Author Topic: Sandcast #97 restoration  (Read 254414 times)
Offline markb
  • When I finish my current project I might be a
« on: November 01, 2010, 03:57:36 PM »
I've finally started this project after picking the bike up this past spring.  I spend my summers boating and fishing and do little if any work on the bikes.  I've got two other 750's that I've restored, an early diecast and sandcast #5383.  I'm going to post this on this forum and the SOOC forum so some posts by me will be identical but the replies will probably steer it in different directions so I'm not sure how that will work out.  But I figure that way I can get feedback from two different audiences.  My goal is to make it as correct as possible which I realize may be next to impossible because of the rarity of some of the missing parts.  There's plenty of work to do and plenty of missing parts.  I'm looking for all the advice I can get and if anyone has a part that I'm missing and you can part with please contact me.  I know they won't come cheap.  So for my first post, here's what it looked like when I picked it up last spring.
What a great motor number
« Last Edit: November 06, 2010, 11:49:49 AM by markb »
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline Damfino
Re: Sandcast #97 restoration
« Reply #1 on: November 01, 2010, 04:05:16 PM »
Mark, not sure I understand the four identical links to the same current sandcast auction on eBay?
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline markb
« Reply #2 on: November 01, 2010, 04:06:01 PM »
Ooops.  Technical difficulty.  Squared away now.
Offline Damfino
« Reply #3 on: November 01, 2010, 04:08:30 PM »
See it now... ;D
Looks like you've got some serious work ahead of you! I'll be watching, you've done outstanding work on your others!
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline Simpson
  • I ain't no
  • Aged to perfection
« Reply #4 on: November 01, 2010, 05:02:09 PM »
I'm microwaving some popcorn and getting a chair. This will be great.
Mark, please post lots of pictures.
This will be great, the heavy weight super bowl championship of restorations.
Can't imagine the cost, yikes...
1970 CB750 K0
1975 CL/CB 360 Mix
Offline vnz00
« Reply #5 on: November 01, 2010, 05:18:00 PM »
Good luck Mark. You have your work cut out for you, and if I can help in any way with early part pics, pls let me know.
Regards, Steven V.
Offline bgfootball67
« Reply #6 on: November 01, 2010, 05:32:52 PM »
Can't wait to see your progress.  Is the engine free?
Columbus VinMoto
Ohio Cafe Racers website - http://www.ohiocaferacers.com
« Reply #7 on: November 01, 2010, 05:39:56 PM »
Good luck Mark!
Knowing your previous work I am sure you will do an excellent job. I am with Simpson - lots of pics please!!!
cheers
Andy
Offline markb
« Reply #8 on: November 01, 2010, 08:09:15 PM »
Thanks for the support guys.
No it was part of the price...oh, do you mean does it turn over?  Unfortunately not.  More about that soon.
Online Stev-o
« Reply #9 on: November 01, 2010, 08:21:34 PM »
Are you going to try ATF/acetone on the stuck motor?
« Reply #10 on: November 01, 2010, 08:26:32 PM »
Does it have the small hole crank, early should have  smaller alternator bolt threads.
Offline Magpie
« Reply #11 on: November 01, 2010, 10:44:09 PM »
There's got to be a story about how you found this bike or it found you. Number 100, amazing! I wonder how long the assembly line was running when it rolled out the end all shiny and new.
Cliff.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #12 on: November 02, 2010, 04:49:23 AM »
Wowsers!  Those serial numbers are amazing!  May I ask how much you picked her up for?
« Last Edit: November 02, 2010, 04:59:24 AM by Greggo »
Offline markb
« Reply #13 on: November 02, 2010, 05:53:20 AM »
I'll use it everywhere.
I have no reason to believe it doesn't but I haven't got that far yet.  I'll let you know.
Cliff.
I actually found it from a posting here on a CL ad.  A custom bike shop in Oklahoma picked it up locally and I made up my mind I was going to get it.  The seller was out of town so wasn't answering his emails right away but through a little detective work I tracked down his shop and got his phone number and called him.  I got lucky.  We'll see how lucky once I get into it more.
All I'll say for now is too much?
Offline markb
« Reply #14 on: November 02, 2010, 05:54:12 AM »
First thing is to start the tear down.  I hoisted the bike up and dropped the front wheel and the three exhaust pipes that were there so I could put it on my cart.  I have a stand but it only puts the bike 18” off the ground and I hate kneeling and bending over.  The pipes disintegrated during removal.  I soaked all the nuts and bolts with a 50/50 mix of acetone and ATF.  I’ve used it before and seems to work great.  It separates though so you have to keep shaking it.
It must have been set up as a cruiser.  It has old running boards and crash bars.  I’ll get rid of those first.
Then I pulled the front end, fender and forks.  The headlight bucket and ears were completely broken as well as the speedo.  Good thing I have one of those.  Looks like someone took a baseball bat to them.  I think the tach is salvageable.
The tops of the fork tubes look pretty gnarly.
At least the front fender is correct and solid.
It looks better without all the junk and broken parts on it.
It’s missing the kick-starter so I put one on just to see if the engine would turn over.  Nope.  Tried moving the shifter too.  Nope.  After that I drained the oil…and water.  A cup of water came first then about a quart and a half of oil.  Nothing in the oil tank (although it is well coated inside with a layer of oil and dirt) or oil filter housing.  Ruh-roh.  Not a good sign.
« Last Edit: November 06, 2010, 11:54:13 AM by markb »
Offline HedNut
  • Underwater Basket Weaving
« Reply #15 on: November 02, 2010, 06:53:26 AM »
WOW! This is going to be an exciting build for sure!! Saved from the depths of certain death.... you'll make this a road tearing butterfly...I know you will!  I've got my popcorn cooking too....  :D  Awesome!
Offline ohiocaferacer
  • www.OHIOCAFERACERS.com
    • OHIO CAFE RACERS
« Reply #16 on: November 02, 2010, 07:02:23 AM »
Watching this one too!!!
Just a heads up....those Triple A floor boards are highly sought after parts. Alot of people are looking for them.
Offline The_Crippler
  • Work in progress.
« Reply #17 on: November 02, 2010, 07:10:30 AM »
No worries about that at all.  I've had some custom computer case mods that I did the same thing with - type out an update, copy it to both forums, answer/respond to any questions/comments that come up.  Twice the audience for the same amount of work (well, twice minus anyone like yourself that's in both places.)
It's 68 in binary.  Not sure if that means anything, but there you are.
EDIT:  Forgot to mention the obvious - I will be watching this build.  I know little about the 750s, and would never even think to attempt a project like this.  Nothing but respect for those that do.
Offline markb
« Reply #18 on: November 02, 2010, 07:39:06 AM »
Interesting observation.  So in a way it's a 2-digit engine too. ;)
  • Work in progress.
« Reply #19 on: November 02, 2010, 07:55:17 AM »
There we go!  I knew we could come up with something.
Offline markb
« Reply #20 on: November 02, 2010, 12:58:52 PM »
Just a bit more history before I get too much further.  The license plate on the bike was 1979.  The seller told me that it had been sitting and then an attempt was made to get it running again in 1986.  They never succeeded because they couldn’t get the carbs right.  So, I was told, it sat in a barn (don’t they all) until he obtained it.  (If it was in a barn it was a leaky barn.)
Anyway, one of the first things I discovered was it had the 19 liter tank and in pretty good shape at that.  The badge recesses had been filled in and unfortunately the cap and short-neck petcock were missing.
By the way, does anyone have a short neck petcock they could sell me?  This is a high priority for me because it is one of those really visible things.
Note the lack of dimples in the area where the carbs tops are.
I could tell from the bottom of the tank that it was originally candy red and after some debate I decided to keep it the color it was born which happened to be the same color as my later sandcast.  It’s already been internally derusted and coated and repainted and looks great.  Blake Conway who did my others did this one too.
My K0 was the blue/green so I put that tin on the other sandcast (so I could have one of each color) and I plan on using the red where I need too and borrow parts off the K0 so I can maybe get #97 put together while I hunt for correct parts.  Eventually I’ll probably do the K0 in gold (even though the VIN is a little low for that).  Can’t even think of that right now.
« Last Edit: November 06, 2010, 11:57:08 AM by markb »
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #21 on: November 02, 2010, 02:12:53 PM »
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline markb
« Reply #22 on: November 02, 2010, 02:25:18 PM »
Yea, I saw that one.  I was slightly interested in going to take a look at it.  It's about 2 hours away.  If it was older and had more of the stuff that I'm missing, I'd be all over it.
Mark
Offline UK Pete
« Reply #23 on: November 02, 2010, 03:27:05 PM »
WOW looking forward to the restoration, good luck
Pete
Offline onagd
« Reply #24 on: November 02, 2010, 04:05:27 PM »
Will follow this with much interest and appreciation and ENVY!!!!! :D
Brett
1973 CB350F
1975 CB400F
1998 GL1500
