Author Topic: 1972 CB450 "Supersport" NOW SHE REALLY LIVES!!!!!  (Read 116569 times)
Offline dagersh
    • Photos
Re: 1972 CB450 "Supersport" .....Honda, but not SOHC, and not a four
« Reply #25 on: July 18, 2009, 12:38:29 AM »
Here are the sanding pads
Here is the bike in its present state of affairs
What's up with these wear marks on the tire.  Very deep, they will need to be replaced!
« Last Edit: July 20, 2009, 03:31:33 PM by dagersh »
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline dagersh
    • Photos
Re: 1972 CB450 "Supersport" Grenade!!!!!
« Reply #26 on: July 19, 2009, 09:39:50 AM »
So, after getting inspiration on how the carbs were looking, I wanted to try my hand at polishing the engine covers.  I had the sproket cover off many times, so I tore into that one first.  I originally attempted to see what a soda blast would do for the oxidized finish - but it did not do much at all.  I put my pieces in the sun until they were warm to the touch.  At the time, I had no Acetone on hand, so the black residue made the job harder.  When polishing, wiping down the piece with Acetone, will make your job so much easier, and you get a pretty quick idea of just how good your results are going to be.
Also, I was not using a mask, and I am seriously concerned about the fibers being thrown into my face, so I will be wearing one as well as safety goggles any time I am on the buffer.  Actually, I learned the relatively hard way to ALWAYS wear eye covering - a shot of carb cleaner in the face, up your nose and in your eyes is a wonderful cure for forgetting to done your safety gear....  Holy He!!, that hurt like a ...  well you know.  Fortunately, not real damage!
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline dagersh
    • Photos
« Reply #27 on: July 19, 2009, 09:51:07 AM »
Anyway, on to the pics:
The sprocket cover:
The Alternator cover:
The sprocket cover - the one on the left has been buffed out, but the pics don't do it justice:
The Buffer:
So I then wanted to move on to the Alternator housing.  I should note, that when I drained the oil, there was a ton of copper and brass in the pan.  I realized something was way amiss, but as this is an educational project, I would cross that bridge when i came to it...  Here is the bridge...   ::)
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline dagersh
    • Photos
« Reply #28 on: July 19, 2009, 10:00:39 AM »
It would seem that the Starter Clutch Plate Grenaded inside the housing.  Ouch.....
Weird, though, the bike did not have any charging problems prior to the tear down.  It was pretty nasty in there, and I don't have a puller to get into it further.  Anyway, hopefully I can find the pieces and make the repair. Furthermore, the wires coming in from the harness, did not seem to be connected to anything.  Do they just make contact with the spinning copper windings?
I wanted to clean up the damage as best as I could, so I cleaned out the metal filings and detrached the Stator from the assembly.  Cleaning the rotor was no fun, as there were a ton of razor sharp filings stuck to the magnet...  I must say, I am having a blast!!!!
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline fastbroshi
  • Puppet
« Reply #29 on: July 19, 2009, 10:12:45 AM »
   Very cool dager, though I have to ask did you move some of your pics?  Because all I see is the photobucket logo for a lot of the above.
Just call me Timmaaaaay!!!
Offline dagersh
    • Photos
« Reply #30 on: July 19, 2009, 10:21:34 AM »
The Right Crankcase Cover that houses the Rotor and Stator and Starter Assembly cleaned up very nicely after getting rid of the grenade damage.  One of the problems i see on this bike was the PO's did not maintain it nicely.  All the gaskets are very brittle and and now I see why the bike was constantly pissing oil.  I sprayed the Seating Surface down with gasket remover and set it aside to bubble and foam.  While waiting for that, i pulled off the points cover to get the polishing treatment.  At this point in time, I had Acetone, and it really made it an easy job:
Before:
After:
This took no longer than 5 minutes between the Tripoli and Rouge steps.  I then set the cover aside and went to work on that softened gasket.  Very carefully I used a sharp razor blade to lift the gasket off.  It was slow progress, and remembering a step from my modelling days, if I wanted to remove a molding seam from plastic, instead of leading with the blade, I pulled the blade towards me, dragging it over the surface.  it worked very well.
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline dagersh
    • Photos
« Reply #31 on: July 19, 2009, 10:26:07 AM »
Fastbroshi - no, I did not move any.  I just logged off and checked, and they seem to coming up for me as a Guest.  Anyone else having trouble with the pics?
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline dagersh
    • Photos
« Reply #32 on: July 19, 2009, 10:39:16 AM »
The dragging of the Razor over the surface, did not remove all of the gasket, and what was left was so thin, I was hesitant to try the sharp part of the blade.  So I threw the cover into the blaster.  The soda took it right off and left a very clean surface with absolutely no damage!  I am really loving this machine, it makes it very easy to get little things done, and it has instant gratification!
The CC:
The Blasting Cabinet, BTW -
I then decided the carbs could use some more work, so back apart and to the buffer:
I still have to hit the polished parts with some aluminum polish, and carnuba wax, but they look spectacular..
Off to do the clutch cover today!  More updates later.  Also, let me know if these pics are not working!!!
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline Caminokid
« Reply #33 on: July 20, 2009, 07:51:06 AM »
I have always loved these bikes as well as the 750. Good progress you are making. I had a few of these that were between 69 and 74. Lots of get up and go power. The later 450's cant compare to the dohc 450's.
I have been using soda for blasting. Wish I had a cabinet to do it in. The driveway always looks like its been snowing! LOL. The up side to it...If I dont clean it up right away...and it rains...the driveway gets really clean and brighter after I power wash it.
I dont see the pics either. They just say moved or deleted.
God created man...Winchester and a baseball bat made then equal. Evel Knievel
Offline dagersh
    • Photos
« Reply #34 on: July 20, 2009, 02:33:51 PM »
Weird, the pics work for me when I am logged off, and I checked with cafe2be, and he had no problem viewing them.
I will check again from my work computer....
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline dagersh
    • Photos
Re: 1972 CB450 "Supersport" Pictures Fixed!!!!!!!!
« Reply #35 on: July 20, 2009, 05:54:08 PM »
Fixed the picture links, hopefully they now work for everybody!!!
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline fastbroshi
  • Puppet
Re: 1972 CB450 "Supersport" Pictures Fixed!!!!!!!!!!!
« Reply #36 on: July 20, 2009, 06:50:49 PM »
yup there they are. Sweet caddy!
Offline dagersh
    • Photos
« Reply #37 on: July 20, 2009, 07:37:48 PM »
Not mine, but living at my house.... ;D ;D ;D
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline dagersh
    • Photos
Re: 1972 CB450 "Supersport" Finally a worthy update!
« Reply #38 on: August 30, 2009, 06:06:01 PM »
So much stuff in the way of working on this bike.  I really wanted to have it done for Rice-O-Rama, but the best laid plans.... and all that.
Well, finally today I had a chance to work on something at least.  I cleaned and polished the caliper.  It was wicked disgusting, with slop the consistancy od Maple Syrup sitting beneath the piston.  Fortunately, the piston is in great shape, and the caliper cleaned up nicely, with special attention paid to the groove.  i used Denatured alcohol in conjunction with tin foil to clean out the interior.  I then decided I wanted the bodies polished so I quickly stripped the mottled paint with my trusty media blaster.  I use soda, and it fairly ripped the paint right off the caliper.  Lierally, it took less than 10 minutes to do both bodies and clean up the hard tube that runs from the caliper to the brake line.  I then put them all under the buffing machine, using Tripoli and then Rouge.  I am very happy with the results and will further the process with Simichrome and Mothers Aluminum polish.  I will continue on with a rebuild and polish of the MC.
Here are some pics:
After the Blasting Cabinet
a shot of the groove
After Tripoli and Rouge
Got the bolt heads
The hard line came out great!
A Preview of what's to come....
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline fastbroshi
  • Puppet
« Reply #39 on: August 30, 2009, 06:52:20 PM »
   Alright looking good.  I'm a fan of the 450s, they're hard to come by though.  Keep up the good work.
Offline MarkoVisacki
  • Buy the ticket, take the ride
    • SMK KLASIK - Vintage motorcycle racing club
« Reply #40 on: November 12, 2009, 12:33:14 AM »
Beautiful project.
Here's one cb450 k5, literally made from nothing. She was lying IN the ground for about 20 years, so there wasn't even one screw that was usable...
Friend of mine  invested enormous amount of work and money, in order to drive her on Vintage racing championship...
450's are fast bikes, but "Four" machines are far more endurable.
2004:
2009:
« Last Edit: November 12, 2009, 12:37:17 AM by MarkoVisacki »
« Reply #41 on: November 12, 2009, 05:25:25 AM »
Very cool race photos and I like the before and after shots!
where do you race?
cheers
Andy
Offline Aaron Richard
  • 1975 CB550 cafe
    • shop
« Reply #42 on: November 12, 2009, 06:04:53 AM »
can I move into your garage! :D
Offline dagersh
    • Photos
« Reply #43 on: November 16, 2009, 07:11:15 PM »
Schiznitz,
I have so many borders already....  all my friends help me work on the bikes and at the same time their own cars.  Lots of fun, much cerveza consumed...
Updat eon CB450 being put together as we speak.  Lots of work over the past 2 weeks.
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline dagersh
    • Photos
Re: 1972 CB450 "Supersport" A mass of work and Pics!!!!
« Reply #44 on: November 16, 2009, 08:29:46 PM »
Hi All,
It’s been too long as usual.  Different projects in the way.
Over the last couple of weekends I have thrown myself into the 450 project.
The bike has been stripped down and I am ready to remove the engine and prepare it for complete disassembly.
As you can see the chain sprocket area is a mess.  But it will be dealt with later on.
I took as much off the engine as I could to lighten the load to get it ready to put into the engine stand.
The engine stand was purchased off of Ebay, and I have a second cradle for CB750 engines that fits into the base (you can see it hanging on the wall in the background).  The tool cabinet fits under my workbench, so I needed to make sure the surface stays flush when I am not using the engine stand.  To secure the stand to the base, I drilled out holes for 3/8” threaded inserts.  The bolts are 3/8” X 1” and the stand is very sturdy on the 1” base of the work surface.  Later on, I had to crank on some bolts and the stand worked great!
Here is the engine in the stand, secured by the mounting bolts that hold it to its frame.  It’s a bit high, but I think it will be good for getting to the bolts underneath.
As we were maneuvering the engine to the stand, this fell out…
It holds the lowest cam chain guide on the engine.  As it turns out, it was lost the last time the PO was in the engine…  I only hope it was benign as later pictures will show.
Now that is a naked bike!
Removing the Cam Chain Gears and followers from the head.
The Cylinder is off
The Intake Cam and rockers
My buddy Lyman broke the drive train.  It was a B!7(!-!
A great tool – the Motion Pro Chain Breaker.  We did the Cam Chain and drive chain with it.
Meanwhile, here is the exhaust Cam…
The Rockers!  Cb450’s don’t have valve springs.  They move against Torsion Bars.
After a bit of a struggle, and a little easy banging with a screw driver and mallet…  one side is out!
Now for the valves…
My Tusk Valve spring compressor.  The Clymer manual will tell you to remove the torsion bars and then the valves.  I promise you it’s much easier to remove the valve first!  Much safer as well…
Using the 23mm attachment, and making sure the other end is secure in the dead center of the valve face, I slowly applied pressure to remove the holders.
Empty Head!  (Just like mine!)
At this point, when everything was out of the head, I hit it with some gunk to get the years of neglect off of it.  Worked Ok…
However, I figured my Soda Blaster could do much better..  and it did.
The Cylinder as it came off the engine:
More to come…
« Last Edit: December 16, 2013, 03:38:27 PM by dagersh »
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline dagersh
    • Photos
Re: 1972 CB450 "Supersport" More mass pics!
« Reply #45 on: November 16, 2009, 09:06:03 PM »
Remember, back when I took the stator assembly apart, the starter clutch had grenaded, leaving a mess of metal shavings.  Well….  The oil filter was full of them as well.  Strangely enough, the filter screen was relatively clean, and easily made spotless with some  Brake cleaner.
YUCK!!!!!!
Filter, Circlip and O-ring
Oil Filter, Lock Washer and Thrust Washer.  I buggered the lockwasher, hopefully I can order a new one…  It might be salvageable if not…  how important is it to be REALLY strong?
All that metallic gunk is hopefully only the remnants of the Starter Clutch.  The other piece that came out of the engine was pristine, so I don’t think it was banging around doing damage.  But we’ll see.
The Buggered Lockwasher:
The Oil Pump Screen:
More to come next weekend.  I plan on splitting the cases and inspecting the guts.
« Last Edit: December 17, 2013, 11:35:45 AM by dagersh »
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline fastbroshi
  • Puppet
« Reply #46 on: November 17, 2009, 05:13:03 PM »
   Cool to see the insides of one of those, pretty high tech for when it came out, torsion bars on the valves and all.  Do you have any pics of these pieces and how they work?
Offline dagersh
    • Photos
« Reply #47 on: November 18, 2009, 08:14:29 AM »
Hey FB,
The only dedicated pics I have are above, I will snap pics of the assemblies this weekend and post them.  Also, there will be more when I put her all back together.  I am going to attempt to follow Hondaman's Thought on the CB450 by grinding off one of the splines on the torsion bar, and setting them "tighter".  I think I will have to PM him for some more clarification on this!
I have also been talking with Marko Visacki, who helped his friend and fellow racer build and prep a 450.  On his reccomendation, I am going to bore 2mm over and install Kawi KZ1000R pistons and rings which are lighter.  This is the set up they are running, with much success and no mechanical issues.  Thanks Marko!
Anxiously waiting for the weekend...
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #48 on: November 19, 2009, 02:24:00 AM »
i've also heard of racers converting the heads over to use regular coil valve springs, not that i know anything at all about it other than that it HAS been done  :D
Mark Twain - Notebook, 1894
Offline dagersh
    • Photos
« Reply #49 on: November 19, 2009, 09:21:23 AM »
THR and M3 both make conversion kits for valve springs.  I am not sure what the benefit is, maybe just for racing.  However, Marko and his friend have been campaigning their 450 with only the overbored pistons and a free flow exhaust.
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
