Author Topic: All you kids running an Motogadget M-unit sound off  (Read 15015 times)
Offline greenjeans
  • 1972 CB750K2
« on: February 17, 2016, 01:41:05 PM »
For you guys that have one installed.  How long have you had it, how many miles have you put on with it
and anything else you would care to share about it ?   Tips tricks etc.   Been thinking about on of those for
a while now.   Talk me into it.
Offline CBGhia
Re: All you kids running an Motogadget M-unit sound off
« Reply #1 on: February 17, 2016, 01:52:32 PM »
I am about to rewire my 550 (you may remember that bike), when it gets back from powdercoat.
I have looked at the M-Unit and I can't see any real advantage for these older bikes.  You still have to run wires to all of the controls.  It's a little more condensed and you can use thinner wires to the controls, so that helps, I guess... but what else makes it worth the cost? Turn signal cancelling?
« Reply #2 on: February 17, 2016, 02:38:50 PM »
hey man, it kinda looks like a cell phone...so it's gotta be good!
Offline dusterdude
« Reply #3 on: February 17, 2016, 02:42:27 PM »
Awwww man,i wish you hadnt opened this thread.now we'll have to listen to cal spout the m unit kool aid
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Camrector
« Reply #4 on: February 17, 2016, 02:43:38 PM »
I'm using it on my 550 build. Ease of use (wiring) is mainly why I got it. Control wires to M-button then one wire to M unit. Not sure if I'll use all of the features (light flashing options) but the alarm built in seems cool, and zero fuses!
Offline Camrector
« Reply #5 on: February 17, 2016, 02:46:47 PM »
Also I think if you watch the Revival Cycle video, and he wires a bike in 6 minutes with it I think you will be as sold as I was.
Offline greenjeans
  • 1972 CB750K2
« Reply #6 on: February 17, 2016, 02:59:16 PM »
Not opposed to purchasing the 3-button motogadget to eliminate hand controls.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #7 on: February 17, 2016, 03:21:50 PM »
This should be interesting
Offline Kevin Knueppel
« Reply #8 on: February 18, 2016, 12:55:56 PM »
First I've heard of it. Did some research and it looks great. I might be ordering for my project.
Sent from my MotoE2(4G-LTE) using Tapatalk
Offline fodzilla
« Reply #9 on: February 18, 2016, 01:28:47 PM »
I managed to grab an m-unit of a friend cheap as he's building a custom T110 and doesn't have a need for it.  Quite looking forward to getting it on my cb500 and burning the custom harness I built that caused me a summer of nightmares tracking down a simple charging issue. (Forgot to earth the stator, got very friendly with the recovery drivers near me - I know, but my first wiring attempt!!!)
Skip the M-Button, it has conflicts with certain types of ignitions.
I'm a little confused with this Cal, could you expand?  I was planning on using grabbing one to simple keep everything neat and simple.
CB500 Four K1 '75
Offline Camrector
« Reply #10 on: February 18, 2016, 03:02:04 PM »
Skip the m-button? How are you then expected to chose and select the different features and settings?? And how could it interfere with their own keyless ignition system? :D Connecting control wires to the M-button only requires you to run one wire to the unit instead of them all.
Offline ChopSticks
« Reply #11 on: February 18, 2016, 03:32:00 PM »
You'll need 5 buttons to replicate the stock functions (Turn L, Turn R, Horn, Start, LO/HI). And 6 if you use they electronic gauge (MENU).
might be a really dumb question, but will the stock controls work with the m-unit? Recently got one as a present but definitely not at that stage in the build, not sure if I need to start looking for new controls or not?
Also for all your builds where did you decide to mount the M-unit?
« Reply #12 on: February 18, 2016, 03:54:44 PM »
Yes.
Many users mount the M-unit under the seat in a pan for electronic components (reg/rec, battery, etc.).
Offline dusterdude
« Reply #13 on: February 18, 2016, 04:59:23 PM »
Do you need it? Nope. Will the stock electronics do the job? Yep. I do like them, and I use them on all my builds. But, every bike I use them on is a full re-wire, all new modern electronics, and all new non-stock components. So "grafting" modern harnesses to stock harnesses is a major PITA.
The biggest difference in the M-unit versus the stock harness is the direction of power. Stock, the key transfers power to the handlebar controls, then to the component. Thus, the stock wires carry current to/thru the handlebars. With the M-unit, the controls only send a GROUND to the M-unit, then internally, the power is sent to the output side and directly to the component. It matters only from a wiring perspective and it does reduce the gauge and complexity of your harness.
The M-unit still requires an inline fuse (albeit quite small) to protect it from over-amp incidents. Internally, the M-unit separates each function onto its own circuit (TURN L is separate from TURN R, HORN is isolated, and so on) so from a troubleshooting/reliability, I feel it has some advantages over the stock system. You could lose functions of the indicators and still run the bike as opposed to being dead on the side of the road with limited to no lighting. (By the way, each circuit is also self-resetting in the event of a short).
There are some embedded features like: Integrated Flasher, Low Battery Warning, Auto Cancel for your indicators, Flash to Pass, Strobe on your Brake, % illumination on your indicators as Running lights, Alarm, etc. Maybe these features are of no interest to a "restoration bike" but for a "resto-mod" they're pretty convenient.
So it really depends upon your situation as to whether its a good buy. If you have to replace most of the wiring and components because you bought an abandoned bike, and everything is shot, I'd say do it. Otherwise, a modern ATC fuse panel and some diligence works really well too.
But I like all their products a LOT. They're very high quality, but they do charge for it. Maybe not the product line for many, but for some, its all they'll use after experiencing them once.
There are some tricks to getting the most out of them, but only if you find yourself determined to buy one.
As for this ^^^, what took me 3 days to do for Duster, I could have done in 6 hours with an M-unit if he weren't so damn cheap  ;)
Durn tootin brother
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Camrector
« Reply #14 on: February 18, 2016, 05:14:56 PM »
Gotcha Cal great info that I didn't know. I see what you could mean by the ignition then being a problem. Something I haven't encountered because all my bikes are kick only. I also start my builds from none running piles of crap and replace everything with new. Ripping the old electric system off a bike brings a very warm feeling to my heart.
Offline ChopSticks
« Reply #15 on: February 18, 2016, 05:42:04 PM »
Yes.
Does the oil pan have to be relocated with a pan under the seat?
Offline ChopSticks
« Reply #16 on: February 18, 2016, 05:46:27 PM »
Yes, the stock controls will work with the M-unit. BUT, you need to read and understand what I wrote above (about the power distribution being "reversed"). With stock controls, the BLACK stock wire essentially now gets "grounded" to completely ground the switches. The stock switch wires (ORANGE, BLUE, LT GREEN, etc) would then run directly to the input side of the M-unit to send the ground signal to the M-unit. The output side of the M-unit gets wired directly to the component (light, horn, solenoid, etc). In this example I use stock BLACK as its already wired to the switches, and it is superfluous with the M-unit as no power is sent to/thru the handlebar controls.
I've installed them under seats, under tanks on the backbone, on the battery box, etc. The unit is smaller than a pack of cigarettes (maybe you're familiar with that size?) and does not require special environmental considerations.
Duly noted, have you ever purchased the ~$80 wiring kit motogadget offers? Is it worth it? Or better to just buy regular wire?
Also what kind of tanks have you installed under? Really interested in this placement, I saw one on a 750 but the tank was a Yamaha or something, wonder if it's possible with a stock '74 tank?
« Reply #17 on: February 18, 2016, 06:04:10 PM »
An old-school "m" unit (sorry Cal, I couldn't resist myself ;D):
« Reply #18 on: February 18, 2016, 06:55:51 PM »
So was everything OK using resistor caps?
Offline ChopSticks
« Reply #19 on: February 19, 2016, 07:52:59 AM »
I just use high quality copper stranded wire in 24awg and 18awg. I but it in 100' spools thru McMaster.
A (cough, cough) Harley peanut, a vintage BMW, an older Ducsti, and more relevant a 750f. Another location on the 750 is within the lateral tubes beside the backbone. A small mounting plate and away you go. Makes access to it a bit more tricky, but once it's set up, it's a "forget it" kind of product.
Do you have a link to the wires? I'm on mcmasters and doesn't look like they separate by copper, but by "type" of wire such as chem resist, harsh enviro, radiation etc
http://www.mcmaster.com/#standard-electrical-wire/=116z79b
Assuming the 24awg is for controls and 18awg for power and 25-50 ft should be more than sufficient right?
Is this that flat bar where the back of the seat cover?
Offline Gooseman
« Reply #20 on: February 19, 2016, 08:16:22 AM »
I picked one of these up on a resto-mod 76F project that had no wiring harness to start, and needed custom wired anyway due to electronics relocation.
My favorite part of this system is actually somewhat of a safety feature.  The digital relays detect shorts and/or over volting and immediately shuts down the offending relay!!  This will prevent an electrical fire/melt down should something start shorting out, even on the main line in the case of loose battery cable!
I went for a test ride after butting something back up this fall and after a couple blocks the bike would shut off when i hit a decent bump in the road.  I pull over scratching my head, pull the seat off, Ooops!! Positive battery cable is loose!
Had it not been for the M-Unit detecting the short and shutting off that circuit, I would have melted that battery terminal for sure if not started an electrical fire!!  The M-Unit saved me from this disaster, I tightened the terminal up and went on my way.
Offline thirstforspeed
« Reply #21 on: February 19, 2016, 12:00:18 PM »
i put one on my Virago, custom wiring and the whole bit. didnt use any stock components except for the TCI box.
I can't say enough good things about it. it is very easy to wire (for a noob - it was the first time i did any custom fab work at all). i like how straight-forward the wiring layout is. one side to the switch, one side to the load, ground through the frame. and lots of customizability for different switches and such. I think it is a great upgrade to any TCI/points bike if its at the point where the harness needs to be redone or the electrics are being relocated. integrated fused relays are the future.
Offline fodzilla
« Reply #22 on: February 23, 2016, 03:17:37 PM »
Hard to out a price on safety, but I definitely agree it is a nice feature. Some might say, "That's a newbie mistake and you will learn next time..." But I'll take some creative thinking over human error to offer some protection any day. After all, I'm only human.  :)
Hi calj,
I'd like to thank you for the help on this, I think I almost ready to begin the wiring stage, but wondered if you had a wiring diagram you'd used.  I've had a look about on the forum and thought I'd seen one you'd posted before but for the life of me I can't find it now I'm after it.
I now get the charging system not being part of the M-unit and understand it runs of the auxiliary as detailed in this partial wiring diagram I found online. But I'm a little confused with the indicator warning lights, full bean warning light, neutral light and oil light positions in the wiring.
Doe's the indicator warning light share a connection with both "Turn L & Turn R Out's" on the M-unit? Such as "Turn L & Turn R Out's" -> Indicator Warning Light -> Ground
And do the neutral light and oil light share the "Aux out"? If so in which order?  "Aux out" -> Switch -> Light -> Ground
Sorry, I'm a little confused here at this point, I get the attached diagram but can't find much on warning lights with the M-Unit installs.
CB500 Four K1 '75
Offline fodzilla
« Reply #23 on: February 23, 2016, 05:21:30 PM »
Thanks Calj,
That's absolutely terrific!  It's just clicked perfectly in my head for me!  Your comments and the diagram I found on the Motogadet site helped it all go together!   Looking forward to fitting the thing now, and that new part they do is nice, expensive but for the sake of £15 it will save a lot to time and hassle.
For anyone else, here is the link...worth the read, by the time you get to the end of reading, it starts to fit together!
http://motogadget.com/media/downloads/manual/munit_v2_manual_en_3.2_k.pdf
I'll map out the switches, key, lighting and other bit you might want and drop you a PM sometime tomorrow.
Thanks again for your help here.
« Last Edit: February 23, 2016, 05:26:46 PM by fodzilla »
CB500 Four K1 '75
Offline greenjeans
  • 1972 CB750K2
« Reply #24 on: February 23, 2016, 06:26:45 PM »
Thanks for the input guys.   The bike I'm building is for me, until somebody gives me a silly number for it.  It has an aluminum oil tank and will not run side covers.  Was thinking of an m-unit coupled with a rectifier/voltage regulator combo unit.  That way I could put them where they wouldn't be seen.  I could do pretty much the same thing without an m-unit, but I like the idea of eliminating the stock handlebar controls.  There are 2 things that get me - priceif I were to get the m-unit, 2 3-button handlebar controls and, the actual look of the buttons.  Ideally, I'd like something less modern.  Could be just as easy as smoothing out the tooling marks and rounding things a bit.
