Author Topic: THE PHOENIX :FROM THE ASHES TO THE ASPHALT  (Read 144336 times)
Offline KB02
Re: THE PHOENIX :FROM THE ASHES TO THE ASPHALT
« Reply #200 on: April 18, 2008, 09:06:36 AM »
Don't jinx the man. He's had a hard spring!!   ;) ;D ;D
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline DarkRider
« Reply #201 on: April 19, 2008, 05:55:12 AM »
Holy crap!! just now noticed spikeys posts...man you gotta fire off a few more STAT!!
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
« Reply #202 on: April 19, 2008, 10:16:51 AM »
i was being the evil lurker for a few days  ;D
Offline heffay
« Reply #203 on: April 19, 2008, 10:18:09 AM »
at least you didn't spontaneously combust.
fuzzybutt
« Reply #204 on: April 19, 2008, 03:24:15 PM »
like all the drummers for spinal tap?
Offline hoodellyhoo
  • CB350F
« Reply #205 on: April 19, 2008, 03:34:22 PM »
Not all of them died that way. One was killed by an unfortunate gardening accident if I recall.
Offline Rsnip988
« Reply #206 on: April 19, 2008, 05:02:39 PM »
Did your Dyna hook up ok?  your wiring looks like mine I installed.
I only hope the high heat didn't mess up the magnetics of the peices....
Thats a quick rebuild Spikey, I admire your tenacity/dedication.   And that thing looks nice
RKS
R.K.S.
1976 CB750 K6 Full
1976 CB750 K6 Cafe'ish
« Reply #207 on: April 19, 2008, 05:55:37 PM »
RKS
i too am a little concerned about the magnetics of the ignition, i'm not at a point were i can test it, once all the harnesses are connected i can mare sure everything works , hopefully later tonight or tomarrow
it's going so quickly because 1. i've done most of it once already ;) 2. it's getting nice out and i really want to ride it  ;D
« Last Edit: April 19, 2008, 05:57:17 PM by spikeybike »
Offline .RJ
  • homebase in your airspace
« Reply #208 on: April 19, 2008, 06:10:32 PM »
When you get it hooked up, you can make sure its working with a test light, per the dyna instructions.
« Reply #209 on: April 19, 2008, 06:29:37 PM »
good point , waiting to put the kid to bed , or i'd be out doing it right now
Offline heffay
« Reply #210 on: April 19, 2008, 06:32:41 PM »
wow rsnip!  you're still around!
good to see ya.
Offline Ingrid
« Reply #211 on: April 21, 2008, 03:34:12 AM »
Must compliment you on your choice of (Belgian) beers thought! 8)
Here in the UK, Stella = Wifebeater, usually drunk on a Saturday night by the knuckle draggers.
What you need is a nice cask ale!
but what if i'm a knuckle draggin wifebeater  ;D
Stella might not be my choice either but for the special beers I was looking at the Delerium Tremens under the Stella...
Always like them special beers :P
troppo
« Reply #212 on: April 21, 2008, 03:38:16 AM »
I always thought the Delerium Tremen came AFTER the stella  ;D
« Reply #213 on: April 21, 2008, 04:15:24 PM »
i personaly like to start with a few Delerium's , then move on to something lighter , like stella
Offline Rsnip988
« Reply #214 on: April 22, 2008, 06:20:34 AM »
good to see ya.
Just haven't had much time for anything lately
rks
R.K.S.
1976 CB750 K6 Full
Offline mkramer1121
« Reply #215 on: April 22, 2008, 08:17:18 AM »
Manny,  you still coming on the Crud Run w/ us?  I've got a new chain coming for my 550 this week, and I'll tune it up this weekend, let me know.
« Reply #216 on: April 22, 2008, 01:46:18 PM »
unless my babysitter arrangements fall through (unlikely, but possible) i will be "in there, like swimwear"
Offline goon 1492
  • Sucka Repellant
« Reply #217 on: April 23, 2008, 09:43:50 AM »
hows the sled comin?
Offline JLeather
« Reply #218 on: April 23, 2008, 10:02:39 AM »
Meh, I'm a dark beer fan myself.  Darker the better.  Unfortunately it's tough to find a good stout out here in the States.  I had one from the UK once that was "Harviestouns Old Engine Oil Reserve" that wasa cask-aged stout.  Pretty good.  I need someone from some other continents to get me a good local stout sampler together.  Anyone ??? :D
Offline mystic_1
  • 1970 CB750K
« Reply #219 on: April 23, 2008, 10:13:38 AM »
MMmmmm!  Sounds tasty!
mystic_1
- John Augustus Shedd
« Reply #220 on: April 23, 2008, 05:38:35 PM »
well its almost all wired, my camera is getting fixed, i should get it and have some shots up by monday, i'll most likely have the front end all buttoned up by then, just got my new ss brake cable from dennis kirk today
« Reply #221 on: April 23, 2008, 09:04:19 PM »
i finally got the, main harness and it's attachments all together, stuck in the key turned it .....  nothing   :'(
 wasn't a big suprise really, ... anyway so as soon as i turn the key the main fuse pops , of coarse this could be a bunch of things.   but it's late and i have to work in the morning bla bla bla so i just called it a night
so someone call out were i should start tomarrow, and i'll go down from there till i find it ;) :D
  ***hope my multimeter still has juice ;D***
« Reply #222 on: April 23, 2008, 10:37:07 PM »
Make yourself a test light.
A twelve volt bulb with two wires soldered to it and alligator clips attached to the wires.  These are handy to static time points, but...
Attach your new test light to the fuse clips INSTEAD of the fuse.
Any shorts in the wiring will make the lamp burn bright when you turn the key on.  But, the bulb will limit current through the circuit so things don't fry.
Now divide and conquer.
Start disconnecting things until the lamps dims or goes out.  You've found the circuit with the problem.  Chase the wires in that circuit to find the mis-wire or short.
« Reply #223 on: April 24, 2008, 07:39:12 AM »
that is essentially what i was gonna do , but i didn't think of a test light.
so basically a short will burn the light bright, and no short it will be dim (ignition on)
the more i think about this method the more i think it would've taken forever with a multimeter
Offline goon 1492
  • Sucka Repellant
« Reply #224 on: April 24, 2008, 09:18:08 AM »
man two tired I think about half of the people on this site would like to dissect your brain, your like a walking mechanical/electricial/sohc encyclopedia. ;D ;D ;D ;D ;D ;D
