Author Topic: my CB750F build into a CR750 cafe  (Read 60962 times)
Offline jaguar
« on: May 04, 2008, 01:39:40 PM »
ive been building and posting for awhile now and i figure its time to post some pics and get some feed back.
as she started
CR tank with spray bomb job
new paint.  nissan/infinity black metalflake
im rebuiling the front end right now and hope to get the frame powdercoated this week.
i have almost every part that i need to put the bike together.
cant wait to start final assembly
« Last Edit: April 26, 2010, 09:50:00 PM by jaguar »
Offline bigsherm
Re: my CB750F cafe project
« Reply #1 on: November 22, 2008, 10:04:39 AM »
Jaguar-
How'd this turn out?  I love CR replicas!
Sherm
Offline jaguar
« Reply #2 on: November 30, 2008, 04:05:56 PM »
the frame is having the removable frame kit installed.  motor is being gone though too.  my other bikes, school, and work slowed the CR down alot but ive colected almost everything i need to start building. i hope with some time off for xmas i can get her to a rolling bike.
Offline jaguar
« Reply #3 on: March 25, 2010, 10:08:06 AM »
as all builds this one is taking way more time and money then i thought.
school work and life have gotten in the way but im back on the project with the hope that its on the road this summer
frame has been powder coated in a dark red/marroon.
progressive front and rear suspension
TTR400 parts
-pre loaders
-top nut
-chain adjustors
-oil nut
-head light ears
dyna 2000
dyna 2.2 coils
hondaman resistors
Tarozzi rearsets
Tarozzi front fork brace
XSmike fork cartridge
swing arm needle bearings
all balls wheel bearings
all balls steering bearings
Cycle X front forks
Gordon frame kit
airtech CR750 tank and seat
Daytona steering damper
lester mag wheels
-19 front
-18 rear
1982 honda OEM twin piston calipers
W clipons
handle bar mounts shaved
all clips and such were cleaned and shaved off frame
every nut and bolt has been cleaned or replace
seals and rubber parts were replaced with OEM parts
thinking about running
dunlop GT501 tires
Trailtech Vapor digital dash
DDM HID headlight
still need to figure out wiring and lights
havent even started on building a motor to go with the build, just have a solid stocker for now.
sitting on my IKEA motorcycle stand
Second floor apt...lol
parts back from the coater
Forks are being build next.  will have more pics
really like these Tarozzi parts
Tank sitting on frame
waiting for the wheels and forks to go on.
thinking about doing the lesters in a bronze color.  what do you think?
Offline UK Pete
« Reply #4 on: March 25, 2010, 10:59:13 AM »
Thats looks good man , keep up the hard work
Pete
Offline jaguar
« Reply #5 on: March 26, 2010, 07:25:35 PM »
lesters.
im thinking more and more about painting them bronze
going to order tires this weekend
bearings and some other bits will be here soon
next is put together the forks
Offline KB02
« Reply #6 on: March 27, 2010, 04:56:03 AM »
I say leave them black.
Looking good so far, man. Get it on the road!
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline jaguar
« Reply #7 on: March 27, 2010, 07:19:48 AM »
at this point in the build everything is new or painted so i dont want to leave the wheels they way that they are.  they are very clean but not new like the rest of the bike.
i dont really know what im going to do with them yet
ordered the vapor dash
is there a spacer to delete the speedo pick up on the axle?
the vapor uses a magnetic pick up so the speedo assembley would just sit on the axle doing nothing.
any ideas?
Offline jaguar
« Reply #8 on: March 29, 2010, 01:00:11 PM »
cleaning up the calipers.
they are OEM twin pistons that bolt on with the right OEM brackets
anyone have a good place to get pistons and seals?
Offline jaguar
« Reply #9 on: April 06, 2010, 01:52:12 PM »
go the calipers cleaned out.
need to order seals and such.
32mm twin piston fronts
still am thinking or figuring a way to use a twin piston rear too
cleaned up the fork tubes
cycle X legs
going to get them together tonight or tomorrow.
have all the OEM honda seals
points if you can name the block that my coffee table is made out of.....lol
rear master cleaned and painted.
ready for rebuild and install
new digital tail tech dash
i printed it all out to make it easier to build the bike and not get my macbook dirty.
Offline jaguar
« Reply #10 on: April 06, 2010, 03:08:21 PM »
i cant get the bearings out of the lesters so when the tires come in ill try and see if the local honda dealer can press them out and swap the tires
i need to order more OEM honda parts anyway
i dont know why but i cant get the bearings out.  tried using a drift and alittle heat but nothing
also ordered a indicator dash for the vapor
tires will be Dunlop GT501s
Offline KB02
« Reply #11 on: April 07, 2010, 05:09:05 AM »
As for your rear brakes, the stock F1 rear caliper was an opposed twin piston job. I always found that funny on my F1 that I way more stopping power on the rear that I did up front. Not sure if one would fit with the lesters or not, though...
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline jaguar
« Reply #12 on: April 07, 2010, 07:32:42 AM »
the lesters are off a 78f so that used the single single piston rear.
i have that brake set up, the set up from the 76f that has the oppisite twin piston and then the rear off a GL1100 that has the twin pistons that are next to each other.  make any sence?  no?  yeah im lost after reading that too...lol
ill try and post pics of the rears that im talking about
Offline jaguar
« Reply #13 on: April 15, 2010, 09:02:02 PM »
got the forks together.
mounted up the new Dunlop GT501s.
had the local guy install the bearings.......WOW
he charged 3 hours labor to install the bearings and swap the tires.  i thought that was a bit much.
also the dash for the trail tech came in.
ill get more pics asap
Offline jaguar
« Reply #14 on: April 18, 2010, 07:45:20 AM »
forks are together
mocked up the bracket to mount the twin piston calipers on the front
also looking into making the rear twin piston caliper work but im still not sure
now going to work on getting the rear wheel mounted, rearset on and rear master rebuilt
Offline jaguar
« Reply #15 on: April 26, 2010, 09:49:15 PM »
painted up the front brake bracket
put the rear wheel on
mostly little stuff
found out that i cant use the rear twin piston set up as the bar support is on the wrong side so ill just run the single piston off a 78F
next is the rebuild the calipers and master.
then mount and finish the install of the rearsets
i had it down on its own wheels to sit on her and feel it.  im pumped
anyone have the TTR400 rear chain adjs?
mine fit funny and i wanted to know if its something that im doing wrong
Quartza
Re: my CB750F build into a CR750 cafe
« Reply #16 on: April 26, 2010, 10:09:03 PM »
The problem with the chain adjusters is that you have a F model swingarm. Its has a thinner axle dropout.  I checked the website out of curiosity and it only says the K models.  If you dont mind the warping it seems they are still getting the job done or add a washer.
« Last Edit: April 26, 2010, 10:31:16 PM by Quartza »
Offline SKTP
« Reply #17 on: April 26, 2010, 10:40:48 PM »
Great looking build and bike...do you have a link of more info about the "tail tech dash"? I googled with no luck. Looks like a nice little unit.
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline jaguar
« Reply #18 on: April 27, 2010, 03:45:20 AM »
i didnt realize that the F and K swingarms were that different.
i mocked it up with a washer and it seemed to be much happier.
dont think that there is any reason not to use a washer, right?  there isnt much force on them, right?
trail tech
http://www.trailtech.net/
sorry.
thanks for all of the help
Offline jaguar
« Reply #19 on: May 02, 2010, 11:49:35 AM »
so the rear mount for the twin piston caliper was off a GL sooo its upside down to use on my bike....Duh
i found a bracket off a dohc 4 so that should work.  ill have to wait and see.
painted up the calipers copper/bronze and i dont like the way that they look.....Duh again.
i think that i will just have the brackets and calipers power coated to match the other black parts on the bike.
had to lower the front fender alittle to clear the fork brace.  i thought that it was ment to just bolt on but it wouldnt so no big deal.
next is to mount the tank and do some wiring.
going to order the brake rebuild parts and some other oem stuff i need this week
also going to run the TTR400 headlight ears too.  they really do have such nice stuff
Offline jaguar
« Reply #20 on: May 19, 2010, 06:38:08 PM »
just got my TTR400 headlight ears in.
those guys are sooo great.  its beautiful
packing up the calipers, brackets and masters to ship to my coater
OEM pistons and seals are in the mail to finish the brakes
also going to order SS lines
i messed around with a fender that i had and didnt like it.  then started playing with the stocker to see it that would work......then i called GFTP and ordered a dunstallish front fender...lol
ordered a CBR600 front master to work with the 32mm calipers
started to fab up a mount for the dash.  going to finish that this weekend
Offline Flying J
« Reply #21 on: May 19, 2010, 07:14:43 PM »
I like it!
Offline jaguar
« Reply #22 on: May 22, 2010, 03:56:49 PM »
thanks very much.  ive watched your builds, very nice
got the oil tank painted and installed.
mounted the trail tech dash
next is to figure a nice spot to mount the dyna 2000 and steering damper.
also will need a horn.
just got in my finned starter cover to go with some other finned parts for the motor
also some other cool bits from TTR400
Offline jaguar
« Reply #23 on: May 23, 2010, 01:53:20 PM »
had a few questions about the twin piston front calipers.
its a bolt on set up with the right brackets.  i call it OEM+
most of the time it is refered to as using 1982 cb900F brakes and brackets.  if you cross the honda part numbers it comes up with a very long list of bikes that used the brakes and brackets
i myself and using the magna(and other honda) calipers.  they are 32mm rather then the cb900f, they are 30mm
i am also trying to run the rear twin piston set up.  this has been alittle harder but i think that i have it sorted.
the 82 cb900F rear bracket seems to line up with everything so far.  i have not heard of anyone upgrading the rear brakes as they are already more then enough but i wanted to for looks and ease of parts ordering latter.  but thats why im not sure that the rears will work
as for the fronts there are a few guys that have done it and really love the extra stopping power
this is the brackets to show that they have the same bolt spacing
i have other pics in the thread showing the fronts mounted
also had a question about the rear seat
its and airtech seat with their pan
Offline jaguar
« Reply #24 on: May 26, 2010, 11:49:32 AM »
starting to polish the controls
