Author Topic: The South Side Dive Bar  (Read 3412982 times)
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
Re: The South Side Dive Bar
« Reply #22925 on: January 12, 2010, 05:16:37 PM »
I read about that, it was effed up.
what bike are your levers from?
 I've made this so far. it's fancy aircraft aluminum.
« Last Edit: January 12, 2010, 05:18:39 PM by Industrial Cafe »
Offline vanillagorilla
  • When did I become a
    • The ole Facebook Profile...
« Reply #22926 on: January 12, 2010, 05:51:29 PM »
Those are some of the better looking rearsets I have seen. And I just so happen to have a little build money...  'bout $100. Hmmm.... ;D
Offline b82ta
« Reply #22927 on: January 12, 2010, 07:25:22 PM »
IC those look great!  the brake lever is from a cbr 600 but I would look for something different if I was going to do it again, it ended up being a pain to use.  Some of the kawasaki levers look like they would work much more easily.  The shift lever is a gsxr 1000 and it works PERFECTLY I just cut the original shift lever down, bent it, drilled it, and made a linkage that connects the gsxr lever to the original shift lever.  it works flawlessly.
Offline MickeyX
« Reply #22928 on: January 12, 2010, 07:29:47 PM »
I'm at work stealin' teh nets...  ;D
Offline b82ta
« Reply #22929 on: January 12, 2010, 07:48:10 PM »
my find of the day is an old Grant RG-9 Helmet.  Picked it up for $3.  Its the Red one, the orange one is my AF-20
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #22930 on: January 12, 2010, 07:54:10 PM »
Just splurged on 2GB of memory for the new to me computer- wow, game changer to say the least.
Offline b82ta
« Reply #22931 on: January 12, 2010, 07:57:34 PM »
forgot the [pic....
Offline the technological J
  • deliciouso!
« Reply #22932 on: January 12, 2010, 09:00:40 PM »
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline Zaipai
    • My Home page
« Reply #22933 on: January 12, 2010, 09:30:43 PM »
im gonna tune in tokyo :D
www.gizmowatch.com/images/boobs-radio_48.jpg
If I were single I would for sure get one of those..  :P
Its my Avatar..
75 CB550F  |
  • Like a well oiled
    • Undead Asphalt
« Reply #22934 on: January 13, 2010, 06:59:01 AM »
I was looking at 99-07 hayabusa rearsets
see how the levers are not on the peg? I think that would give you more pedal and peg mounting options.
Offline b82ta
« Reply #22935 on: January 13, 2010, 08:39:06 AM »
That does look like a pretty nice setup, though I do like the cleaner look of the pedals and pegs sharing the same mount.  The only issue with having the pedals mount on the same bolt as the peg besides getting the bushing made is to come up with a brake lever that functions well... I need to take some time and try to re work that a little bit.  What I've got on the bike now works, but is certainly not ideal.
  • Like a well oiled
    • Undead Asphalt
« Reply #22936 on: January 13, 2010, 08:47:35 AM »
what's the issue with your brake pedal?
Offline b82ta
« Reply #22937 on: January 13, 2010, 08:53:42 AM »
Well initially the problem was that the arm that the piston rod connects to was too far out in the middle of the pedal so the master cylinder would have to be mounted pretty much inside my foot.  So I had a local welding shop weld on a new arm on the end.  It works just fine but the master cylinder is still a little far out, stealing a little bit of my peg space.  So when I redo it I'll either get a different arm that brings the mastercylinder in closer to the bike, or just keep using what i've got and have a wider bushing made that pushes the peg outward.
  • Like a well oiled
    • Undead Asphalt
« Reply #22938 on: January 13, 2010, 09:16:44 AM »
huh.
you have disc in the back, I forgot about that.
03-09 yamaha R6 brake has some interesting properties.
Offline b82ta
« Reply #22939 on: January 13, 2010, 09:34:33 AM »
hmmmm those are interesting.  I'm not sure if it would work, but before I redo mine I'll definitely look into those!  I'm just not sure if I could lay the master cylinder down like that with out hitting the frame... At least with the way mine are currently mounted
Offline alltherightpills
« Reply #22940 on: January 13, 2010, 05:17:07 PM »
How-do, you sinners.
It's been a couple of months since I've been on the forums.   I was spending way too much time on the intertubes (mainly this site) and needed to take a big, big break.
Anyway, thought I'd check in and see how everyone is doing.
78 550K
77 550K (in pieces)
71 500K0 (in pieces)
  • Like a well oiled
    • Undead Asphalt
« Reply #22941 on: January 13, 2010, 05:21:12 PM »
PILLS!! we're still here.
hey, does anyone know why "tough guys" take off their shirts when they want to fight?
I just saw a dude do it today and my friend Ari does it too, but "I don't know" isn't a good enough reason.
« Reply #22942 on: January 13, 2010, 05:29:56 PM »
I don't know, I usually take my pants off to fight.
78 550K
77 550K (in pieces)
  • Like a well oiled
    • Undead Asphalt
« Reply #22943 on: January 13, 2010, 05:36:57 PM »
I told him I'd do that next time he got into it with someone.
Offline Frankenkit
  • Industrial Strength
« Reply #22944 on: January 13, 2010, 06:26:09 PM »
Wow. Element of Surprise x10.  :D
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline BlindJoe
« Reply #22945 on: January 13, 2010, 06:32:38 PM »
one less thing for their opponent to hold on to, they don't want to get it ripped, intimidation
Offline 333
  • Time for change
« Reply #22946 on: January 13, 2010, 07:10:46 PM »
Sure it not pure intimidation?
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline 333
  • Time for change
« Reply #22947 on: January 13, 2010, 07:11:49 PM »
And, Evening, Pills.
What happened to the spell check?
« Reply #22948 on: January 13, 2010, 07:13:05 PM »
Only if he is hung like a horse.... ;D ;D
  • Like a well oiled
    • Undead Asphalt
« Reply #22949 on: January 13, 2010, 07:17:37 PM »
haha, he starts wingin' his wiener around like a set of nunchucks!!
all under the arm pit and over the shoulder.
