Author Topic: Rebirth of paulages' cb735  (Read 132974 times)
Offline JAG
  • '74 CB750K, '72 CB500, '76 550K
Re: Rebirth of paulages' cb718 bike
« Reply #225 on: February 22, 2010, 04:22:07 PM »
Can you touch the ground when sitting on the bike???
Cafe Racing is mainly a matter of taste. It is an atavistic mentality, a peculiar mix of low style, high speed, pure dumbness, and overweening commitment to the Cafe Life and all its dangerous pleasures. I am a Cafe Racer myself, on some days - and it is one of my finest addictions. ~H. S. Thompson~
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
« Reply #226 on: February 22, 2010, 05:43:21 PM »
toes. it's light though- 385# dry, about 405 fully wet.
« Last Edit: February 22, 2010, 05:47:58 PM by paulages »
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline Frankenkit
  • Industrial Strength
« Reply #227 on: February 22, 2010, 10:19:05 PM »
wow. 100# lighter than mine dry, then, I think.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline paulages
  • 1976 cb735
« Reply #228 on: February 22, 2010, 10:37:38 PM »
to be fair, i weighed it with a full gas tank and oil in the engine, and it was 406#. i calculated the weight of 5 gallons of gas and 3.5 qts. of oil to come up with the dry weight.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline cb650
« Reply #229 on: February 23, 2010, 05:00:07 AM »
I dont feel to bad a bout the old drag bike now.  It was right around 400.
Yours turned out very nice!!!!!!!
traveler
« Reply #230 on: February 23, 2010, 05:02:10 AM »
Yeah, I agree...it really turned out nice, Paul.
Are you done now, or what else is in the works?
~Joe
Offline paulages
  • 1976 cb735
« Reply #231 on: February 23, 2010, 09:10:51 AM »
~Joe
once i swap out the transmission and find my mystery oil leak it'll be done. i think.  ;)
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Frankenkit
« Reply #232 on: February 23, 2010, 01:12:58 PM »
Define "Done". ;)
1973 CL350- Lola?
Stuff for sale
Ryan 550k
« Reply #233 on: February 23, 2010, 04:40:05 PM »
Offline Little_Horse
    • My cafe build
« Reply #234 on: February 26, 2010, 09:32:19 PM »
Paul, I just noticed this but can you possibly show a closer shot of your coutershaft cover. I am looking for a solution to reducing its size and saw yours cut down, and if you don't mind too much I may gank the concept from you. Thanks.
"Little Horse Cycles" facebook page: http://www.facebook.com/pages/Little-Horse-Cycles/185809474769493
LHC is my start up cafe racer shop specializing in custom parts, bikes, restoration and recreation
The 500 builds http://forums.sohc4.net/index.php?topic=64250.0
Offline B.O.X.N.I.F.E.
  • The Stumped
« Reply #235 on: February 26, 2010, 09:52:31 PM »
I'm super jealous, congrats
1974 CB550
Forever West
Offline paulages
  • 1976 cb735
« Reply #236 on: February 27, 2010, 12:09:13 AM »
i'll have to take another picture. the guy took a good one, but i haven't obtained a copy yet. i'll say this: i cut mine down too much. it holds the shaft steady, but has more flex in it than i think it should.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
    • My cafe build
« Reply #237 on: February 27, 2010, 08:51:11 AM »
thats good to know, I was asking because I removed the starter and would rather not put the original cover back on but instead make it look like it was never supposed to be there kind of like yours. Plus I like seeing the counter shaft sprocket I think it looks very down to bussiness.
Offline paulages
  • 1976 cb735
« Reply #238 on: March 16, 2010, 12:08:13 PM »
Ok, a little tech update...
I received my loaner undercut trans in the mail a couple weeks ago (thanks Bwaller), but subsequently broke my hand and have been unable to work on the bike. I finally got it open now, and found some interesting things.
First, I discovered the gyst of my gear slipping problem: I mistakenly used a 550 shift fork with a 650 gear cluster, which resulted in incorrect clearances bewteen the shift fork fingers and its corresponding groove. In short, the gear could float in and out of it's mating gear without the fork budging. The two small forks themselves are well within specs, but the large center fork is .011" under. That gear was not being problematic, and having an undercut gearbox to go in, I think I'm going to call it ok.
Another strange problem: the bearing retainer that also holds the shift fork shaft in place was bent out 1/4" or so, as the shaft was forced outward by what appears to have been trapped air in the case where the other ends rests. I don't know the cause of this problem, but plan to drill a relief hole in the shaft to prevent it from happening again.
Should have it back together this evening, and then it's on to the mystery leak...
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline moham
  • .fnord.
« Reply #239 on: March 16, 2010, 06:11:16 PM »
Does that mean you're leaving the large fork in or were you referring to the two smaller forks? You're saying the undercut trans will help keep it from slipping, even with the mismatched forks? Sorry for my ignorance, transmissions are mysterium to me...
And didn't you promise me some killer pizza combinations? The wood-fires oven is up am rolling out a thousand pizzas a week (give or take a couple..)
lovely bike, again.
Mo.
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline paulages
  • 1976 cb735
« Reply #240 on: March 16, 2010, 07:33:57 PM »
lovely bike, again.
Mo.
it may very well be that the undercut trans would have prevented future slippage with the mismatched forks, but no.. the fix was to use the right forks.
i'll PM you some recipes.  ;)
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
traveler
« Reply #241 on: March 16, 2010, 07:43:43 PM »
Paul....I have to say....you bike has really turned out outstanding!
PM sent.
~Joe
Offline Staggerlee
« Reply #242 on: March 16, 2010, 08:09:03 PM »
Wait, what?
Pizza?
Offline paulages
  • 1976 cb735
« Reply #243 on: March 16, 2010, 10:02:08 PM »
Wait, what?
Pizza?
mmmm, pizza. yes, I built a wood-fired pizza oven in my backyard (before all these yuppie places opened up in town), and moham built one to serve to the public. mine's tuscan-style, cooking the pizzas in 60-90 seconds at 900F. yum!
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Frankenkit
« Reply #244 on: March 16, 2010, 11:16:09 PM »
Italian style blast furnace?  mmmm...
1973 CL350- Lola?
Stuff for sale
Offline MickeyX
« Reply #245 on: March 16, 2010, 11:35:11 PM »
I like mushrooms on mine. Lots of mushrooms.  ;D
Offline paulages
  • 1976 cb735
« Reply #246 on: March 16, 2010, 11:52:31 PM »
okay, okay... you ladies will be invited to the next pizza party.  ;D
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline moham
  • .fnord.
« Reply #247 on: March 17, 2010, 03:00:27 PM »
come on dude, yuppies are kinda cute when they're gentrifying a neighborhood....
78 750K-The Ocho
Ryan 550k
« Reply #248 on: March 17, 2010, 03:11:11 PM »
 :D :D :D
Offline ev0lve
« Reply #249 on: April 06, 2010, 08:28:56 AM »
