Author Topic: What did you do to your bike today ?  (Read 3668412 times)
0 Members and 9 Guests are viewing this topic.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #16775 on: February 22, 2014, 02:17:36 PM »
Made my last order from Yamiya for my sandcast project...
RHS with black kill knob
Acorn stem mirrors
Side cover screens
Side cover grommets
Harness band clamps
Blinker relay rubber housing that clips onto battery box
« Reply #16776 on: February 22, 2014, 04:04:58 PM »
"Checked the pipe sets that I sprayed with wd40 last Year, no rust until yet."
What do you have there, a 15 cylinder radial engine? ;)
No, it's called extreme hoarding and I am very jealous.
Offline fire113
« Reply #16777 on: February 22, 2014, 04:19:13 PM »
...haha  ;) No need to be jealous !
Take a look at the picture, 2 bikes without pipes and the third on is waiting.
When I finished my projects all pipes will be gone or maybe I have to buy some more.
Have a good one...Georg
« Reply #16778 on: February 22, 2014, 05:15:09 PM »
I've still gotta get some spokes to lace the matching Borrani rear rim to another hub, but the guys at Buchanan's aren't being all that helpful, I sent them an email asking what heavy duty stainless spoke kit I needed to lace my Borrani WM5 18" rim to a K1-K6 rear hub, and they came back to say that it depended what the inside diameter of my rim is? I thought that they'd know all that stuff? Oh well, I guess I'll have to do their job for them.......... Cheers, Terry. ;D
That's because there is more than one style of rim profile.  The rear rim in the photo is a drop centre, the front is a regular shouldered rim.
Thanks Brian, the wheel on the back is only there until I get the Borrani shouldered rim laced up to the rear hub.I explained to Buchanan's exactly what sort of rim I had, but they didn't seem all that helpfull. Oh well, I know their spokes are good, so I'll do their job for them, I guess............. ;D
Offline edwardmorris
  • Youngish
« Reply #16779 on: February 22, 2014, 05:31:45 PM »
Mostly cleaning up the bottom end, main shaft, final drive, kickstart etc.
Offline Tintop
« Reply #16780 on: February 22, 2014, 06:31:27 PM »
Kind of strange with Buchanan.  When I got spokes for the Borrani's on the 550 I just called them and told them I had WM2 & WM3 18's to go with stock Honda f & r hubs.  No issues. ???
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline bjbuchanan
« Reply #16781 on: February 22, 2014, 06:39:36 PM »
No personal experience here but from what I have seen/heard Buchanan's must have one or two tech/support people who just aren't very helpful or can't quite nail your combo. Overall they seem to be good but...I guess you could say that about everything
For me, I pulled my bike apart, again. I yanked the battery box and the exhaust for a changeup. I'm gonna clean up/shave the battery box a little and mount my beat up Hooker. (Thanks Toytuff)
Thanks to my Tracy body the battery isn't a two second job. Luckily my electrical is  ::)very sorted.
Offline MoMo
  • Ride like you're invisible
« Reply #16782 on: February 22, 2014, 07:57:16 PM »
You're going to  mount a beat up hooker.  Shame on you ::) ....Larry
« Reply #16783 on: February 22, 2014, 09:26:29 PM »
I've bought from Buchanan's a couple times, the girls who answer the phones don't always know the answer.  Once I was transferred to a male tech, he knew exactly what I needed.
Oddly, the girl did not know what nipple size I needed!  Really.
Didn't do a dam thing to my bikes, I'm in Florida, 1200 mikes away....
Offline bjbuchanan
« Reply #16784 on: February 22, 2014, 09:39:41 PM »
I got that hooker all beat up from YOU, don't you put that evil on me Ricky Bobby
Don't You Put that Evil on Me, Ricky Bobby!
« Reply #16785 on: February 22, 2014, 11:58:59 PM »
Here you go Brian, here's the email I sent them, and below that is their reply. I already knew how much their spokes cost as I contacted them thru their website, so I don't think that A.F.'s reply was particularly helpful..........
G'Day Guys,
             I've got a 1971 Honda CB750. I want to install an 18 inch rear Borrani flanged WM5 alloy rim circa 1970's and need to lace it to the stock (1971-76) drum brake rear hub with some heavy duty stainless steel spokes, can you tell me which Buchanans spoke kit will suit my project? Thanks in advance!
Terry.
The estimated cost for 40, 7-8gauge stainless steel spokes w/nipples is $129.00 each rear set. The length of the required spokes is based on the inside diameter of your rim.
Thank you
A.F.
Re: What did you do to your bike today ? 3 Relay mod
« Reply #16786 on: February 23, 2014, 04:15:48 AM »
3 relay mod done! 2 relays for headlight (Lo-Hi), 1 for ignition to avoid burned ignitiion key switch and handle bar controls with crappy switches and thin cables. Now controlling the relays only. All relays have their own 12 V direct from battery, cable fuse close to the battery connection. (Connected at starter solenoid in connection screw)
The relays are connected in parallel to everything else, easy to switch back without relays.
I managed to squeeze in the 2 relays inside the head light!
I think that the coils get better power now when the 12V has only one switch now, the relay. before crappy switch and handle bars switches.  I did not measure before, but it must be better now! :)
EDIT: I have a new tank set with side covers from Yamiya750 with all badges etc. I'm afraid to scratch them so I'll drive the bike  a few days in spring until the bike will get the goodies. 1 scratch will be horrible.... ::) :-X
The bike project is ready now...
Next project is frame mod kit, open the head cover replacing most of the cyl studs, cam towers and double check o-rings + time the cam again.
« Last Edit: February 23, 2014, 04:28:16 AM by PeWe »
Offline strynboen
« Reply #16787 on: February 23, 2014, 10:58:23 AM »
got my littel yamaha running..got bleedet the disc breake..its a bit overkill for a 35 kmt moped..but looks fine
now aut and give the nature some 2 stroke smoke...
i hate all this v-w.... vords
Online 750K
« Reply #16788 on: February 23, 2014, 11:47:28 AM »
^^^nice, that little Yamaha looks fun.
77 Cb750, 78 Kz1000
Offline fire113
« Reply #16789 on: February 23, 2014, 03:25:39 PM »
...took off more chrome stuff.
Offline Tintop
« Reply #16790 on: February 23, 2014, 03:57:29 PM »
I guess that chicken doesn't have any more teeth Terry. ::) ;D ;D ;D ;D
77 CB550 Cafe build
« Reply #16791 on: February 24, 2014, 03:41:12 AM »
The very angled shocks rear lower mount look strange. It should be attached one step forward, in the other hole in the swing arm, right?
Offline fire113
« Reply #16792 on: February 24, 2014, 08:10:36 AM »
Hi PeWe,
...don't know  ??? was mounted this way as I bought it  ;D I will take it off anyway when I put the K0 wheels on, I don't like this lowering kits.
Checked the parts that I brought to the bike today, ready to swap the wheels and fork but the fork ears are still waiting for the paint job. Think I will take the K2 ears until the paint job is done.
« Last Edit: February 24, 2014, 08:12:44 AM by fire113 »
« Reply #16793 on: February 24, 2014, 09:11:54 AM »
Aha...lowering kit...that explains it. I have never seen that.
K0 is a model I want to have too. Original as it left Honda but fresh restore.
Offline fire113
« Reply #16794 on: February 24, 2014, 12:34:07 PM »
...go and start a K0 project ;) here is my first K0 rebuild.
« Reply #16795 on: February 24, 2014, 12:44:50 PM »
WOW!
Something like that! Or even more precise ... Exactly like that!
K0 is not for sale that often here. I have to keep my eyes open. Or import ... I need to check the additional costs for import
Offline fire113
« Reply #16796 on: February 24, 2014, 03:30:40 PM »
WOW!
...buy one in Europe or isn't Sweden in the EU ;) no IMPORT-TAX in the EU.
« Reply #16797 on: February 25, 2014, 03:04:40 AM »
It seems to be much more of these in USA and for less money than in EU. CB750 is very popular today, many guys restoring them too.
Offline fire113
« Reply #16798 on: February 25, 2014, 03:53:14 AM »
...K0 VIN ~10000 (motor&frame=matching numbers) went for 2000€ (sold from the Neterlands) 1/2 Year ago and I missed it :(
Good luck...Georg
Offline johsch
« Reply #16799 on: February 25, 2014, 10:01:10 AM »
Got my new brakes and rear set mounted. If only the winter would end so I could try how they work.
