Ok, a couple of weekends, but lots of progress. As we left you last, Hondaman had pointed out to me that my fork seals were upside down. So, I went back that next weekend, pulled my seals and I thought flipped them over…. Well, not quite, somewhere along the line, I put them back in their original positions, because, I did not refer to my original photos. Well, long story and many head-butts against a hard metal surface, they are now in correctly.
When using the All-Balls seals MAKE SURE THE RECTANGULAR “HOLES” ARE FACING YOU!!!!!!!!!! Yes, I am yelling this, but at myself, not you guys!
I then proceeded to time the Camshafts. Not a lot of pictures here, but you need to remember that getting the side covers on is paramount. On the intake side, the timing is easy, on the exhaust, don’t be afraid to manhandle the camshaft into position. BTW, Honda… your timing marks on my bike SUCK!!!!! But I got it despite you, and thanks to
http://www.hondatwins.net/forum/viewtopic.php?f=29&t=781, without which, your service manuals do absolutely no good….
Got it done, and life is good!
Shop Dog was very happy about the whole affair…
So after running the engine through some revs, I heard the wondrous “whoooosh” as the engine built up compression, but brilliant as we are, I forgot to set the valve clearance. I did hit 95 – 110 PSI without, so I am pretty hopeful…
So my buddy pointed out the hard work we did Zoop Sealing the Aluminium, that the stainless bolts looked dirty in the allen heads, so after much beer and bravado… we came up with this – the Q-tip has brake cleaner on it.
Works great, BTW….
Zoop Seal shows a lot of promise, BTW…
I got the engine together, here are some views…
Now. I have to set the Valve clearances, and then I have to learn how to weld, so that I can make the mounts for the 550 Seat. Once the brackets are welded, the frame and lower triple will get PC’d black and then the tins will be painted Candy Bacchus Olive.
