Author Topic: "INSPIRATION GALLERY "  (Read 2390632 times)
Re: "INSPIRATION GALLERY "
« Reply #8250 on: July 05, 2012, 01:47:09 PM »
i really gotta thing for ironhead bobbers ...   maybe someday i'll make one
http://www.bikeexif.com/harley-ironhead-dp-customs
Offline Oette
« Reply #8251 on: July 05, 2012, 02:05:07 PM »
I usually don't like this type of bikes, but this turned out sweet!
Offline jett
« Reply #8252 on: July 05, 2012, 03:50:36 PM »
i really dig that fender ...  ... very very clean indeed ... so whatda think of those gauges . i have the same ones on my KZ and i don't really care for them .. they look good , but dont work for jack
I have the same gauges and feel the same.  They look great but work so so.
Jett has the rear fender been modified?  Or is it stock?
Thats the stock rear fender.  The shocks are shorties.  I choked up a bit on the forks to match. Used risors so I could mount the straight bar.
Offline the technological J
  • deliciouso!
« Reply #8253 on: July 05, 2012, 03:56:19 PM »
good luck getting one for free spike!
jett what master cylinder you using?
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline jett
« Reply #8254 on: July 05, 2012, 04:05:43 PM »
I'm using this master cylinder from Dime City...
http://www.dimecitycycles.com/vintage-caferacer-cafe-racer-bobber-brat-chopper-custom-motorcycle-brake-parts-aluminum-universal-hydraulic-front-brake-master-cylinder-perch-lever-kit-717-601.html
You have to use the bikes original banjo bolt - you'll never get a proper bleed otherwise.
Offline veloracermike
« Reply #8255 on: July 05, 2012, 05:08:56 PM »
Got the same one off eBay for 49.00, the seller is always on there.  I used the bolt that came with the MC with steel braided lines from the seller who advertises on this site (I'd find the link but the stupid search engine on this site hasn't worked for me in months) and I got a great bleed and nice feel from the lever.
« Reply #8256 on: July 05, 2012, 05:33:47 PM »
actually i was talking about the front fender jett
« Reply #8257 on: July 05, 2012, 05:35:32 PM »
Someone was an Ayrton Senna fan.
« Reply #8258 on: July 05, 2012, 05:36:14 PM »
Looks like a shortened stock front fender.  Yes?
Offline jett
« Reply #8259 on: July 05, 2012, 05:39:23 PM »
Re fender - the front is a universal unit from jpcycle.  Mounted to the original bracket.  Tried to save the original but failed.  This one is not as wide.
« Reply #8260 on: July 05, 2012, 05:40:16 PM »
yeah thats what i like about it .. thanx
« Last Edit: July 05, 2012, 06:00:56 PM by Spikeybike »
« Reply #8261 on: July 05, 2012, 05:56:21 PM »
Jett for doing so little you've really achieved a lot...this is one of my favorite bikes I've seen on this site.
Offline jett
« Reply #8262 on: July 05, 2012, 05:58:07 PM »
Thanks - that means a lot.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #8263 on: July 05, 2012, 06:10:25 PM »
There is no way on earth I would ride that. First time you hit the brakes hard you lose your nads.
« Reply #8264 on: July 05, 2012, 11:05:45 PM »
 last pic is a shovelhead, someone called it a Sporty on the previous page.
 The yellow and Green rigid Sporty up above.. I dont call that a bobber..its what we called digger style, or streetracer... used to be gobs of them a Sturgis.. my 836 chopper was built in that style..
« Reply #8265 on: July 05, 2012, 11:15:22 PM »
While we're on the subject of HDs, did you see this one, Frank? Lovely bike from a new member...
« Reply #8266 on: July 06, 2012, 03:45:33 AM »
That's a hell of a build.  What frame did he use?
Offline Tintop
« Reply #8267 on: July 06, 2012, 05:35:01 AM »
Looks like a featherbed.  Probably one intended for a Vincent.  Just can't understand why people put huge work into building a performance bike, then put antiquated tires on them. ::)
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #8268 on: July 06, 2012, 06:28:03 AM »
Thats the first thing I thought of when I saw this bike. Shame as it looks like it would handle with good tires.
Offline Doctor_D
« Reply #8269 on: July 06, 2012, 07:50:31 AM »
+2  First thing I noticed as well.
Nice Norley otherwise.
« Last Edit: July 06, 2012, 07:53:04 AM by Doctor_D »
Take care,
David
1978 CX500
1971 Norton Commando
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #8270 on: July 06, 2012, 09:11:15 AM »
Freakin Goregous...But, if you look at the forward most holes in the LHS brake rotor, kinda looks like someone did a crappy job on the drill spacing...maybe there's a pattern to it, but I don't see it.
« Reply #8271 on: July 06, 2012, 10:43:23 AM »
your right .... and the discs don't match each other ....
Online Godffery
  • Godffery's Garage
« Reply #8272 on: July 06, 2012, 11:53:43 AM »
Those are KZ Wheels & Rotors.
They come that way stock form the factory.  Could never figure out why.?
Best I could come up with was, they had just started Drilling Rotors in the late 70's and may have thought uneven spacing was better some how..?
« Reply #8273 on: July 06, 2012, 12:29:22 PM »
Many bikes of then had oddball hole patterns. Personal experience with GS400/450, looked like that. Beats me.
Offline Flying J
« Reply #8274 on: July 06, 2012, 12:49:04 PM »
Harley still does it. Look at this fatboy rotor.
