Author Topic: my chain keeps going slack ?!  (Read 1996 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: April 16, 2009, 06:06:15 PM »
OK, what am I doing wrong?!?!
The chain on my K3 keeps going slack.
I tighten it to ~1/2' deflection like the manual says & set the tensioners.
2 rides later it has about 1.5" deflection.
Retighten, same thing again.
I had an old chain that I though was stretched beyond use so I replaced it with one of these
~600 miles later it's still doing it - same scenario.
The axle isn't slipping - I check the position markers on the drop outs.
So what's the deal?
What's about to blow up? Main drive shaft/gear? Rear axle?
WTF?
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: my chain keeps going slack ?!
« Reply #1 on: April 16, 2009, 06:27:08 PM »
Hows about a couple of photos of your present set up ???
Offline grumpy
« Reply #2 on: April 16, 2009, 06:32:11 PM »
Totally stock 750K3
Camera batteries are on the charger...
Offline kghost
« Reply #3 on: April 16, 2009, 06:36:39 PM »
Average tensile strength of 7,850 lbs
Suitable for up to 750cc max
I dunno....My two cents is that its on the light side for the CB750.
I'm sure someone will disagree but I like my chains in the 10,000+ side of tensile strength.
All new chains have a bit of stretch during break in....but continual issues with reoccuring slack sounds dangerous.
Stranger in a strange land
« Reply #4 on: April 16, 2009, 06:38:24 PM »
If you didn't change the worn sprockets, the new chain will quickly stretch to fit the wear pattern of the old sprockets.
Offline grumpy
« Reply #5 on: April 16, 2009, 06:42:27 PM »
Yeah, I thought the chain might be a little wimpy but I don't flog it. Just ride it to work....
Could be new chain/old sprocket syndrome...
Now I'm questioning whether the old chain was really bad.
« Last Edit: April 16, 2009, 06:46:05 PM by grumpy »
