Author Topic: why this?  (Read 2774 times)
Offline Zig
why this?
« on: May 07, 2010, 10:38:31 PM »
why did po do this?? 2 washers under one bolt and 3 under the other.
any ideas?
« Last Edit: May 07, 2010, 10:40:51 PM by Zig »
Offline clayman74
Re: why this?
« Reply #1 on: May 07, 2010, 11:04:03 PM »
they clearly arent the stock bolts so.... to long?
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: why this?
« Reply #2 on: May 07, 2010, 11:07:04 PM »
yup, probably bottom out otherwise.
Offline Zig
Re: why this?
« Reply #3 on: May 07, 2010, 11:18:40 PM »
thats what i was thinking, was he to dumb to cut them down if thats all he had to work with? will figure it out when i disassemble.
Offline KB02
Re: why this?
« Reply #4 on: May 08, 2010, 04:41:33 AM »
I can't believe that plate didn't snap on him on reassembly. Wow...
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Re: why this?
« Reply #5 on: May 08, 2010, 06:58:53 AM »
He was too lazy to get the right size bolt...
traveler
Re: why this?
« Reply #6 on: May 08, 2010, 08:12:54 AM »
not lazy....used what he had in the garage.....it worked and the cover fit.
~Joe
Offline fastbroshi
  • Puppet
Re: why this?
« Reply #7 on: May 08, 2010, 08:25:50 AM »
"Hi, I'm the PO and I can't afford to go to the hardware store and spend $1 to get the proper bolts for critical components to the motor on my two-wheeled meat slingshot."
  On that note, Fastenal is awesome.  I'm literally right around the corner from Harbor Freight and two miles from Fastenal.
Just call me Timmaaaaay!!!
Re: why this?
« Reply #8 on: May 08, 2010, 08:26:54 AM »
YEah the 2 on the left are the correct ones, they have a flanged head (built in washer)they must be no longer than them. What he did while not very elegant was functional and no real risk to the plate if he drew them down properly, which he did either knowingly or accidentally.
I think they are "8" hardened bolts. THe one with 2 washers is an 8 looks like. THe phillips is a stretch.
« Last Edit: May 08, 2010, 08:29:24 AM by MCRider »
Re: why this?
« Reply #9 on: May 08, 2010, 12:35:32 PM »
~Joe
Too lazy to go to the hardware store and do it right.
