Be sure to visit the SOHC/4 Web Site for more information on Honda and the SOHC/4 Motorcycles.
Interesting.........Glad you could use my pics from a few years back. Here's how it turned out.
Thought I would post this early picture (edges need finishing) of my modified speedo drive for a 550. The key is that you need a front hub with the flats machined on two sides. I have a 550K (using), and early 750F (for next project) both with the flats. Also have a 78 550 without.So does anyone have suggestions to modify to fit for the hubs without the flats? i was thinking of grinding notches into the Inner diameter of the disc rotor...
Quote from: Tintop on May 05, 2010, 10:00:54 PMThought I would post this early picture (edges need finishing) of my modified speedo drive for a 550. The key is that you need a front hub with the flats machined on two sides. I have a 550K (using), and early 750F (for next project) both with the flats. Also have a 78 550 without.So does anyone have suggestions to modify to fit for the hubs without the flats? i was thinking of grinding notches into the Inner diameter of the disc rotor...My 78 550 hub doesn't have flats. I was thinking of taking the lip off the drive plate in a lathe, and then installing dowels in the hub which would mesh with holes in the plate.
That'll work if you have access to a mill. Machining flats into the backside of the rotor is a second way to do the job. RR
A member on the forums (Rangelov) has had a number of adapter plates machined out of aluminum for this very purpose. I'm awaiting mind, but they seem to be pretty damn slick. They're in the FS forum:http://forums.sohc4.net/index.php?topic=76835
Quote from: Ricky_Racer on September 10, 2010, 02:48:13 PMThat'll work if you have access to a mill. Machining flats into the backside of the rotor is a second way to do the job. RRAre you sure that would work RR? My rotor (550) is a slip fit over the hub centre. There is no clearence for the edge of the drive plate between the rotor and hub.tintop
Quote from: Tintop on September 10, 2010, 04:33:34 PMQuote from: Ricky_Racer on September 10, 2010, 02:48:13 PMThat'll work if you have access to a mill. Machining flats into the backside of the rotor is a second way to do the job. RRAre you sure that would work RR? My rotor (550) is a slip fit over the hub centre. There is no clearence for the edge of the drive plate between the rotor and hub.tintopSorry I missed your posting, TT. I don't know about the CB550, but I've seen reliefs cut into the rear of the CB750 rotors. Of course the chrome trim ring is unnecessary then. I'm using old sandcast drive plates that work like the cut 'n bent ones, so I haven't had to do either yet. RR
We made some of the modyfied speedo drives for double disc setups.nippon
