol in the fuel was not actual back in the days. That's a new problem like the absence of zinc in the oil.
I should never trust the old type of hose when there are ethanol and other chemicals in the fuel.
Offline Davez134
« Reply #12 on: May 20, 2015, 09:16:22 AM »
I have been using the Honda 5.5mm hose with no clamps and with no issues.
Offline Chachi
« Reply #13 on: May 20, 2015, 10:02:28 AM »
I use Honda 5.5mm with no clamps. Works great. I bought the correct Honda 'clamps' -- those circle clip things -- for both fuel tap and carbs, but never used them. Honda line is not expensive from local shop, it's pliable and it fits (and removes) as it should. I bought it by the foot from my local shop.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline mcswny
« Reply #14 on: May 20, 2015, 10:23:04 AM »
No clamps and you can get it on fleabay, they often dont say it fits a CB, but it definitely does.
just a quick search....
http://www.ebay.com/itm/New-Genuine-Honda-Bulk-Fuel-Hose-5-5-mm-Line-Sold-By-The-Foot-See-Notes-R20-/271782216115?fits=Make%3AHonda&hash=item3f477b81b3&vxp=mtr
1972 CB750 K2
1975 XL250
198 XR80
« Reply #15 on: May 20, 2015, 10:34:22 AM »
Clamps are not needed. Honda uses the minimalist single wire wrap clamp. We've had buyers specials here before, where one member would buy a bunch from here, https://www.alssnowmobile.com/PRODUCTPARTS.ASPX?pn_deptid=304  to mitigate the shipping then parse it out to members.
But 5.5mm is the key.
Offline dgilling
« Reply #16 on: May 20, 2015, 02:44:10 PM »
I ordered a new 5.5mm Honda line from 4 into 1.  I also ordered a 3/16 in hose to compare.  both were pretty cheap.  the 3/16 hose is Helix Polyurethane and claims to provide "superior abrasions and kink, tear, oxidation and chemical resistance. Melting temp 370f Operating temp -75f to 155f This fuel line will not get hard, stays flexible."
I also got the Helix type in clear.  I like the idea of having a clear fuel line but if the fit isn't good i'll just stick to the 5.5mm Honda one.
« Reply #17 on: May 20, 2015, 02:59:20 PM »
The seller, Everett Powersports, is close to me.
They seem to dust off NOS and OEM stuff now and again.
I'll have to pay them a visit.
Offline Johnie
« Reply #18 on: May 20, 2015, 05:39:54 PM »
Been using 3/16 on all the bikes with no clamps. No issues. I get quality fuel line from Napa.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #19 on: May 20, 2015, 05:48:20 PM »
I have not have long term luck with the polyurethane line. It tends to get hard. It has not been a big issue since I swapped it out with the fuel filter. The Tygon seems better, but either will be fine. I gave up on the thick corded rubber hose. There is no pressure, so not need for cord.
« Reply #20 on: May 20, 2015, 07:40:33 PM »
Yep, me too. Bought a huge roll at a hardware store close-out for cheap, may last my lifetime and I like it very much on the old Honda's.
Offline shmorty
« Reply #21 on: May 21, 2015, 08:36:17 AM »
I got 5.5mm fuel line from http://www.mamotorworks.com/ apparently old Volkswagens use this size too.
Offline edwardmorris
  • Youngish
« Reply #22 on: May 21, 2015, 09:23:39 AM »
Honda part numbers for all your hose needs
Honda OE Hoses
Fuel tube - 1 Metre long
Part number          - ID    - Color
95001-3500160M - 3.5mm - Black
95001-3500150M - 3.5mm - Black, braided exterior
95001-4500160M - 4.5mm - Black
95001-4500150M - 4.5mm - Black, braided exterior
95001-5500160M - 5.5mm - Black
95001-5500150M - 5.5mm - Black, braided exterior
95001-7500160M - 7.5mm - Black
95001-7500150M - 7.5mm - Black, braided exterior
Vacuum tube - 1 Metre long
95005-3500120M - 3.5mm - Grey
95005-4500120M - 4.5mm - Grey
95005-5000130M - 5.0mm - Black
95005-5500120M - 5.5mm - Grey
95005-7000150M - 7.0mm - Black
95005-7500120M - 7.5mm - Grey
95005-8000120M - 8.0mm - Grey
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #23 on: May 21, 2015, 09:28:51 AM »
the problem I found, at least for the 550 is aftermarket fuel line is thicker outside diameter and can be a bear to fit through the carb bracket. But other than that i use it. I buy it from NAPA. I use clamps too.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline mcswny
« Reply #24 on: May 21, 2015, 11:42:04 AM »
Yeah I've always had good experiences buying from everetts.
1972 CB750 K2
1975 XL250
198 XR80
