Author Topic: 1975 Supersport, performance cafe  (Read 136208 times)
Re: 1975 Supersport, performance cafe
« Reply #425 on: September 02, 2013, 08:25:38 PM »
Dave,
Looking good!  I am torn on the steering damper issue on this build.  Can you share what type you are installing and how you plan to mount it?
Also, are those stock GL1000 brake discs or aftermarket?  What kind of fork brace are you going to use?
PS  The bike looks awesome, as ever.  I was so focused on the front end, I completely missed the graffiti on the lift.  ;D
Offline Doctor_D
« Reply #426 on: September 03, 2013, 06:58:38 AM »
Doc,
I'm doing a GL1000 fork swap too.  Can you share where you got the phenolic pistons and EBC discs and details on the parts?
Here's what I've gotten so far:
Part        Supplier
Replacement Fork Seals        Z1
Fluid   US3 (15wt)        Racetech
Cartridge emulators & adapter FEGV S3301 & FPEV AD3303 P                        Racetech
Fork tubes   -2"        Franks Maintenance and Engineering
Springs   FRSP S2643095        Racetech
Fork Brace (Superbrace)        Randakks
Gators        EBay
Tapered steering bearings  All Balls        EBay
Caliper rebuild   hardware        Bike Bandit
Brake master cylinder  5/8"        Randakks
Brake lines and "T"        Spiegler
Rotors EBC MD1074LS & MD1074RS        Bike Bandit
Brake pads  EBC Semi-sintered        Bike Bandit
Phenolic caliper pistons        Godffrey's Garage (member here)
Top triple tree (CNC)        Dime City Cycles
I seem to recall you asking the rotor question before. ;-)
Take care,
David
1978 CX500
1971 Norton Commando
Offline Doctor_D
« Reply #427 on: September 03, 2013, 07:33:08 AM »
As for the damper, we'd welded a mount to the frame originally, and I've been running a simple NHK unit that I picked up from MikesXS.
So, it's just a matter of adding a mount to the fork leg to keep the damper.  I liked the look of this SES unit: http://www.ebay.com/itm/37MM-STEERING-DAMPER-FORK-CLAMP-/280722516473?pt=UK_Motorcycle_Parts_13&hash=item415c5da9f9 and it should be here soon
Take care,
David
1978 CX500
« Reply #428 on: September 03, 2013, 09:33:25 AM »
Doc,
Part        Supplier
Gators        EBay
Hey Dave,
I'm getting old and forgetful. ;)  Last night I was looking from my iPhone and the discs looked different than stock -- looking on my PC they are clearly floating rotors.
I wasn't sure if you were still running the EBC discs or not (as they were spaced to you old 750F front end).  Since you had switched to a GL1000 front,  I assumed that the spacing to the rotors was different, so I wasn't sure if you you went to the GL1000 discs or did something new.  I see from the fitment guide that the MD1074 is a direct swap for the GL1000 rotors.  I imagine they save a few lbs from the stock rotors.
« Last Edit: September 03, 2013, 09:59:46 AM by CB750 Cafe Racer Fan »
« Reply #429 on: September 03, 2013, 10:09:45 AM »
I, too, am in the midst of a GL1000 front swap.  I have 1.125" shorter than stock tubes (from Forking by Frank), the Dime City upper triple clamp and brackets to mount my key switch and gauges, and the stock GL1000 brake calipers (with Goddfrey's phenolic pistons) and drilled GL1000 brake discs.  I originally mounted Tarozzi high-rise clip-ons but they would not hold their position because the pivots are not indexed -- no matter how tight you ratchet them, they still move when you push or pull with a bit of force.  I swapped them out for 37mm Vortex clip-ons.  I also went with a Telefix fork brace.  I am using the Motolanna fork ears, but I have decided to invert them, because I think they will look better slanting upward than downward (as they are pictured below).  I am on the fence as to a steering damper, but I am gathering ideas in case I get any head shake down the road.  I like the idea of lighter, floating rotors, so I might upgrade down the road, as well.
« Reply #430 on: September 06, 2013, 02:20:04 PM »
 CB750 Cafe Racer Fan, what's the "British Flag" doing on your turn indicator/indicator light panel?  These are Japanese bikes, not British bikes...
 ;D ;)
« Reply #431 on: September 08, 2013, 11:36:47 AM »
 ;D ;)
There's a Union Jack on the oil tank, too.   It's a Japanese bike, with Brit cafe style.
Offline Doctor_D
« Reply #432 on: September 19, 2013, 06:50:24 AM »
Well, I rode it to Backfire Moto last night, and what a difference.  The new brakes have transformed the bike into something much more confidence inspiring.  Before, I was hesitant to really get on the throttle because it would eat road so quickly and in the city you never knew when you'd have to stop.  The brakes weren't bad - they just weren't as good as they should be on a bike this fast.
Now, I grab a handful of brake, and drop out of warp without any drama or uncertainty.  I found myself waiting to brake late just to test the threshold braking and progressivity of the setup.  The rigidity of the forks has to help here as well.  In a little bit of winding road riding in the Magnolia neighborhood last night, the front end felt less noodley.  Again, not that the CB front end was bad, just that there is a noticeable difference here.
The only complaint is that there's a little fork stiction, which should improve as the new seals break in.
Take care,
David
1978 CX500
« Reply #433 on: September 19, 2013, 07:58:57 AM »
Dave,
Glad to hear your satisfaction with the new front end and brakes. The stock CB750 front can feel a little wobbly in comparison to a modern bike.  I am hoping to feel as happy about my GL swap when I get my bike on the road.
Love your bike and would love to see some more pictures of the newly completed version.
D
Offline Doctor_D
« Reply #434 on: September 22, 2013, 07:47:05 PM »
Here it is at Backfire Moto last Wednesday.
And since it's back on the road, it will commence raining in Seattle in 3... 2... 1...
Take care,
David
1978 CX500
« Reply #435 on: September 22, 2013, 09:22:11 PM »
David, very clean and nicely put together...
Well it is fall and around here it rains more in spring and fall, but this year has been wetter than normal with over 16 (?) inches above normal precipitation levels
Offline Doctor_D
« Reply #436 on: October 05, 2013, 02:01:32 PM »
Yesterday was gorgeous, as is today and possibly tomorrow.  Enjoying it while it lasts.
Have to laugh though.  The rear rotor is bigger than the front rotors.  Think I'll ditch the pie-plate and put some smallish, modern thing on there over the winter including an underslung Honda caliper.  Something interesting to research during the rainy months.
The best projects are never done, I guess.
Take care,
David
1978 CX500
« Reply #437 on: October 05, 2013, 05:25:59 PM »
[/b]
Never a truer word spoken David.  ;D
« Reply #438 on: October 05, 2013, 07:02:05 PM »
16 inches of rain.. That is a whole year for us ..
Offline Godffery
  • Godffery's Garage
« Reply #439 on: October 06, 2013, 07:46:16 AM »
I can make your "Pie-plate" Much lighter if you'd like.
http://www.vinmoto.org/gallery/v/VinMoto-Garage/album03/Godfferys-Garage-123/95/Brake+Rotors+_+Thinned+and+Drilled/
Yours would be in the top row, 3rd one over. These Rotors are nearly half the weight of stock and grab like the X-wife on her way out of the house.
Offline Doctor_D
« Reply #440 on: October 06, 2013, 09:09:47 AM »
You must be in the rain-shadow, across from Sequim.  We get 39" in Seattle.
Take care,
David
1978 CX500
Offline Doctor_D
« Reply #441 on: October 06, 2013, 09:32:05 AM »
You're always on my list.  Those phenolic pistons are a godsend.
Still looking for a way to reduce the diameter in addition to thinning and drilling.  What other Honda rotors fit the bolt pattern and offset but has a smaller OD?  '81 900F?
Take care,
David
1978 CX500
Offline Godffery
  • Godffery's Garage
« Reply #442 on: October 06, 2013, 10:32:34 AM »
Actually if your after a smaller diameter, I can mount a CB550 front Rotor to the CB750F rear Carrier.
Offline mazen0822
« Reply #443 on: October 11, 2013, 11:32:18 PM »
any more info on this?
Offline Godffery
  • Godffery's Garage
« Reply #444 on: October 12, 2013, 08:22:38 AM »
Just send me your stock one, I'll do the mods removing it from the carrier & replacing your 295.8mm rotor with a Drilled & thinned 276.1mm rotor, then send it back within 48hr's.
They are $88 each with your core, return shipping is $12.50 in the continental US.
 jstephens7@wi.rr.com
Offline Doctor_D
« Reply #445 on: October 12, 2013, 08:35:28 AM »
I'll need to look at a few different calipers to see what works with a smaller rotor, but that seems like a good plan.
Maybe something like this:
Take care,
David
1978 CX500
« Reply #446 on: October 12, 2013, 08:41:05 AM »
David,
I see that you are afflicted with a common condition: upgrade itis!  ;)
I love this build!
Offline Godffery
  • Godffery's Garage
« Reply #447 on: October 12, 2013, 11:28:56 AM »
That might do the trick ?
Your brake pad contact area for the 276.1mm rotor would be about 90mm to 137mm from center.
« Reply #448 on: October 12, 2013, 06:10:44 PM »
What bike does that caliper fit? It looks very similar to my '82 FT500, except the FT has an added boss for the brake stay. The FT rear rotor is the same OD as the 550: 276mm.
Offline Doctor_D
« Reply #449 on: October 12, 2013, 07:15:26 PM »
It's from a 1981 cb900f.  No idea if it's even remotely likely to fit.
Now, the Ascot caliper is on my list to check as well.
Take care,
David
1978 CX500
