Author Topic: My Honda S90 * operation vacation bike * Running and Riding WOOOOOOOOOO!  (Read 74196 times)
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
Hey there steve o. Long time. Why does the forum look so different to me? I can no longer just check into " recent posts". Don't know what the poop in the bar is. Fyi - just poured you an ice cold Becks.
Hey Frankie....yeah, life gets in the way sometimes, ya know?
The forum looks the same to me, not sure of your issue??
Offline streak09
  • I don't know what im doing, but I'll do it anyway
Bike looks great! I did a restoration on one the summer before last, so I can attest to the "hard to find correct part" situation. They are a blast to ride!!
OK so....I keep blowing fuses and the headlight won't work. When the key gets turned the red wire from battery is grounded to the motor!? I don't know where there could be a short....there is so little to the wiring. Ug. Any ideas
Offline phil71
is the harness intact, or was it cut up where it all meets the battery box? The battery on this bike IS the regulator.. it's very easy  to hook it up with the fuse in the wrong place.. then, it blows immediately, which only takes the battery out of the circuit. Once this happens, the stator is  free to send 16 volts to all your 6 volt bulbs, blowing up everything that is on. Bet you at the very least blew the headlight low beam.
Brand new (NOS) harness. Fuse is on the solid red from art to harness and the red with white goes to rec.
Offline phil71
Hmm. The fuse blows the second you turn the key on?  The key should not switch ground.
Re: My Honda S90 * operation vacation bike * Running and Riding WOOOOOOOOOO!
« Reply #182 on: September 14, 2013, 04:13:23 PM »
I just made these up to sell on my site. Just like stock but not brittle and I added a fillet to the tab for strength.
fendersrule
« Reply #183 on: September 18, 2013, 01:49:20 PM »
Hey Frankenstuff....you can't make side covers for my '70 SL350 can you?
« Reply #184 on: September 18, 2013, 02:05:27 PM »
Interesting choice of words Fenders...
So, if he says "yes" does this mean he can or can't?
Where are the arguments that there would be a market greater than one (you) to make it economically viable?
Where would he reach or how would he reach those other owners?
The SL350 is not a SOHC/4 design so it is not going to be here...
Are the CB or CL350 side covers alike?
« Reply #185 on: September 18, 2013, 03:04:52 PM »
I will make anything if I can sell enough to justify the cost.
« Reply #186 on: January 17, 2015, 07:16:48 PM »
Ha! I was just google-ing around about wiring on old Hondas and my own thread came up. Threat to revisit the pages and pics. The bike was put into storage before we moved, I can't wait to get it back into my line of sight. First I have a z50 to play with....then back to the 90.
« Reply #187 on: January 17, 2015, 07:47:11 PM »
Ha! I was just google-ing around...
google google
« Reply #188 on: August 04, 2015, 09:17:39 PM »
Just got my hands back into this bike. Feel like a few mods are in order. First off....switching the wiring harness back to the original. The original harness has no wires for directionals and a 3 way combination ignition. The new one I have in now has wires for all the bells and whistles and a 2 way switch.
Question....how do you hotwire a 3 way switch? Looking at the diagram red+black wires are ignition but....then I'm not connecting the dyno and headlight. Wait....I will attach a file.
« Reply #189 on: August 04, 2015, 09:18:48 PM »
« Reply #190 on: August 04, 2015, 09:21:00 PM »
I had to dig to find this diagram. The only one close to what my bike has for wiring. Not even in my shop manual.
« Reply #191 on: September 15, 2015, 08:45:36 PM »
Picked up this fine set of wheels for the90. These are from a cb175.....I love that brake. I want more beef for tires.
« Reply #192 on: September 15, 2015, 08:50:44 PM »
Love front drum brakes....except when I need to stop fast!
« Reply #193 on: September 15, 2015, 09:55:15 PM »
Nice twin-leading show brake.
« Reply #194 on: October 25, 2015, 09:05:15 PM »
Nice project, My prospect has no title, I'm looking for a frame with title. A guy I knew junked some a couple years ago.
« Reply #195 on: October 25, 2015, 09:32:29 PM »
Don, you can always go the Vermont title path. They will give you a legal title and then you present it to the local title agency. Some have ran with Vt title and registration for a year. Only becomes a problem if stopped in your state if you have requirements to title in 2 weeks to month in most states. If you have property in VT then it can be explained sometimes. Depends on attitudes of officer.
Otherwise,  there is bonded title process, etc.
Depending upon your state....
Some states do not do titles for old bikes and prior registration & bill of sale is sufficient in those cases. Depending upon where the bike came from and that state's requirements.
David
« Reply #196 on: October 25, 2015, 09:39:26 PM »
Franken,
That 175 wheel fits?
Are you considering upping the stock 8hp motor as well?
The 175 was advanced for its day creating 20hp and able to hit 75mph in tucked position. The front forks will quickly be a weak point if you are cranking out more power and mass on them. Are you considering changing the forks?
David
« Reply #197 on: October 25, 2015, 09:50:12 PM »
Don, you can always go the Vermont title path. Some have ran with Vt title and registration for a year.
Wrong - VT does not issue titles for bikes over 15 years old.
http://dmv.vermont.gov/registrations/drivers/title
Offline grcamna2
« Reply #198 on: October 25, 2015, 10:09:08 PM »
That CB175 front wheel/drum brake is good for the S90,I hope you can mount it up to your orig. forks.  8)
I'll be doing something similar w/ my CB125S as I'll be doubling the power by installing an XR200R motor in it later and swapping in a pr. of CB400F forks,CMX250C triples w/ a CB350 front twin leading shoe drum wheel which should stop her w/o any issues rain or shine,I just finished building the front wheel for it tonight w/ PC'd orig. spokes and rim w/ polished and clear coated hub.
75' CB400F/'bunch o' parts'
« Reply #199 on: November 12, 2019, 06:50:10 PM »
Still have the bike. Still ripping it around. Getting cold here in New England. I gave it the big bore treatment. 50mph is easy and I am smiling.
Sent from my SM-J737T1 using Tapatalk
