Author Topic: Pete's 82 Nighthawk Project  (Read 22463 times)
Offline irish44395
Re: Pete's 82 Nighthawk Project
« Reply #100 on: February 07, 2017, 01:23:33 PM »
Thanks,Going to paint it that original blue. I am still working on getting the engine painted, did the covers that I had taken off and my lower forks. Hoping to get that done this weekend.
Pete
Offline WesTenRacing
« Reply #101 on: February 07, 2017, 05:17:30 PM »
Great!  I'm going to be keeping tabs on the progress.
Offline irish44395
« Reply #102 on: February 11, 2017, 05:26:44 AM »
Well I got the motor painted. Its still in my cardboard box oven. when I painted my lower forks last weekend then  I bake them I had them on cardboard well they stuck to the cardboard. didn't see that happening . so I waited ,want over them with a scotchbrite pad and repainted them well this time I managed to get a run on one of them.I got made at my self and stop ,I'll wait and try again. If it ain't one thing its two
Pete
Offline irish44395
« Reply #103 on: February 25, 2017, 12:20:34 PM »
I got the motor back in the frame. the hardest part was trying to figure out what bolts want were.Got to   finish up the forks and put the trees on. also got to do something with the shocks there in good shape just have to clean them up .If any one know if they come apart let me know it would make it better for cleaning .
Pete
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #104 on: February 25, 2017, 12:49:10 PM »
I took mine apart and cleaned them up.
Offline irish44395
« Reply #105 on: February 26, 2017, 02:46:51 PM »
put the alternator back on  and the swing arm, I was  going to put the clutch cover on but after looking at the gasket decided to wait and get a new one also cleaned up and installed the right and left step holders.
Pete
Offline irish44395
« Reply #106 on: February 27, 2017, 03:46:19 PM »
I got my all balls steering head bearings in tonight.
Pete
Offline irish44395
« Reply #107 on: March 04, 2017, 01:22:16 PM »
Getting a little farther along in getting this thing back together. I got the  shocks apart they are to rust pitted to just clean up and put back on,so  I am going to paint them. I'll take them to work and sand blast them and use the epoxy paint . I have one of bolts for the rear turn singles that is bent if you have one and want to sell it to me cheap let me know
Offline irish44395
« Reply #108 on: March 05, 2017, 12:30:36 PM »
Well today I just took the front brakes apart.I used air sounded like a bomb going off.Had them raped in a rag to keep them from taking my head off ,and ordered new seals. I got new stainless steel braided line to put on after paint.
Pete
Offline cb650
« Reply #109 on: March 05, 2017, 05:10:04 PM »
Nice your going with a black frame.  I never did like the blue frame
Offline irish44395
« Reply #110 on: March 11, 2017, 01:46:06 PM »
I am liking the black too.
Today I did some work on the rear shocks Well  painted them more like I am using plastic-dip. I have to clear them tomorrow . also painted the brake calipers today going to let them sit a while before I reassemble them
also made a clutch cover gasket and put bolts in my air assist fork caps Thanks to F16Viper68's post in tips for giving the size needed. 8mx12m
Pete
« Last Edit: March 11, 2017, 01:48:31 PM by irish44395 »
Offline irish44395
« Reply #111 on: March 14, 2017, 01:40:30 PM »
I put the shocks back together . I not sure if I like the plasti dip . after I put them on the bike  I turn the adjuster and it scratch the silver a little . but for now its ok
Pete
Offline irish44395
« Reply #112 on: March 19, 2017, 12:19:28 PM »
I didn't do much this week end . filled the front forks with oil painted the crash bar now I can lock down the motor , worked on my V star change the oil and a new battery. painted my tank badges and put some oil in the motor going to do a  valve check this week my feeler gauges are at work got to remember to bring them home. Note to my self  next build I have to be more organized when I take things apart and take more pictures before I remove things
Pete
Offline irish44395
« Reply #113 on: April 01, 2017, 01:38:15 PM »
Haven't been getting much done lately been trying to figure out where the bolts go on the rear fender  got that figure out and rebuilt the fuel valve. I am going to need to get that gasket with the four wholes in it fixed trying to coat it with rtv  maybe I should bite the bullet and get a rebuild kit. but on a good note while testing the valve I filled the tank with water ,no leaks happy that the casswell job worked  also got 14 leaders out of the tank  may have to raise the reserve tube a little it stoped at 11 leaders that gives me 3 leaders reserve maybe thats enough.
Pete
Offline irish44395
« Reply #114 on: April 02, 2017, 12:20:16 PM »
well this is my progress so far , it's slowly coming together
Pete
Offline irish44395
« Reply #115 on: April 08, 2017, 02:51:54 PM »
I got the front Brakes done, New brake lines master cylinder rebuilt with the calipers new seals . broke mighty vac left it in the shed it rusted up the humidity here in florida  sucks some times . Now I know why I put speed bleeders on my wing. Did the valves intakes were good the exhaust were tight .
Pete
Offline cb650
« Reply #116 on: April 08, 2017, 03:14:39 PM »
Looking good!!!!
Offline PetesPonies
« Reply #117 on: April 08, 2017, 03:54:59 PM »
I use Master Series Silver on inside of tanks. It a moisture cured urethane, so it is 2K, but nothing for you to mix. Just pour it in the tank and turn the tank to coat everything, then pour out the excess. It doesn't peel away because of gasoline, great material. I use it for rust on sheetmetal typically, but works great inside a tank.
Pete's Ponies
Mustang RUSToration & Performance
Offline irish44395
« Reply #118 on: April 08, 2017, 04:07:18 PM »
thanks for the tip already did the tank for this build but I have another tank that I am not sure what I am going to do with it yet but its a little rusty inside I may give this stuff a go
Pete
Offline irish44395
« Reply #119 on: April 16, 2017, 03:48:13 PM »
This week end I got the  wire harness on and got everything working but the blinker I need a new flasher unit. looks like I will be firing this thing back to life soon need to work on the exhaust and get that on .
Pete
« Reply #120 on: April 16, 2017, 04:14:23 PM »
Awesome progress!
« Reply #121 on: April 19, 2017, 07:39:55 AM »
Why are your photos upside down for the most part?
Offline irish44395
« Reply #122 on: April 19, 2017, 01:11:25 PM »
Offline irish44395
« Reply #123 on: April 19, 2017, 01:13:07 PM »
Its my phone for some reason it does it no mater how I hold the phone. Going to start using my regular camera
Pete
Offline irish44395
« Reply #124 on: April 29, 2017, 02:33:32 PM »
I spent last weekend seeing if I can polishing up the exhaust . I felt like there was to much rust and pits on the headers so Today I wet sanded them and painted with vht flameproof back . I had sandblasted the crown thinges and just clear them
Pete
