Author Topic: What did you do to your bike today ?  (Read 3980069 times)
0 Members and 8 Guests are viewing this topic.
Offline grcamna2
« Reply #32750 on: January 28, 2024, 12:07:06 PM »
'bear claw' foot pegs done
How it's looking at the moment
Side covers pretty much done
I like all the mods done here. Especially the exhaust header clamps.
Do they do the job? No leaks? Where did you source them?
Spotty,I noticed the cover off;how's your shifting mechanism ?
75' CB400F/'bunch o' parts'
Offline 88BuckMeister
« Reply #32751 on: January 28, 2024, 12:20:44 PM »
I sanded my fuel tank to try and figure out why in the hell the last guy covered the emblem mounts in bondo. I've successfully dug them out. I still have no answers as to why the hell the last guy buried them in bondo. New Honda tank emblems costed me like 60 bucks
Offline grcamna2
« Reply #32752 on: January 28, 2024, 01:18:14 PM »
Sometimes certain owners do the 'emblem delete' on the tank when they repaint the bike.
I imagine it looks better to them without the emblems;a certain 'smooth/clean' look.
Offline spotty
« Reply #32753 on: January 29, 2024, 01:07:41 PM »
i've never ridden the bike but the PO reckons theres nothing wrong in that department, i can't remember why i took the cover off
i blame Terry
Offline BenelliSEI
  • 1969 cb750
« Reply #32754 on: January 29, 2024, 06:08:56 PM »
Four shiny covers!
Offline grcamna2
« Reply #32755 on: January 29, 2024, 09:02:01 PM »
I really like the stator cover too  8) 8)
« Last Edit: January 29, 2024, 11:56:13 PM by grcamna2 »
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #32756 on: January 29, 2024, 10:50:04 PM »
Four shiny covers!
Bud! You did a heck of a job. They look great!
Sent from my LE2127 using Tapatalk
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline BenelliSEI
  • 1969 cb750
« Reply #32757 on: January 30, 2024, 05:42:12 AM »
Better on the bike!
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #32758 on: January 30, 2024, 06:01:41 AM »
Better on the bike!
Shewwww-eeeee
Talk about clean.
You could eat off that thing!
Offline M 750K6
« Reply #32759 on: January 30, 2024, 06:22:04 AM »
Super job. 👍
Envy your undamaged points cover!
Offline BenelliSEI
  • 1969 cb750
« Reply #32760 on: January 30, 2024, 06:45:00 AM »
Super job. 👍
It had a tiny ding I pushed out. I only have one really good one left, for the S/C!
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #32761 on: January 30, 2024, 06:45:34 AM »
Nice polishing, looks chromed.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #32762 on: January 30, 2024, 07:17:29 AM »
Was a great day in Central Texas yesterday, decided to roll the CB750 out of the garage.  Cranked it over, seemed starter was a little slow, but after 3 cranks, she fired up! [it's been about 2 months since riding this bike]  Sunny and 70 degrees, perfect day to go for a ride, I love winter-time in Texas....
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #32763 on: January 30, 2024, 11:02:49 PM »
When out to start to CB project.
smelled gas as I opened the shop door.
i had one float a bit high and one leaking bowl gasket. carbs 1 and 2. cleaned up the gas and it fired up and idled well enough for now.
waiting on parts to do much more with it ATM.
« Reply #32764 on: January 31, 2024, 07:05:48 AM »
Did you leave the petcock on?
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #32765 on: January 31, 2024, 07:18:02 AM »
Yes.
Offline Magpie
« Reply #32766 on: January 31, 2024, 09:52:03 AM »
A good friend gave me an engine stand so I did a major clean up of the engine for my K6. I should have bought a stand long ago!
Offline Floshenbarnical
  • Money pit enjoyer
« Reply #32767 on: January 31, 2024, 11:18:07 AM »
Why is this the single most British image I have ever seen? I can practically smell a steak and kidney pie
"All things change in a dynamic environment. Your effort to remain what you are is what limits you."
'77 CB750 SS
Offline spotty
« Reply #32768 on: January 31, 2024, 04:35:10 PM »
i've got terrys engine stand at my place and i was thinking this would be a good idea for when the time comes to clean/paint my engine
could you chuck a picture up of how its all bolted up at the back ? did you make brackets to turn the attachment points 90 degrees to attach to the motor
i blame Terry
Offline lash
« Reply #32769 on: January 31, 2024, 05:12:20 PM »
Here’s mine..just some pieces of angle iron and bolts
« Last Edit: January 31, 2024, 05:15:37 PM by lash »
Offline spotty
« Reply #32770 on: January 31, 2024, 05:22:55 PM »
thanks for that
i blame Terry
Offline BenelliSEI
  • 1969 cb750
« Reply #32771 on: January 31, 2024, 07:50:10 PM »
Spotty….. I used two pieces of angle (4” X 4””). One set of holes for the rear through bolts on the engine and four bolts directly to the main plate on the stand.
What you can’t see clearly is a bit of “shaping” (with a grinder) around the clutch cover where the kick start shaft is located.
Offline newday777
« Reply #32772 on: February 01, 2024, 03:31:54 AM »
This is what I cut up to make the motorstand adapters. I used some 2"×3" angle iron and cut Vs out to clear the back sides of the cases.
I picked up this K5 motor a couple years ago as it was pulled out of a chopper, low miles on an 836 build, ported head, SS2 cam + springs and titanium keepers. I still have to go through it and inspect the insides as well as vaporblast the paint off and repaint.
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #32773 on: February 01, 2024, 03:33:15 AM »
A friend in California has this stand off bracket welded up
Stu
My current rides
Prior bikes....
Offline WhyNot2
  • I'm finally an
« Reply #32774 on: February 01, 2024, 07:12:46 AM »
Still haven't installed this tank yet, but the CB750 will be going on the table this week.
Agenda:
Change rear swingarm with a CB550 one.
Change front forks with CB550 set.
Try my hand again at polishing some pieces.
Will try to do some rewiring to clean up the rats nest in the headlight.
If I can get to it.......the shop called and finally after 2 years, the head for the frankenbike CB/CL/SL350 twin is ready.
Been messing with this thing a few years or more.
