Author Topic: Marissa's 1972 CB500  (Read 108447 times)
Offline wolf550
Re: Marissa's 1972 CB500
« Reply #100 on: November 15, 2017, 09:14:35 PM »
in the same boat as to my own project.
around last week or so I was enjoying riding my bike around tow when the oil light came on and losing power.
after disassemble I found my valve guides fractured and one chunk off my cyl 1 valve crumble before my very eyes
bought a donor motor to get parts off only to find most are in the same condition
this is my first bike and after getting it started and going I could not see having bought a different bike
it seems there are many people on here that help each other out with info and parts
keep up the good fight
74' CB550 (Sold)
71' CB500/550 (Sold)
« Reply #101 on: November 16, 2017, 08:29:53 AM »
Cal is everywhere.  Always.
Offline Scott S
« Reply #102 on: November 16, 2017, 08:52:43 AM »
 I definitely have some loose valves. I don't think it's a full set...maybe one missing. Let me know if you need any.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #103 on: November 16, 2017, 02:02:28 PM »
For head work there is also Mark Paris, aka Hondaman. My K3 750 head turned out beautiful.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline DaveBarbier
« Reply #104 on: November 17, 2017, 05:22:38 AM »
It's possible that the machine shop didn't do as good a job as they should have, but it's also possible the valves are all a little tweaked and it's hard to measure. I agree that the major bent valve really looks like it was bent from improper valve cover installation. When you were talking about 'timing' you meant cam timing, right? So you think the valve hit a piston? You'd see damage on that piston. And it would have had to shift a couple teeth for that to happen.
Definitely lap the valves yourself. Easy and you can verify they all seal. This video from Jafro helped me:
I have a lapping stick and compound if you want to grab it, but that stuff is cheap enough.
There is this head on eBay which comes with rockers and cam and cover. Looks to be in good shape but you might have to deck the head surface. Kind of hard to tell the condition. The journals, cam lobes and rocker faces seem to be in good shape. Best case, this head will only need to have the valves lapped and new valve seals installed. It also says "or best offer" so he'll go lower.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F292269714009
Let me know if you need help with any of this stuff. We've all been there with problems that just seem to compound and never get any better. The more issues a bike has, the more experience and knowledge you gather...also the less fun you're having, haha. But hey, it's pretty much winter up here anyway.
I thought you can remove valve guides with a slide hammer and not destroy the valve seat. Am I way off?
Offline DaveBarbier
« Reply #105 on: November 17, 2017, 06:20:59 AM »
Dave - you can hear the head and drive out the guide, but with new guides you must recut the seats anyway. Off to the machine shop you go...
Ah ok, that makes sense.
« Reply #106 on: November 19, 2017, 11:18:09 AM »
Valve lapping, especially with a new valve, is straightforward and simple. Most of the CB500/550 heads live a LONG time with their guides because the angles are straighter and the side loads lower than on the 750 engine: it is rare that I have to replace the guides in these heads. The exhaust side wears out first, mostly due to ethanol fuels today.
Maybe check with PartsNmore for valves, less expense than OEM.
Offline Marissa
« Reply #107 on: November 26, 2017, 03:58:26 PM »
I got started on relapping the valves, so far it seems really straightforward, but I have a couple of things I want to run by those with experience;
On cylinder 4, the intake valve looks like its wearing along the area above the seat (the black "polished" ring is what I'm referring to), is this something I should be concerned about? On all the other valves, that section is more like a thin stripe than anything else. Looking at them from the side, the valve on cylinder 4 did seem more voluminous above the seat, and it does have the same stamping on the face of the valve as all the others. Is this like a flaw with OEM valves? Am I overthinking this? Should I get a new valve for this one?
Also, does anyone here use bounce tests to verify the concavity of the valves? I want to bounce test them but I don't know if there's a special technique to do so, whenever I insert the valves into the guides there's not enough slack to allow them to fall into place, giving them the inertia to bounce if they were right. If no one here ever bounce tests the heads, then I guess I will trust a leak down test to tell me. I know there are some people though that don't like to go by that method alone.
I currently have the Vesrah valve seals installed, does anyone think it's a good idea to change to the Viton seals while I'm in here? These seals are new and were installed by the machine shop. They look fine but if it's better to upgrade to Viton with factory spec internals then I guess I will, it is pretty cheap to do so.
I'm using CTA lapping compound, which comes with a "Coarse compound" and "Fine compound". It seems to do the trick well. I'm also using Permatex "Ultra Slick" engine assembly lubricant to lubricate the valve stems while I'm lapping the seats.
1984 Nissan 300zx - sold
2016 Ford Fiesta ST - daily
1972 Honda CB500 - infinite work in progress
Instagram- marissasimos
« Reply #108 on: November 26, 2017, 07:19:27 PM »
The 'bounce test' only works on valves with more than 0.0030" stem-to-guide clearance, which is too much for this engine. This one uses 0.0008" to 0.0012" intake side, 0.0014"-0.0022" (new numbers) clearance. If yours has bronze guides, use the tighter numbers.
The valve 'margin', which is the unground portion outside of the newly-ground face & seat, should not be less than 0.25mm. When new, this space is about 1.2mm on the 500/550 valves. If this goes to 0, then either the valve must be replaced (if it was previously ground) or the seat recut, in which case all 4 should be recut together. The OEM valve seats, according to Honda's manuals, were 3- angle seats: in the 500/550 engine this was never true. Most of them come with a 2-angle seat, the inner 60-degree one being sort of molded into the valve seat itself, not cut in. Making new 3-angle seats with 1.25-1.50mm 45-degree seat faces will improve breathing and cooling, if you're going for more HP.
Offline Davez134
« Reply #109 on: November 26, 2017, 09:14:07 PM »
Just read through most of the thread. Good on you for trying to do things the right way. I know it can be disheartening every time you open something else up and find something wrong. The payoff of a reliable, good running bike in the end is worth the effort!
Offline DaveBarbier
« Reply #110 on: November 29, 2017, 04:38:07 AM »
I may have missed it, but are you replacing the guide(s) and getting a valve job? Or maybe just trying to see how lapping goes?
Offline Marissa
« Reply #111 on: January 04, 2018, 12:10:11 PM »
Back from the depths of winter with an update.
Originally Dave, it was just seeing how lapping was going to go, and to replace one valve guide that was cracked. I had to drill out the old guide, but it got to a point where I was off a drill bit size by just a hair, so I couldn't remove the rest of the guide, and I certainly did not want to go over a size or else the head wouldn't be useable. I didn't know what to do next and I was getting hesitant to go further with that, which is when I stumbled upon a used head on eBay for $50. It had perfect fins and looked to be completely solid, so I went for it and bought it.
Turned out to be in pretty good shape. A lot more dirtier on the outside than mine was, but cosmetics are easily fixable. The inside was fairly decent, and turns out all of the studs were replaced at least in the past couple of years, so they almost look new. All threads are in great shape, no damage. So I went ahead and started to disassemble this head and look for issues. Since the first time my original top end was rebuilt by a shop, I have no internal comparison to make, but I could tell this head ran with ethanol fuel for a while. The exhaust valves were pretty ugly and took a while to clean, really caked stuff. I wish I took more pictures of the outside because it was pretty ugly, but here's a couple from the job. All valves, guides, and even seals seemed to be decent, so it was a really straightforward cleaning and lapping job. I bought Viton seals for it as well and put those on, and sprayed the head with a coat of VHT's Flat Aluminum Header paint.
So clean and pretty!
A glimpse of the work during a quick 400 grit sanding of the mating surface. It wasn't uneven really, but there was a tad bit of pitting from the corrosion you can see in the photo. After a nice cross cutting sand, the corrosion was still visible, but you can't feel it in the surface, even with a fingernail. So I didn't worry much, just not the prettiest surface, which is A ok in my book.
An old seal. I eventually cleaned out as much as possible on this head after soaking it in a 50/50 solution of Purple Power and water for a couple of days, since it's been so cold I was allowed to work inside the kitchen a couple of nights, so I grabbed some nail polish remover while I was in the house and started to clean up any hard to reach areas with cotton swabs. And yes, the alcohol content in nail polish remover does a really nice job of cleaning. I highly recommend it since it also does not have as strong of fumes as some of the typical solvents and cleaners.
Coming together. You can see I wasn't able to get the face of the exhaust valves to look completely smooth and new, but that seems to be of no issue. You can also see the array of tools and materials used, as well as the teddy bear sheet (which adds like 10 extra horsepower and a blessing to this build, of course.)
Very dirty exhaust port.
Very dirty intake valve. I wish I had remembered to take a photo of all 4 at once to compare to everyone the appearance of them. I could tell there was AFR issues in some valves, I think it was cylinders 2 & 3 that looked like they were running richer, which I believe could make sense if they were running a different intake style as 1 & 4 always get more air from the physics behind them, and likely the bike was tuned to the AFR of 1 & 4. Just a speculation I guess.
The cleanest valve!
Intake before:
After:
Nice and clean seat:
Nothing looks brand spanking new internally, nor am I using new oversized cool valve train components, but it was still exciting to see it come together
After cleaning up the valves and putting the new seals on, I went to reassemble and I noticed some of the retainers were more worn than others. I'm thinking at some point valve lash was incorrectly measured and maybe a couple of times it was ran a tad low on oil or there was some other oil issue. So I went ahead and swapped out the worn ones with good ones from my original head. It pays to have an extra after all.
Borrowed a leak down tester from work, and after working to about 4am, it was going to be ready to test the next morning. Quite frankly I was so tired that I didn't even realize how much the results we saw in that moment were going to matter. I had no idea how this was going to go.
1 & 2 were absolutely perfect. 3 was at about 20%, but that one is likely due to the fact that I kept spinning it over TDC by 10 degrees, every single time(it let air out through the exhaust port as well which is why I'm thinking there is no issue with the cylinder, but mainly user error  :) ). 4 was a bit sad, because it showed results that need attention:
The good news is, absolutely none of this was leaking from the head. Which means that I finally solved the top end issue, once and for all. This was monumental for me!
The bad news is, this was crankcase pressure, so likely, I cracked a ring when placing the cylinder jug back on. I'm not really surprised since I had to do that twice, I probably cracked the ring the second time on and considering I used my hands to compress each ring, one at a time, and slowly lower the jug onto it going from side to side. I essentially was asking for a ring to fail, haha. So all in all, I am not upset. I actually was able to find a leak as well from the kickstarter area, which I referenced a few months ago when the kickstarter spring (at some unknown point in its life) kicked off the perch by the clutch basket and squeezed itself between the cover and the gasket. Now I know that it needs a little bit of RTV on that side and it should be good to go after. Quite frankly I'm happy that issue showed itself now and not when the bike was on the road and spilling oil every where!
I also used the rubber band trick as prevention when installing the valve cover on, and although I thought it would do little to nothing, it truly helped a lot more than expected and made installation a breeze. It only takes about a minute to put the rubber bands on as well so it's really not out of the way.
So, disassembly will be needed one more time, I'm going to wait until I can inspect the rings on 4 to order any parts or ring compressors. In the meantime, I did order an EK cam chain and master link, so I will need to break the old chain, break the new chain, remove a link, install chain with new master link and link tool. I know endless is always preferred but I didn't want to go down to the crankshaft and I think the advantage over master link will be negligible for a stock rebuild. All thoughts welcome on this however, if it's unanimous that this isn't the best chain brand or option, then I can still return it and swap it!
Right now it's just a waiting game, it's been single digits and diving into negatives for the past couple of days and weekends which is really upsetting since the next semester starts in two weeks. I really wanted to make some progress between now and then, but it's just too cold and I don't have a heater in the garage. I also know I make stupid mistakes when it's that cold, so I think it was a perfect time for an update.
I also made an electrical box about a month ago. It's pretty big because initially I was trying to fit a stock sized battery into it, but I've read that I'm going to need a lithium battery once it's running because of the extra CCA the electronic ignition is going to want along with a higher AMP per hour. This is fine because I had my eyes on a small Antigravity 8 cell anyways, so once I'm done with everything else I can modify the box further since the Antigravity battery reduces battery size pretty much in half. I was thinking about trimming an inch off the height and then creating a lip around the top of the box to give it a more refined finish look and feel, and hopefully save my fingers from getting cut on the rough edges haha. At that point everything will look so much more clean and tucked, even though it's still using original harness. After I get a season of riding time into this thing I would love to convert to a motogadget unit and create a new harness from scratch.
Thank you all for your support and telling me about similar instances many of you have had. I know I don't reply to most comments on here (I feel like it really lengthens posts an excessive amount, and I'm trying to keep it straightforward for anyone who reads this for any insight for whatever reason) but I read every single one and I try to respond to most of them in mass updates like this. Or, I hope that my updates help answer the previous question stated without having to reiterate it.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #112 on: January 04, 2018, 01:43:47 PM »
In addition I'll say a battery tender is a must.
Looks like a great project.
1973 CB 750 K3
« Reply #113 on: January 07, 2018, 08:48:36 AM »
The color difference on the valves (and chambers) when oriented as 1-4 and 2-3 usually comes from the ignition timing having been off a little bit on one of them. ;)
« Reply #114 on: January 07, 2018, 10:15:20 AM »
My bike has no problem with a cheap GEL battery.
Offline Marissa
« Reply #115 on: January 14, 2018, 07:04:58 PM »
I was able to tear the engine down this Friday, a random heat wave of 50 degrees came through!
Expecting to see a cracked ring, I pulled the jug off carefully, and surprisingly, no damage to any rings.
It looks like this may have been a potential indexing issue, as everything is in good spec and I didn't set the gaps 120 from another. I took multiple measurements, some of which I have photos for.
Here are some of the measurements I took. I'd love to get a second opinion on these measurements, I just have a hard time believing that improper ring indexing could really cut compressions in half.
Cylinder wear:
2.185 in.
Cylinder wear limit: 2.207 in. Therefore in spec.
Piston diameter: 2.2001 in.
Piston diameter limit: 2.199 in. Therefore in spec.
Piston ring end gap: (Top Ring) .015 in. (Second Ring) .010 in.
Piston ring end gap limit: .030 in. Therefore in spec. (Second Ring limit): .020 in. Therefore in spec.
Piston Ring Side Clearance: (Top Ring) .12mm (Second Ring) .10mm
Piston Ring Side Clearance Limit: (Top Ring) .18mm (Second Ring) .15mm
Keep in mind, I know the air is passing through the rings because the leak down test revealed pressure being released from the oil breather (which means crankcase pressure) and I had another leak all the way at the side of the clutch basket cover.
I'm hesitant to put everything back together on an assumption that it's ring orientation. Is there anything else I'm not thinking of that could lead to this issue? Either way, I have to order a new base gasket and head gasket, so nothing is going together until next weekend, at the earliest.
Thanks in advance!
« Reply #116 on: January 14, 2018, 08:03:53 PM »
There is both a minimum and a maximum ring-end gap: max for this bike is 0.026" for the top 2 rings. I'm a little curious: did you get 0.030" top gap in a new set of rings, or are these used rings? Usually new rings come at 0 or the minimum gaps, requiring fitting during installation. Most of the 500/550 pistons I've done fall into the 0.008"-0.010" range, larger being for the overbores like 600cc kits: on those the top rings can go out to 0.012" gap.
If the top ring gap is more than 0.020" then there will be quite a bit of compression leakage, at least until possibly some carbon fills it in somewhat. That may take up to 1000 miles with today's super-clean-burn gasolines, though.
Offline Marissa
« Reply #117 on: January 14, 2018, 09:23:40 PM »
Hey HondaMan,
I should clarify, the last measurements (where I state they are in spec) are the maximum wear limits provided by the Clymer Manual. Here in the book it says the top ring limit is .030 in. and the second ring is .020 in.
The rings installed are new rings, measured at .015 in. for the top, and .010 in. for the second ring. Those were measured by placing them in the cylinder jug and measuring with a feeler gauge.
« Reply #118 on: January 15, 2018, 01:23:41 PM »
Hey HondaMan,
Ah, yes, Clymer strikes again...their errors in their various versions of their CB750 manuals were one of the things that pushed me to make my book...
Your actual ring numbers are good, though, at less than 0.016" and more than 0.007".
To get off into the weeds a little for a moment:
RING WEAR is measured by putting the ring at the bottom of the cylinder bore where the hole is most likely still its original size.
BORE WEAR is measured just below the site where the top ring's travel marks are/were. The bore above that site is also still un-worn.
WEAR LIMIT is measured with the used ring(s) placed at the most-worn site at the top of the bore, usually about 1/4" down from the top.
Thoughts about the compression numbers:
if the ring gaps of the top 2 rings are closer than about 60 degrees to each other, it makes a noticeable "number difference" at cranking speeds. This often fills itself in with a little run-time and carbon build-up, though. In really-worn (750) engines I have torn down before, I've seen all 3 gaps aligned vertically (on pistons with 1-piece oil rings) from cylinders where compression was OK, but rings worn enough to let oil slip by. This happens on these engines mostly on the 1-4 cylinders, with the gaps aligning toward the outside-front (11 o'clock on #1, 1 o'clock on #4) zones where the bore is largest. But...I'm speaking about engines with nearly 100k miles on them, certainly not in this one's arena.
The leakdown problem can also come from a loose-fitting valve guide: the most common culprit here is the exhaust guide clearance-to-stem. Reason: if the clearance is too loose, the valve closes just slightly off-angle after being pushed open-closed slowly (cold, especially) and doesn't completely seal. If the clearance is a bit too tight, and especially if the valve is new (Parkerized stem), it will not seat well until it wears into both the seat and the guide.
Too-much clearance is about 0.0032" wiggle of the valve face when lifted about 5mm off the seat: the greatest movement is toward the center of the chamber and the front of the engine, back-and-forth. Too-little clearance is less than 0.0006", or if the stems are still Parkerized, 0.0004". In this case, I have sometimes polished the offending stem somewhat, or reamed the [new] guide 0.0004" extra to set them up.
Once in a while, I have also found a slightly-warped valve stem! These can be hard to find, but one way is to roll the stem slowly along a flat plate (I use a piece of picture frame glass I that haven't broken yet) while watching closely for the face to wiggle, or else put the valve in the head sans spring, look at it from the port, and shine a bright light at the chamber while slowly spinning the valve against the seat to see if light shows up around an edge. If warped, light will peek in for about 30-45 degrees around the edge of the valve now and again while twirling it, trying to hold it tight to the seat.
Offline Marissa
« Reply #119 on: February 02, 2018, 06:51:11 PM »
Kinda wanted to keep it hush hush until I made uphill progress, but I reached a point where I really want to get multiple sets of eyes on what I'm seeing and ensure I make the right decisions.
I got a cb550 engine for a good deal and wanted to grab it to learn more about disassembly and potentially swap it into my 500. I figured if anything else I could part it out and make more money on it vs. what I spent. I split the cases the other day and I'm a little concerned about two things:
1: This engine needs a new primary chain, it is rubbing a tad on the bottom casing and has lots of side to side play. The crankshaft appears to have heat discoloration near it from contact I would guess?
Has anyone seen this, and how bad is it?
Second concern is the bearing seats for the transmission gear shafts, they are all worn irregularly and I'm not sure how much of a threat this is. I'm assuming you treat them similar to the cam seats and the crankshaft bearings, which would mean this is not good. Does this mean I can't use these crankcases?
Thanks in advance!
« Reply #120 on: February 02, 2018, 07:04:33 PM »
Check the crank for runout on V blocks. The only reason I can think of for that heated area is  maybe  cutting off a primary chain, or maybe trying to straighten a crank? Cant think of other reasons.
Offline wolf550
« Reply #121 on: February 02, 2018, 07:50:58 PM »
hope it all works out in the end.
have a 500 and 550 engine going to start pulling apart to understand how to put back together myself.
74' CB550 (Sold)
Offline Marissa
« Reply #122 on: February 03, 2018, 11:39:16 AM »
Those are both good points actually. Thanks, I'll check for run out.
Anyone have any thoughts on those transmission bearing seats? Should I just try to find new ball bearings and run it? I can't find anything on the shop manual or the Clymer manual that discuss them other than talking about putting in the bearing set rings and the dowel pins.
Thanks.
Offline Marissa
« Reply #123 on: February 03, 2018, 11:49:24 AM »
Thanks, you as well! I'm hoping by the time I'm done with the 550 motor (if I don't part it out) I can swap it in and use that with my bike, and then practice more with the 500 engine. After taking this thing apart I am fairly certain that the buildup of grey stuff in my original engine is crankcase material from a sloppy primary chain. Obviously I won't know for certain until I take the cases apart but the 500 engine looked to be completely original (based on my comparison with the 550) and had that buildup, which tells me it's possible for the primary chain to be original, and with 23,000 miles on it, I would definitely believe it would have enough slack to do that damage.
Someone has very clearly been in the 550 engine before. So we will see what we find!
Offline Marissa
« Reply #124 on: February 04, 2018, 08:16:46 AM »
More nice finds. I can’t tell how this damage came to be on this primary shaft but I guess if all else fails I can pull parts from my 500.
UPDATE: looks like this is apparently normal on the primary shaft? I looked at primary shafts for sale on eBay and every single one had this awful hole in it. It didn't look like it was intentionally put there at all but I'm guessing this has a purpose since every single other primary shaft I found has this. It looks pretty scary though, I won't lie. I have no idea why this was designed in such a manner.
Got a better view of the discoloration on the crankshaft now. Looks like it affects two sides, not sure the cutting idea fits now. I haven't seen this on any of the previous build threads I've read on here. I work at an automotive performance shop and have seen this on a couple Audi 2.7T cranks, should I disregard this as normal? I just want to make sure I'm not overlooking anything that might need attention.
« Last Edit: February 05, 2018, 06:59:12 PM by Marissa »
