Author Topic: cb750 racer build  (Read 5377 times)
Offline themotoworks
  • addict
    • roc city cafe racers
cb750 racer build
« on: April 25, 2009, 06:04:59 AM »
I've been working on a major summer project and posting on dotheton a lot, so i figured i'd share this here too... i'm building a 74 cb750, with alloy tank, seat and fiberglass race fairing which will have a vac molded plexi windscreen.  this has been a real learning experience for me, as I usually do the body work in fiberglass only.  I'm liking the aluminum though as one off parts don't seem to take as long to do... I'm mocking up the parts on another 750 i have still assembled, then moving them over to the new frame.
getting close to a finished swingarm, got the axle blocks back today from my machinist friend and they are KILLER!!! so I welded those up, forgot to tap one before I welded it and went DUH so now I'll have to come up with some kind of 6" tap extension before I can ride... got a 77lb piece of 1/2" plate steel for my jig too, seems to work really well, good and flat and great for clamping.  machined up my pivot tube too, it's got needle roller bearings and needle thrust bearings, and the swingarm is still 4lbs less than stock, should help the back end really stick to the ground!
tacking up the pivot tube to make sure everything clears before final alignment and welding, there's going to be a crosstube in there too, 2X1" al tube
Almost done with the body too!
almost done, just gotta weld on the shock mounts, and a tab for the brake bar and we'll be golden... I think had I had it all to do over again, I may have just powdercoated the old stock one....... I guess we'll see how much of a performance difference I get
all assembled, I'm actually going to do a more square alloy seat for it, the tank came out looking less round than I imagined, so now the seat doesn't quite match
« Last Edit: April 25, 2009, 06:11:55 AM by roccitycafe »
www.roccitycafe.com <- my sideline turned living
Re: cb750 racer build
« Reply #1 on: April 25, 2009, 07:18:24 AM »
Hey Sean,
Great looking swing arm.  I think your aluminum Dunstall seat looks amazing.  Fantastic finished look!
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #2 on: April 25, 2009, 10:35:22 AM »
It's a thing of beauty!
Keep us posted.
FJ
Offline ev0lve
« Reply #3 on: April 25, 2009, 11:11:40 AM »
Jaysus! This will be a righteous build. Subscribed!
  • addict
« Reply #4 on: April 29, 2009, 11:41:37 AM »
got the engine in!  starting to look like a bike now, and I love how there are so few extra things on this bike.  very minimal and light!
Offline cdoggy81
« Reply #5 on: April 29, 2009, 08:51:00 PM »
very cool!
« Reply #6 on: April 29, 2009, 09:23:14 PM »
Looks good,
 Hope you are running a hardened shaft or collars on them needle bearings, and  that you are heat treating that swingarm..
  • addict
« Reply #7 on: April 30, 2009, 04:30:52 AM »
the heat treater actually recommended a stress relief, I don't know if that restores temper, but I'll leave it in the hands of the pros
Offline papp101
« Reply #8 on: April 30, 2009, 08:31:15 AM »
Excellent build, can you give some more details about your process on making the Front Fairing?
  • addict
« Reply #9 on: April 30, 2009, 04:09:00 PM »
Looks good,
thinking more about this, the shaft is hardened, but there's no collar around the bearing unit, it's self contained and sealed, but do you think I should machine a bronze sleeve for it to distribute the load over a wider area?
Offline burmashave
  • Forum Immoderator
    • burmashave.net
« Reply #10 on: April 30, 2009, 07:00:58 PM »
Very impressive build! I'm looking forward to progress as well.
Quote from: SOHC Digger, RIP
'77 CB750k
Offline kghost
« Reply #11 on: April 30, 2009, 07:03:08 PM »
Shame you bondo'd that tank....Aluminium looks so nice polished.
Dig your swing arm....May do one like that on my build.
Looking good.
Stranger in a strange land
  • addict
« Reply #12 on: May 01, 2009, 12:29:07 PM »
yeah, it's one of my first tanks, so it wasn't perfect enough to polish and i meant for the whole bike to be done in honda red anyway
« Reply #13 on: May 01, 2009, 08:19:58 PM »
What I was getting at on the needle bearings was, if they are not shaft size, then you either open up the holes in frame, or build sleeves to take up the difference.. but that would be tricky as they would be VERY thin.
Bronze aint the anwer, the bearings have to run on a hardened surface.. to the best of my knowledge
  • addict
« Reply #14 on: May 02, 2009, 05:33:32 AM »
oooh gotcha, yeah, the bearings are metric, so they fit on the shaft perfect, and they're a press fit into the swingarm pivot
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #15 on: May 02, 2009, 11:40:14 AM »
       Have to agree with the others, about the quality of this build! :) So much attention to detail AND such features (swing arm, gastank, fairing, etc)!!!!!!!!!! :o 8) ;)
Member # 1969
  • addict
« Reply #16 on: May 05, 2009, 07:51:39 PM »
almost finished with the exhaust... header pipes are all figgered out, just have to get the 1&2 pipes done from the headers back to the megaphones
Offline b20z
« Reply #17 on: May 06, 2009, 01:20:55 PM »
Nice Build so far. What oil tank is that?
Offline 78CB750CAFE
  • I'm not really an
  • Ride, wrench, repeat.
« Reply #18 on: May 06, 2009, 02:16:27 PM »
wow.
lots of work you have in this so far, can't wait to see it done.
any interest in doing swingarms for others?
  • addict
« Reply #19 on: May 06, 2009, 05:18:13 PM »
wow.
actually I have to build a jig to do a rework on the swingarm... if I do that maybe I'll look into building more of them, offer them for sale this fall after I see how this one performs, not sure of the price point though, the machined parts and material costs plus labor would probably put them in the neighborhood of $6-700, think there's interest there?
Offline moham
  • .fnord.
« Reply #20 on: May 06, 2009, 09:15:40 PM »
What's the story with the motor? Have you done any mods there? Very convincing racer look so far. Something about a custom swingarm that turns heads...
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
  • addict
« Reply #21 on: May 07, 2009, 05:53:39 AM »
the motor is stock, just tuned up and checked over good.  the goal of this build was to get it done quickly, which is funny because it's been taking me a while since things have turned busy (not bad!!), i can't imagine how much longer it would take me with serious engine mods!! haha
