Author Topic: CB750K4 - new update 28 June 2025- tachometer troubles  (Read 165338 times)
PS When did Franken-Joe start making air-boxes? 8)
This was a one off chrome dip on an old air box I had lying around. Been sitting on the shelf for years.
I have no idea where Anders chose to ground the charging system. ;D It might even be directly at the battery - terminal? In any case, they didn't need to be removed, and in the older pics the plug is visible unplugged and supported by the wires. You should be good to go.  ;)
Yes....directly to the negative battery terminal.
Thanks Mike!
Got it, one lead battery term negative and other to battery positive terminal. Writing this for future ref
Offline newday777
Thanks Mike!
Are they both green wires Andy?
Stu
My current rides
Prior bikes....
Thanks Mike!
Yes they are
Ok answered my own question with help from Ricks
Re: CB750K4 - new update 31 May 2025 - runs and charges again!
« Reply #330 on: May 31, 2025, 10:19:53 AM »
After a long winter, reinstall of the new stator went well, hooked up the reg/rec as described above and finally came the point of firing the bike up - first time with volt meter reading a healthy 14.4V  ;D Will get a test ride once it stops raining!
Success!
« Reply #331 on: May 31, 2025, 10:27:48 AM »
Bravo!
:D
Offline Alan F.
« Reply #332 on: May 31, 2025, 10:49:58 AM »
Nice work Andy.
Offline newday777
« Reply #333 on: May 31, 2025, 11:40:04 AM »
Excellent Andy. Gold 🌟 for you
Stu
My current rides
Prior bikes....
« Reply #334 on: May 31, 2025, 12:20:21 PM »
Good news, Andy ;D
A wonderful feeling to trust the bike (or car) for a longer ride without being stranded somewhere.
« Reply #335 on: May 31, 2025, 12:34:13 PM »
Success!
Great job Andy!! What rpm range did you get 14.4V?
I miss all your past riding adventures!
« Reply #336 on: June 01, 2025, 08:30:57 PM »
Success!
Idle
Offline Johnie
« Reply #337 on: June 02, 2025, 06:42:58 AM »
Way to keep on it Andy!
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #338 on: June 02, 2025, 12:46:38 PM »
Success!
I measured mine this afternoon and it was 14.3 V at around 1,600RPM (idle for me) Jerry.
« Reply #339 on: June 04, 2025, 02:44:09 PM »
Good news, Andy ;D
I completely agree!! Probably the first test ride will be a 7hr round trip to Vermont for haggis  8) Im hoping for this Sunday  ;D
« Reply #340 on: June 04, 2025, 02:44:54 PM »
Success!
Same as Mike 14.4V  8)
Thank you Jerry I miss them too!
« Reply #341 on: June 04, 2025, 02:45:32 PM »
Thanks Johnnie you are an inspiration  8)
« Reply #342 on: June 04, 2025, 02:46:25 PM »
Success!
If it wasnt for Mike I wouldnt have running bikes at all  8) ;D
« Reply #343 on: June 04, 2025, 07:30:50 PM »
Success!
Mike has inspired and helped us to upgrade our engines! ;D
Re: CB750K4 - new update 28 June 2025- tachometer troubles
« Reply #344 on: June 28, 2025, 10:45:17 AM »
Well after 96,000 miles and 51 years my tachometer has stopped working and is stuck at 4000rpm. Verified that its not the cable. Are their any easy remedies for a stuck tach?
Thanks
Andy
Offline newday777
« Reply #345 on: June 28, 2025, 01:32:58 PM »
Thanks
Andy
We can try a dead blow hammer tomorrow!
Stu
My current rides
Prior bikes....
« Reply #346 on: June 28, 2025, 04:48:09 PM »
Thanks
Andy
I have a box of speedos and tachs brother....some have the exact "patina" of the one in the pic. I'll look tomorrow and send you pics.
« Reply #347 on: June 29, 2025, 12:58:02 AM »
I have recently seen that when testing 2 sets of K2 gauges in parts before sending them to Germany for repair/restore and closing them.  (Forum member "fire113")
I'm in the process to pack all parts... ;)
One tacho needle got stuck at a few thousands of revs direct during a ride.
- The bearing for needle shaft is worn out.
Possible to wiggle sideways. To be replaced when restoring.
The needle can move back when the gauge is held horisontal. Mine slowly did.
« Last Edit: June 29, 2025, 01:03:04 AM by PeWe »
« Reply #348 on: June 29, 2025, 05:07:38 AM »
Thanks
Andy
Oh thank you Mike that would be great!
Looking at a couple that Stu has today - sorry will miss you this weekend! Hope to see you soon!
« Reply #349 on: June 29, 2025, 05:09:01 AM »
Ah this is good to know thanks Per and will def try this. Who in Germany is restoring speedos/tachs?
