Author Topic: What did you do to your bike today ?  (Read 3762977 times)
Offline Grnrngr
« Reply #1650 on: April 05, 2010, 11:11:33 AM »
comstar style forks instead of spokes
uh oh....I've been planning a dual disk swap....how are these forks different? So you're saying I can't put my 80 comstar dual disk on my '74 forks?, if not, is it possible to pull the disks and speedo drive off that wheel and put them on my '74 spoke wheel? heh...guess it's not a thread-jacking...but thats some questions I didn't think needed asking....
pulled my Virago outta the storage, noticed my key wasn't in the switch, installed the new solenoid, cursed myself for not bringing the key, rolled it back inside, went home and remembered I had put my key on my keychain so it was in my pocket the whole time. eeerrrrrggggghhhh   CRS kickin in....
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
Offline Frankenkit
  • Industrial Strength
« Reply #1651 on: April 05, 2010, 01:03:23 PM »
rode to school.  i got a lot of looks.  People were torn between admiration and wondering if I'd gone 'round the bend.
It was cold and wet and I had a ton of fun. :D
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
« Reply #1652 on: April 05, 2010, 04:09:05 PM »
Took a few photos of my bike this morning(0 deg. F. !!)
And started her up 'till she was warm, and did doughnuts in the snow in my driveway.
Should have put the bike in last night......
Ya think?
l8r
PLEASE put the bike under cover!  Don't be "one of those" type owners.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #1653 on: April 05, 2010, 06:45:39 PM »
I get that look a lot!  I love to ride in "non-traditional" bike weather.  The H-D guys and gals at work shake their head, but I know secretly they are jealous!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline grumpy
  • ..... '73 750K3 .....
« Reply #1654 on: April 05, 2010, 07:32:19 PM »
new tires
new speedo & tach cables
adjusted headset
changed the fork oil (twice  ::) )
cleaned up fork oil for a long while  >:(
Offline Industrial Cafe
  • Like a well oiled
    • Undead Asphalt
« Reply #1655 on: April 05, 2010, 07:32:45 PM »
made fender brackets.
Offline 1080
« Reply #1656 on: April 05, 2010, 08:18:22 PM »
Work on fork brace the  chopper.
« Last Edit: April 05, 2010, 08:26:52 PM by 1080 »
Offline motocyconomad
« Reply #1657 on: April 05, 2010, 08:23:33 PM »
I put a pillow on the bike and rode around the block a little
Offline PhilipB
« Reply #1658 on: April 05, 2010, 09:01:23 PM »
Decided to drop the oil pan to see what might be hiding in there. I have never dropped it when I change the oil. (don't ask why). Dang,  >:( who's idea was this again?
Why did Honda weld the bolts in there? I broke out the impact wrench and that made all the difference. No broken or stripped bolts or holes. Wow, gears look great.
(nice and clean)
Wow, look at all that crud in the bottom of the pan. looks like graphite paste.
My last 2 cans or carb cleaner later and some time spent at the drill press with a wire wheel everything shines like new. I found a good size roll of rubberized gasket material at the auto parts store to make new gaskets. (worked great) I did the clutch cover too because I think that's where the oil seep was. Used my last on hand filter and stink-en Wal-mart no longer sells the fram 6009/6012 I need.  >:(
Dang!!! I broke the kickstart bolt off. Well at least it broke where it's still holds the leaver tight so I can use it until I have to pull the clutch cover off again.
I guess the only way to remove it now is to get out Mr. Dremel and cut the bolt at the gap to remove the leaver so I can drill it out. Bummer.
Well that's it for me.
P.S. I did make a great little drain/catch pan out of beer cans so I can drain the float bowels without the gas going on the trans.
When in doubt drink another beer, it may help. ;D
PhilipB
Offline michrobi
  • Goldenrod blew a 5" hole out the front with a
  • On a neverending quest for more garage space
« Reply #1659 on: April 05, 2010, 10:29:38 PM »
Take that, world!
-Mike
'78 CB750F All stock except for the powerplant. Jived it off my Dad in the spring of '94. He had it since 1980 and it's the first bike I ever rode on.
Current project: http://forums.sohc4.net/index.php?topic=67756
How's them SOHC4 patches coming?
« Reply #1660 on: April 06, 2010, 05:24:34 AM »
(nice and clean)
PhilipB
While you had the pan off, did you look up at the oil pump filter screen?
Offline PhilipB
« Reply #1661 on: April 06, 2010, 06:48:42 AM »
Yes I sure did. I even took it off and gave it a good old carb. cleaning bath. Everything was very clean. I expected a lot more goo and stuff.
It was just the pan that needed the attention.
Even the filter and oil looked clear and clean like I just put it in, it was 6 or 7 months old and 300 or 400  miles on it.
I was too cheap and lazy to put fresh oil in it before I put her to sleep.
I usually get to ride during the winter on some days here in Texas.
I don't ride long trips just a lot of short ones an hour at most.
Time on the oil is my problem not milage.
I can't believe my Honda book says to change the oil every month or 600 miles. Motorcycle oil here is like $4.00+ per qt. here.
PhilipB
« Reply #1662 on: April 06, 2010, 07:00:29 AM »
SNIPI can't believe my Honda book says to change the oil every month or 600 miles. Motorcycle oil here is like $4.00+ per qt. here.
PhilipB
Great on the screen. That sounds excessive, misprint or misread maybe? Twice a year or 3000 miles seems better. Maybe 1500 miles?
Offline PhilipB
« Reply #1663 on: April 06, 2010, 07:19:50 AM »
My mistake. 3 mo. or 1,500 miles.
Offline myhondas
  • Not really such a
« Reply #1664 on: April 06, 2010, 10:37:21 AM »
THE REBUILD STARTS ! ! !.....Started by putting the newly polished forks back together. Will slowly start putting things back on it and do all the upgrades. got about a month to get it together and running.
1974 CB 750 K4 SHOWROOM
1965 C100 CUB 50 (PIT BIKE)
1996 VF 750 CD daily rider
SOHC# 5105 11228
Offline mcpuffett
« Reply #1665 on: April 06, 2010, 02:55:11 PM »
finally got round to working on my 1970 cb750 on saturday  8) it has been laid up since before christmas, changed the jets from 125's down to 115's, i was going to put a K&N air filter in but i couldn't get one of the bolts undone that seperate the standard air box >:(, took it for a test ride or two and the plug colour looks good  ;), gave her a wash and shot some photos, went for ride on her on sunday  ;)cheers Mick
Offline SOHC Digger
  • I'm not an
« Reply #1666 on: April 06, 2010, 03:10:10 PM »
Mounted the front end and rear wheel to the frame I picked up on Saturday.  Took some pictures.  Started to get excited.
Offline fire113
« Reply #1667 on: April 06, 2010, 03:44:29 PM »
...put new chains, new crank bearing, rod bearings, and and and...
Offline Pawsoff
« Reply #1668 on: April 06, 2010, 03:59:02 PM »
Put the correct style airbox on, just waiting on my UNI filter and carbtune to come in the mail.... and complete the registration process.
Pawsoff
1977 CB550F
On the road, slowly improving the bike :)
Offline hoodellyhoo
  • CB350F
« Reply #1669 on: April 06, 2010, 06:00:06 PM »
Yesterday I did some research and decided that I want to get Avon Roadriders for the 350 now that it needs a new set of tires.
Today I did some fiddling with the 750 and tried to fix my leaking #3 carb bowl. I swaped the gasket out for a good one but that didn't help. >:( I got bored with it and went to buy a new battery for it. Once I got back I took the carbs off and maybe I'll look at them tomorrow .
  • Like a well oiled
    • Undead Asphalt
« Reply #1670 on: April 06, 2010, 06:10:45 PM »
found out my tag light lights up more than just the tag- NEATO!!
Offline Really?
« Reply #1671 on: April 06, 2010, 07:32:29 PM »
Nuthun,  Still exhausted from being frustrated last weekend.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline DanEarl
« Reply #1672 on: April 06, 2010, 07:59:41 PM »
broke an exhaust stud!
1972 cb500four
Offline kopptl
« Reply #1673 on: April 06, 2010, 08:16:28 PM »
removed a bad oil pressure switch invetween classes.... ordering new one at the moment!
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #1674 on: April 06, 2010, 08:39:06 PM »
i cleaned up and polished my new (to me) stock 4 - 4 pipes for a 750.
Mark Twain - Notebook, 1894
